Old 07-22-2013, 03:37 PM   #1
jmurphy OP
Oddometer: 23
Throttle Lock / Cruise Control
What throttle locks are out there that fit a 2012 1200gs without having to remove the grip or make modifications.
jmurphy is offline   Reply With Quote
Old 07-22-2013, 03:53 PM   #2
jdmetzger
Lone Wolf
jdmetzger's Avatar
Oddometer: 3,217
I installed a Kaoko as my first accessory. Unscrew the bar end weight, install the Kaoko in it's place. Finished.
Not my image, but here you go:
Josh Metzger - Sterling, VA (with occasional stops in Toledo, OH)
1978 R80/7, 2013 R1200GS Adventure "90th Anniversary"
jdmetzger is offline   Reply With Quote
Old 07-22-2013, 03:57 PM   #3
RomaDakota
Illuminatus!
RomaDakota's Avatar
Oddometer: 1,421
Here are more ideas -
http://www.advrider.com/forums/showthread.php?t=821484
My opinion is buried in there
КМЗ Dnepr MT11 // КМЗ M72 // ИЖ Planeta 5 // КМЗ MV750 // Урал М63 // BMW R1200GS 30th
RomaDakota is offline   Reply With Quote
Old 07-22-2013, 04:11 PM   #4
TuonoBiker
Oddometer: 753
Bob's BMW sells their own house brand. I think it was around $60. They aren't as effective as normal cruise control, but wow are they nice on long days when you need to ride the slab for a few hours.
I'd NEVER use one on anything but the Interstate...even then traffic has to be just right...that's my opinion only, of course.
Bob's brand locks by rolling the lock-nut FORWARD. The Kaoko locks while rolling it backward as you accelerate. Much nicer, but again, for 60 bucks, it didn't matter to me. I was happy to save the money over the Kaoko. My friend bought the Kaoko for his Multi and it operates a little easier and smoother...but, again, not worth the extra money IMO.
'12 R1200GS Adventure
'06 Ducati 999S
'11 Harley Street Glide - gone and mostly forgotten
'07 Tuono Factory - gone but not forgotten
TuonoBiker is offline   Reply With Quote
Old 07-22-2013, 04:14 PM   #5
Norhasken
Tryin' to find my way
Norhasken's Avatar
Oddometer: 18,228
Kaoko easy and good. Fine to use anywhere but in the dirt.
"Life isn't much, but there's nothing else to do, La Dolce Vita"
Norhasken is offline   Reply With Quote
Old 07-22-2013, 04:24 PM   #6
Wdwrkr
Wdwrkr's Avatar
Oddometer: 1,852
I have the kaeko. I find it suffices my needs.. It a long way from cruise control as it takes some fiddling to get it to hold a consistent speed, but once you get it dialed in it does the trick... For the money it is worth it... If you are hoping for cruise control this isn't it though.. If that's what you really want I'd recommend a GSw.
My mind is the most dangerous neighborhood I ever enter
Wdwrkr is offline   Reply With Quote
Old 07-22-2013, 05:05 PM   #7
jmurphy OP
Oddometer: 23
Basically just looking for a throttle hand relief every now and then on a long super slab ride and didn't want to hack the grip to do it. I will check out Bob's BMW.
Old 07-22-2013, 05:23 PM   #8
Monsignore
Plunger Boy
Monsignore's Avatar
Oddometer: 901
Go Cruise is the way to cruise. Cheap & effective.
Ewig war ich.
IBA # 55612
Monsignore is offline   Reply With Quote
Old 07-22-2013, 05:49 PM   #9
mudmullet
mudmullet's Avatar
Oddometer: 196
big fat O-ring from Caterpillar is what I use on my 1150. It's yellow and matches my bike. Cheap, too.
mudmullet is offline   Reply With Quote
Old 07-22-2013, 06:10 PM   #10
HondoTX
Rode hard. Put up wet.
HondoTX's Avatar
Oddometer: 157
I had a Kaoko. Didn't like it because the lock ring contacted the grip directly. A slight touch of the grip would cause it to unlock and decelerate abruptly.
Bought a Bob's because it has a spacer between the grip and the lock ring. It snugs-up the grip so you can make minor adjustments to the throttle without unlocking.
Dave
Too many high-performance cars and low-performance drivers
URAL Patrol
BMW 200,000 mile award
Preston's Last Ride = http://hondotx.blogspot.com
HondoTX is offline   Reply With Quote
Old 07-22-2013, 07:13 PM   #11
TBaird
Oddometer: 38
Kruz Locker
I'm a big fan of the Kruz Locker. I wish I hadn't waited so long to install mine... It turns on quickly with only a quarter of a turn, and off even quicker.
Several vendors carry them such as black dog cycle works and advdesigns.
TBaird is offline   Reply With Quote
Old 07-22-2013, 07:27 PM   #12
LaurelPerryOnLand
Oddometer: 3,478
100 THREADS all GS/GSA owners should read.
http://advrider.com/forums/showthread.php?t=836736
58. HAS ANYBODY EVER INSTALLED 'CRUISE CONTROL' ON A GS?
http://advrider.com/forums/showthread.php?t=845862
http://www.advrider.com/forums/showthread.php?t=244690
http://advrider.com/forums/showthread.php?t=803459 (O-ring version)
http://www.mccruise.com/collections/bmw (McCruise)
LaurelPerryOnLand is offline   Reply With Quote
Old 07-22-2013, 07:52 PM   #13
Hikertrash
Oddometer: 2,766
+1
I had the Kaoko and hated having to turn it so much. The Kruz Locker is great and so easy to turn on and off.
Hikertrash is offline   Reply With Quote
Old 07-23-2013, 05:09 AM   #14
murfalert
Oddometer: 99
I'm a fan of the Go Cruise too. For $20 with easy install you can't beat it. I find it as effective as the Kaoka or Throttlemeister and easier to activate than both of those or the o-ring, and I've tried all. Personal preference I suppose. And I use mine a lot.
Murf
murfalert is offline   Reply With Quote
Old 07-23-2013, 06:36 AM   #15
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,524
Bob's is the same exact unit as the Wonderlich. The backwards rotation made using it a pain to me. It is unnatural to push it forward with your pinky and makes applying it a bit jerky and fiddly.
I sold it and got a Kaoko. Worth the extra $60 IMHO.
Jim
Times are GMT -7.   It's 09:45 PM.
