Old 07-27-2013, 10:29 AM   #31
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,265
Originally Posted by tonymorr View Post
The CBR250 engine is a HUGE let down. The WR250R engine is WAY better especially with a big bore kit. I already have one of them and it is a great light ADV bike.
Have a crf250l and wr250r in the stable, prefer the honda engine, yammy suspension.
I've got 98 husaberg 400 that the 300 would fit in nicely oh and it is tagged
What's the throttle body config on the 300? Seems to be the biggest challenge with a ptwin in single backbone frame.
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 07-27-2013, 03:53 PM   #32
tonymorr OP
Malta,NY(Saratoga Spring)
tonymorr's Avatar
Oddometer: 2,529
Dual throttle bodies. Pretty close together. I can't wait for the engine to get here. I'm going to be all over it with my tape measure. Can't do much till that happens.
2013 Multistrada 1200ST - 2013 Honda CB500X - 2014 Honda CTX700
2011 Husaberg FE 390 - 2014 Honda Grom "Napoleon" - 2014 Honda Grom "Lucy"
'07 Mutant Ninja II (sold)click for build report - 2008 Yamaha WR290R (sold-not sure why)
2013 Piaggio BV350 (sold)
tonymorr is offline   Reply With Quote
Old 07-27-2013, 08:43 PM   #33
Lutz
Killer Rabbit
Lutz's Avatar
Oddometer: 1,484
Add a scale to go along with your tape measure, please.
I'd personally like to see something along the lines of a trimmed down Weber Rally Twin...but whatever you decide to build....
Lutz is offline   Reply With Quote
Old 07-28-2013, 02:04 PM   #34
tonymorr OP
tonymorr's Avatar
Oddometer: 2,529
Starting to come around to the KTM frame idea. I'm hoping it's something I can make work. Looks like lots of room. no?
I have a buddy that is a superb welder. Maybe he could make up an airbox/aux fuel tank/subframe similar to what inmate DRjoe made
Since the wider engine would probably take up ALL of the space between the frame I would probably need something like this rally style low exhaust.
Which is fine because the oil pan is going to hang below the frame anyway.
Old 07-28-2013, 02:22 PM   #35
tonymorr OP
tonymorr's Avatar
Oddometer: 2,529
Originally Posted by Navin View Post
With a good seat and some fabrication luggage won't be a problem. Tanks up to 6.6g bolt on. You'll probably need an external fuel pump with whatever you get.
I was thinking external fuel pump as well, but..... If I use the '08> newer KTM frame I wander if I can get a tank for the injected bikes and use that internal pump. Second thought, might be better to source a readily available external pump. Something I could get in a hurry and on the road if need be. Hmmm
Old 07-28-2013, 07:35 PM   #36
Navin
Navin's Avatar
Oddometer: 8,337
There were guys running a common ATV fuel pump for retrofitted FI engines. Maybe a Polaris 650??? Yamaha something... Sorry, I know there was an option, I just can't remember the model it was from.
With some basic skills, the later tanks can probably work on an earlier frame. There are many 1990 up KTMs that have been brought up to date with later generation body parts, including tanks.
Navin is offline   Reply With Quote
Old 07-28-2013, 07:53 PM   #37
tonymorr OP
tonymorr's Avatar
Oddometer: 2,529
Thanks Navin. I'm glad you're here. This is going to be a lot easier with you around :-) BTW, we have a common friend. Chris aka:sportrider (Super10, KTM SMT, 400, etc). I guess he knows you from track days.
Old 07-28-2013, 07:59 PM   #38
Navin
Navin's Avatar
Oddometer: 8,337
Oh yeah, we met last year. Your upstate? I'm on the NJ border. I'll have to take a ride by and see your progress as it advances!
I'll try to grab you the measurements you want tomorrow, though I fear the fairings will block them pretty well. The Ninja 250 intake bells on the carbs are the same diameter/distance BTW. I'm running a 250 K&N pod filter with both TBs in one filter, 2 ports. They are pretty close together. You might squeak them in the rear frame loop of the KTM.
Did you find that KTM engine swap thread?
Old 07-28-2013, 08:01 PM   #39
Navin
Navin's Avatar
Oddometer: 8,337
Here it is in case you want to skim it a bit.
http://www.advrider.com/forums/showthread.php?t=757835
Old 07-28-2013, 08:03 PM   #40
tonymorr OP
tonymorr's Avatar
Oddometer: 2,529
I did. At least I think I did. Also found the thread on adventurizing a 525 EXC. So much info here.... :-)
Old 07-28-2013, 08:15 PM   #41
Navin
Navin's Avatar
Oddometer: 8,337
Here is a neat build going the other way. It'll just give you perspective as to how massive the old LC-4 engine was in case you found a donor frame from one of them. I'd only suggest this option if you are a bigger framed rider. These bikes were massive compared to the RFS or later EXCs. Super stout bikes though. I raced a 620SX a few years, strong and stable chassie. Adv 640 stuff should easily attach to these frames. Maybe a blown engine in one out there?
Old 07-29-2013, 08:14 AM   #42
4play
Next?
4play's Avatar
Oddometer: 2,600
I'd really like to see this work out in an RFS chassis. I would have to seriously consider doing this swap myself
Family isn't always about blood
4play is offline   Reply With Quote
Old 07-29-2013, 08:41 AM   #43
tonymorr OP
tonymorr's Avatar
Oddometer: 2,529
Just curious, why an RFS chassis? Is it because it is better? More abundant? Cheaper? Or simply because you have an extra one laying around? I'm not totally ignorant to KTM's but I'm not fully up to speed on chassis/suspension changes over the last few years.
Found this http://www.enduro360.com/2010/09/27/...tm-rfs-hybrid/
And this http://advrider.com/forums/showthread.php?t=662808
tonymorr screwed with this post 07-29-2013 at 08:51 AM
Old 07-29-2013, 08:56 AM   #44
4play
Next?
4play's Avatar
Oddometer: 2,600
I just happen to have a well sorted '07 RFS that gobbles up the nastiest terrain in comfort & handles so well it makes even me look like I'm a good rider. This rebuild already has 200hrs on it & I'll be looking at another complete rebuild in a year or so. Now that I have the mutant ninja finished & have experienced the smoothness of the twin, I would gladly trade a few KTM HP for that kind of smoothness in a package that handled as well as my KTM for some of my rides. I've considered a WRR but they weigh more than my 600cc (now) KTM & would need suspension & sorting out to handle the really rough stuff.
Old 07-29-2013, 09:31 AM   #45
jdrocks
Gravel Runner
Oddometer: 4,551
why not use the system matched OEM fuel pump?
jdrocks is offline   Reply With Quote
Times are GMT -7.   It's 01:25 AM.
