Old 12-06-2013, 07:58 PM   #181
Travmoto
almost there...
Travmoto's Avatar
Oddometer: 221
looking good, got a finish eta yet?
Is that the stock front guard cut down? Looks nice and slim.
Travmoto is offline   Reply With Quote
Old 12-07-2013, 01:40 AM   #182
digga
Oddometer: 85
@ Violetpop
"That Sir, is coming along a treat"
Poise .... raising an eyebrow - not the roof.
Sex - the price women pay for Marriage.
Marriage - the price men pay for Sex !
digga is offline   Reply With Quote
Old 12-07-2013, 09:44 AM   #183
Dmaster
Dmaster's Avatar
Oddometer: 257
Originally Posted by violetpop View Post
Don't you think you have a up and down moving brake pedel when the rear wheel goes up and down?
And, is this a pushing system, looks like it but maybe i'm wrong?
Dmaster is offline   Reply With Quote
Old 12-07-2013, 11:50 AM   #184
violetpop OP
Oddometer: 174
You make an interesting first comment, something I'll have to look into.
Pushing system, I don't follow?
violetpop is offline   Reply With Quote
Old 12-07-2013, 12:06 PM   #185
Kai Ju
Kai Ju's Avatar
Oddometer: 1,895
pushing system
your brake rod is under compression when you actuate the brake, the way it's set up right now.
I'd strongly recommend you stay with the stock actuation, which is tension. The lever on the cam needs to be pointing down, not up.
The way it is right now you'll end up with flex in the rod unless you make it much bigger in diameter.
Kai Ju is offline   Reply With Quote
Old 12-07-2013, 12:22 PM   #186
violetpop OP
Oddometer: 174
Yes I get you... I only notice it was up. I will have to be in touch with the fab guys and make it spot on. Not an overly big job but must be correct.
Old 12-07-2013, 01:16 PM   #187
scarygary
Drawing blanks
scarygary's Avatar
Oddometer: 388
Nice looking bike!
scarygary is offline   Reply With Quote
Old 12-07-2013, 01:57 PM   #188
violetpop OP
Oddometer: 174
So this is the complications that arise with custom work I guess.
Old 12-08-2013, 11:57 AM   #189
Dmaster
Dmaster's Avatar
Oddometer: 257
Yes
Old 12-08-2013, 01:41 PM   #190
Kai Ju
Kai Ju's Avatar
Oddometer: 1,895
on second thought...
redesigning your rear brake actuation will be a bit of a chore.
Considering that most of your braking will come from the front I'd leave it alone for now.
Verify that you can't bend the rod by normal actuation with your right foot while sitting on the bike, i.e. normal riding position.
If it doesn't bend, see how well the rear brake works the first time you ride it and decide from there.
Kai Ju screwed with this post 12-08-2013 at 01:43 PM Reason: Because I never get it right the first time...
Old 12-08-2013, 04:07 PM   #191
violetpop OP
Oddometer: 174
I just spoke to them and were 100% aware of my concerns. They said they had thought about it and went on to explain something so technical that it went completely over my head. They also said they had a certain amount if adjustment that I would not cause a problem, everything was checked over and will work fine. I will have to take their word for now and test it at a later stage. I have faith!
Old 12-08-2013, 04:11 PM   #192
R100LT
Chasing 11
R100LT's Avatar
Oddometer: 631
Nothing better than road testing brakes
BMW R100LT 93 BMW R100RS 91 BMW K1100LT SE 94 76 R90S
R100LT is offline   Reply With Quote
Old 12-08-2013, 05:25 PM   #193
violetpop OP
Oddometer: 174
Agreed 100%
Old 12-08-2013, 05:33 PM   #194
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,580
...if they work. If they don't work, I can think of some things that are better.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 12-08-2013, 06:57 PM   #195
Kai Ju
Kai Ju's Avatar
Oddometer: 1,895
70-100 % of your stopping power comes from the front brakes....so you only have a 0-30 % of crashing because of the rear brake....
Times are GMT -7.   It's 08:57 AM.
