Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 07-13-2013, 03:29 PM   #1
littlefield OP
Oddometer: 119
Zumo 350/Mapsource
I'm having problems establishing communications between my Zumo 350 and notebook running Mapsource. When I try do download a route it can't find the GPS. Mapsource has 2009 non-NT version of CNNA. I have no problem communicating on another computer running Basecamp. I can see the Zumo in Explorer and Webupdater on the netbook. I have a feeling the USB driver is incorrect. I updated it off the Garmin website and it loaded it in another directory other than the one containing Mapsource.
Can somebody running Mapsource and the Zumo 350 tell be what version USB driver you're using and where in the directory it's located?
littlefield is offline   Reply With Quote
Old 07-13-2013, 04:20 PM   #2
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,169
Not what you want to hear, but use BaseCamp. The maps have changed since MapSource was current, and something about the way the roads are now segmented can be problematic if you make routes in MapSource with the newer maps. But, BaseCamp is free, so no worries.
Old 07-14-2013, 04:03 AM   #3
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,233
Have you updated Mapsource lately? Sounds like you may need a driver update for the new unit.
And you could have problems loading a route from Mapsource to the GPS due to differing maps on each unit.
Better to use Basecamp as it loads map data from the GPS.
dunno.....
Old 07-14-2013, 05:44 AM   #4
littlefield OP
Oddometer: 119
I don't know why I'm reluctant to load Basecamp on the netbook. Sounds like the easiest thing.
Old 07-14-2013, 03:46 PM   #5
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,169
On a netbook? They don't have much processing power, do they?
Old 07-14-2013, 04:06 PM   #6
Schrauberklaus
***ifyer
Schrauberklaus's Avatar
Oddometer: 385
Do you use the Garmin USB Cable ?
The Pinout is differnt to standart USB Cables .
Klaus
___________________________
Honda XL 600 R(S) 84 , Honda XR 600 Dual Carb. 87
Honda XR 280 R Sumo 04 , Honda XR 250 Baja 98
Yamaha Speed MX ( 2 Stroke ) 01 ,CRF250L 13
Schrauberklaus is offline   Reply With Quote
Old 07-14-2013, 06:50 PM   #7
250senuf
250senuf's Avatar
Oddometer: 2,407
Netbook or notebook?
I couldn't get Basecamp to load onto my netbook with a 32GB SSD. The failed install info wanted me to remove a bunch of .Net frameworks files. Didn't go there. I think the install failure has something to do with the write-leveling alogrithm for the SSD. I'm "making do" with Mapsource.
I do have Basecamp on the desktop which has a conventional hard drive.
Not all who wonder are confused
250senuf is online now   Reply With Quote
Old 07-14-2013, 06:56 PM   #8
littlefield OP
Oddometer: 119
I believe it's referred to as a netbook. Runs Windows XP, 1GB ram, pretty good sized hard drive, Intel Atom processor, 10" screen. Small package makes it easy to bring along. I got Basecamp to install and uploaded CNNA. Everything seems to work okay but I haven't tried to create and transfer any routes.
Old 07-14-2013, 10:58 PM   #9
Schrauberklaus
***ifyer
Oddometer: 385
I run Basecamp on Different Laptops and Desktops with HD and SSD Drives no Problem .
Guess you need min 4 GB Ram .
Making Routes in Mapsource or Basecamp and transfer to the Zumo 350 work (only with the Garmin USB Cable) but the Zumo 350 hang up and need a reset every 20 km if i try to follow the Route .
Making the Route direct on the Zumo work and that piece of Shit don't need a reset .
But that is not my only Problem . Will change to a Montana in near future
Klaus
Old 10-26-2013, 03:54 AM   #10
Remo76
Oddometer: 2
Hello,
I have the 350LM and am looking for maps for Japan, I'm stationed there and need maps. And suggestions would b appreciated.
Remo76 is offline   Reply With Quote
Old 10-26-2013, 03:57 AM   #11
Remo76
Oddometer: 2
MAPS of Japan for 350LM
Hello
I have a garmin 350LM and I'm looking for maps of Japan. I am stationed in Yokosuka and need maps please
Thank you
Brian
Times are GMT -7.   It's 08:55 PM.
