Old 07-18-2013, 12:19 PM   #1
stimmer6253472 OP
stimmer6253472's Avatar
Oddometer: 366
help 2001 klr 650
I'm in Colorado on vacation and my KLR 650 won't start like it's completely dead. battery is okay but when I push the start switch nothing happens. please help.
2009 KTM 300 XCW
2007 KTM 990 Adventure
2003 KTM 300 EXC
2003 KTM 50 mini adventure (boys)
stimmer6253472 is offline   Reply With Quote
Old 07-18-2013, 12:21 PM   #2
ruppster
ruppster's Avatar
Oddometer: 881
If you have a voltmeter handy, things to check: Kill switch, side stand switch, and start relay.
15 KTM 690E, 05 KTM 450EXC
ruppster is offline   Reply With Quote
Old 07-18-2013, 12:40 PM   #3
East Coast Rider
Just Me...
East Coast Rider's Avatar
Oddometer: 3,965
Don't forget the clutch safety switch. Battery connections tight?
Txt msg with Dan right after he was paralyzed:
Me: Hey Dan-O. Just wanted to say howdy and Love ya!
Dan: Howdy and Love you too. Doin' good and feeling good.
Me: Give 'em hell, little Bro!
Dan: Roger that.
East Coast Rider is offline   Reply With Quote
Old 07-18-2013, 12:45 PM   #4
millahtime
Oddometer: 64
I'm with the other guys.
battery connections, side stand and clutch safety switch.
check here for the latter two.
http://www.klr650.marknet.us/Safety_Bypass.pdf
millahtime is offline   Reply With Quote
Old 07-18-2013, 12:58 PM   #5
stimmer6253472 OP
Oddometer: 366
it is an intermittent problem sometimes it works sometimes it doesn't. battery is okay because the lights work.
2009 KTM 300 XCW
2003 KTM 300 EXC
Old 07-18-2013, 04:23 PM   #6
RandoCommando
Wannabe
RandoCommando's Avatar
Oddometer: 1,408
I'm gonna bet it's the side stand switch sticking.
Remove the plastic cover and move the switch manually when it won't start.
You'll need to have the kick stand in the up position when you do this.
Might need to replace the cable or lube it up really well.
Or disconnect the circuit or remove the cable.
1999 KLR 650 (her name is KLaRissa) DOOHICKEY DONE!
2013 BMW F800GS (her name is FranGelicaS)
Please. Ride careful, ride safe, ride defensively! This thread should be mandatory reading!
MySPOT
RandoCommando is offline   Reply With Quote
Old 07-18-2013, 05:17 PM   #7
Grinnin
Forever N00b
Oddometer: 2,769
If it's the sidestand switch then it should still start when in neutral.
The neutral switch and clutch switch can prevent it from starting. If you have a neutral light then the neutral switch is working OK and it should start in neutral.
That leaves just about the rest of the electrical system.
I had a similar problem last week in Minnesota. For me it turned out to be the last inch of ground wire with an intermittent break. To find it I had to go over the electrical system bit by bit. For checking ground I took apart plugs, found the black-with-yellow wire, and looked for 0 ohms from there to the negative terminal. The fault being intermittent made it harder to find.
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin is offline   Reply With Quote
Old 07-18-2013, 06:21 PM   #8
ruppster
ruppster's Avatar
Oddometer: 881
I had that problem with my 93. Check the start relay connections and give it a tap with a wrench, mine acted like it was starting to get "sticky".
Old 07-18-2013, 07:43 PM   #9
augiedog
augie dog
augiedog's Avatar
Oddometer: 772
start problem
It is likley the start switch itself . turn the key on , be sure its in nutural, push the start button and wiggle it around alittle while pushing in on it. it should start. KLR's are prone to getting corrosion on the switch connector points. If this corrects the start problem you need to remove the housing and spray the switch contacts with something like wd-40.
augiedog is offline   Reply With Quote
Old 07-18-2013, 07:55 PM   #10
KustomizingKid
Oddometer: 678
Check the starter relay... If the rubber holder falls off (mine disintegrated) and the starter relay touches the metal bracket wrong it won't start. I have to lift mine up, anti theft device hahaha.
2000 Xr650r!
KustomizingKid is offline   Reply With Quote
Old 07-19-2013, 09:13 AM   #11
Kawidad
Kawidad's Avatar
Oddometer: 4,843
I had a similar problem with my 2000. I thought it was the starter relay and bought a new one. (I already got rid of the side stand and clutch switches.) Didn't solve the problem, then a mechanic buddy told me it was likely the starter motor itself. Over time they develop flat spots where the brushes don't make proper electrical contact. Tapping the starter motor briskly with a hammer got it going every time. However, the fix for me was a new starter motor.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 07-19-2013, 09:49 AM   #12
travelinggnome
TravelingGnome
Oddometer: 30
I had the same problem one afternoon and it was as simple as one of the leads (in my case it was the positive lead) to the starter motor having worked its way loose. I would start there as I spent hours fiddling with other things when all that was necessary was connecting one wire back to the motor.
travelinggnome is offline   Reply With Quote
Old 07-19-2013, 11:37 AM   #13
XDragRacer
Oddometer: 3,168
The clutch safety switch can lock out the starter; wiggling the clutch lever sometimes encourges it to straighten up and fly right.
Otherwise, a multimeter and this wiring diagram might be useful:
http://www.wiringdiagrams21.com/wp-c...ng-diagram.gif
XDragRacer is offline   Reply With Quote
Times are GMT -7.   It's 07:08 PM.
