Old 08-22-2013, 03:54 AM   #61
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,886
Originally Posted by CruisingRam View Post
I sub'd this thread. Guess you can't buy it in the states huh?
I think somebody in the States have been trying for a while to get them passed for registration without much luck. The only company, I know stateside is AVA motorcycles selling their upsized version for a fair bit money.
13' kawasaki W800, Yep the twin
13' Skyteam Ace 125 BIG BORE
81' BMW R100 CS
Old bikers don't get old by accident.
Just Dan is offline   Reply With Quote
Old 08-22-2013, 04:57 AM   #62
CruisingRam
Frankenbike builder
Oddometer: 503
Just wrote them to get the details. A 250 would suit me just fine, if the price is right.
You think chicks dig guys who look like road-grimed power-rangers and have interesting x-rays? You must be smoking rope son!
CruisingRam is offline   Reply With Quote
Old 08-25-2013, 03:09 AM   #63
Chats
Oddometer: 13
Saturday morning in the garage and some new bits fitted. Some EBC sintered front brake pads. +1 front sprocket. Piggy back shocks.
Found the 2 bolts that hold the front sprocket on not much more than finger tight. Some loctite 263 will fix that.
Where did you source he shox from?
Chats is offline   Reply With Quote
Old 08-25-2013, 03:25 AM   #64
Chats
Oddometer: 13
I hope so. The Yuanxing tires were ok in straight line
Finished spooning on the tires. The rear end is starting to look good with piggy back shocks, Led indicators and new rubber
Are they ok to run with tubes in?
Old 08-25-2013, 08:34 AM   #65
hugemoth
hugemoth's Avatar
Oddometer: 2,894
Nice looking little bikes. The Honda CG125 engine these are cloned from is legendary for being trouble free and long lasting. With the balance shaft it should be a smooth running engine for a single cylinder although the design is somewhat noisy in the valve train area.
6 years ago I bought a 200cc Lifan in the factory crate and it has turned out to be a great bike. The engine is an enlarged version of the 125, with the balance shaft, and is still running great with over 43000 miles. The Loncin version will probably give you long and reliable service also.
Old 08-25-2013, 11:11 PM   #66
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,886
Most of the gear comes from either Ebay or OOracing in the UK. http://www.ooracing.com/store/index....productId=3981
I am running tubes in Michelin pilot sporty tires. They do grip well compered to the stock tires.
That is pretty amazing 43,000 miles. There are so many choices. We have cheap registration for bikes 125 and under. One option to keep it semi legal is to put a 150 barrel and piston on the 125 bottom end. The other is throw caution to wind and replace the 125 with a Loncin / Zhongshen OHC 250 engine.
They always drag in a crowd.
81' BMW R100 CS
Old 08-26-2013, 01:24 PM   #67
Krasniewski
I don't ride much.
Krasniewski's Avatar
Oddometer: 1,257
Cool thread! Thanks for all the pics.
I really like the tank. What's the capacity?
Krasniewski is offline   Reply With Quote
Old 08-27-2013, 03:33 AM   #68
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,886
The tank holds 9 Litres or 2 gallons. You can buy them separately from here to put on another tiny racer.
http://www.ooracing.com/store/index....wCat&catId=226
81' BMW R100 CS
Old 08-28-2013, 07:20 AM   #69
Sky Racer
Sky Racer's Avatar
Oddometer: 1
Hi all Im new to this group been looking at this bike and from what I have read here my mind is made up going to get one great info Just Dan
Sky Racer is offline   Reply With Quote
Old 08-29-2013, 12:25 AM   #70
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,886
They are great little project. Def, not in the same league quality wise as Japanese bike
81' BMW R100 CS
Old 09-06-2013, 04:20 PM   #71
Krasniewski
I don't ride much.
Oddometer: 1,257
(sorry for the hijack) Cool pics up here on the Facebook page:
https://www.facebook.com/avavelocityworks
I don't suppose a set of those legs come with the bike, do they?
Old 09-07-2013, 12:57 AM   #72
Kennon
Kennon's Avatar
Oddometer: 306
for CG125 based engines you can fit a 200cc kit I've heard of it being done to CG125's using a Chinese cylinder and piston
Kennon
2009 Yamaha Jog 50RR LC sold 2011
2011 Rieju Marathon Pro 125 SM sold 2013
1990 Honda VFR 400 NC30 purchased 2013
Kennon is offline   Reply With Quote
Old 09-08-2013, 06:20 PM   #73
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,886
I have posted on the AVA Facebook page asking. If AVA have fixed the brakes and suspension on their bikes with no reply.
As for fitting a 200 barrel and piston. I think it is way to much trouble. The 200 has different stroke to the 125. I am waiting for a company in China to get their act together and post me 150 cc barrel an piston.
I have been doing little things on the ACE. Tidied up the rear end by moving the indicators onto the main frame.
Used a shock bush as a cover on the kick starter.
Fixed the sidestand. It use to hang down at 45 degrees for some weird design reason.
The box is filling up of stuff removed from the ACE
81' BMW R100 CS
Old 09-08-2013, 10:34 PM   #74
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,408
good lord I love you aussie nutjobs.
really enjoyed the thread.
maybe you'll have a bit of a lark with the bike and if it grenades and pukes it's bottom end out you won't be heartbroken.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 09-09-2013, 01:27 AM   #75
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,886
I won't be heart broken at all it the engine grenades. The basics like the frame are really robust and can take a lot more HP than in its current form.
When the engine goes, most of us, will replace it with 250 OHC single. A few mutter about trying to find a Honda CRF150 engine.
81' BMW R100 CS
Just Dan screwed with this post 09-09-2013 at 06:55 PM
Times are GMT -7.   It's 07:56 PM.
