Old 07-16-2013, 01:24 PM   #1
Irish John OP
Oddometer: 228
Buzzing in transmission, TLR200
Out for a little ride last night on the Project TLR200. Coming home I noticed what I would describe as a buzzing in the transmission when down shifting through gears 3-2-1. Almost like the when being down shifted the shift fork was very lightly rubbing on a spinning gear. Anyone experience this before? Could it be the clutch is not disengaging fully? Shifts with no worries up through all 6 other gears and down from 6-3 with no problems.
Irish John is offline   Reply With Quote
Old 07-16-2013, 03:17 PM   #2
UtahGuido
UtahGuido's Avatar
Oddometer: 4,849
I'd keep that ebay link to the Lifan engine handy - you know, just in case.
Maybe change your oil?
Take up some slack in the clutch cable?
Maybe it's your chain making noise?
Otherwise, dunno.
God Bless Science.
UtahGuido is offline   Reply With Quote
Old 07-16-2013, 06:03 PM   #3
lineaway
Oddometer: 2,705
Did this happen after you changed the sprocket?
lineaway is offline   Reply With Quote
Old 07-17-2013, 09:33 AM   #4
Irish John OP
Oddometer: 228
Yes, I've changed the oil. No detectable slivers of metal. It did start after changing the front sprocket but the "buzz" is felt only when down shifting into 3-2-1. I've played with the slack in the clutch cable, no difference.
The bike runs great, but I'm beginning to get a sick feeling in my stomach that the tranny might be starting to self destruct.
Old 07-17-2013, 10:03 AM   #5
Twin-shocker
Oddometer: 1,673
The gearbox on the TLR is pretty much bulletproof. Have a careful look at how the gearbox sprocket is mounted, and you will most likely find its been rubbing on the cases.
Old 07-17-2013, 12:30 PM   #6
Irish John OP
Oddometer: 228
Roger that, check the simple things first. I'll pull the new sprocket off and see what happens.
Times are GMT -7.   It's 04:42 AM.
