Old 07-29-2013, 11:07 AM   #46
tonymorr OP
Malta,NY(Saratoga Spring)
tonymorr's Avatar
Oddometer: 2,496
Originally Posted by jdrocks View Post
why not use the system matched OEM fuel pump?
Not sure it will work in the tank on the bike that I haven't even picked out yet :-) I have 3 chassis in mind right now.
KTM XC or RFS
DRZ/KLX400 (I like the idea of keeping it Kawasaki)
WR250R
2013 Multistrada 1200ST - 2014 Honda CTX700
2011 Husaberg FE 390 - 2014 Honda Grom "Napoleon" - 2014 Honda Grom "Lucy"
'07 Mutant Ninja II (sold)click for build report - 2008 Yamaha WR290R (sold-not sure why)
2013 Piaggio BV350 sold
tonymorr is offline   Reply With Quote
Old 07-29-2013, 12:44 PM   #47
Navin
Navin's Avatar
Oddometer: 7,658
Here is a "close enough" measurement of as much as I could get with the body in place. It might give you an estimate of what you are up against.
Width of the head, between 10-11"
TB outside to outside, including what I believe is the TPS, 7.25"
Overall height, top of head to bottom of pan, 21-22"
Overall length from tip of cylinder head to back of gearbox, 16"
Overall length from tip of oil filter to back of gearbox, 14"
Outside-outside of widest point of engine, 15", clutch cover to ignition cover. Both are offset, left front wider, right rear wider but 15" max.
Don't go chopping frame rails based on those measurements. I took them as best as I could get, lots of stuff in my way. The rear doesn't pass the swing arm pivot bolt thru the engine, that might make everything easier to line up.
Navin is offline   Reply With Quote
Old 07-29-2013, 01:24 PM   #48
tonymorr OP
tonymorr's Avatar
Oddometer: 2,496
Awesome! Thank you. Def gives a good starting point. My engine should be picked up today. Hoping I get it by the end of the week.
Old 07-29-2013, 06:44 PM   #49
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,242
Ahhhh hell!I'm in.Seems like a mongrel bike I'd be into.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 07-30-2013, 03:32 AM   #50
Rode2Nowhere
Rode2Nowhere's Avatar
Oddometer: 2,206
He's at it again.
I'll be sure to stop by and ogle the progress.
- Jonathan
'88/'96/'08/'09 KLR650 Amalgamation
IBA #45896
Adirondack Tags
Rode2Nowhere is online now   Reply With Quote
Old 07-30-2013, 12:29 PM   #51
tonymorr OP
tonymorr's Avatar
Oddometer: 2,496
Does anyone need a perfectly good running DRZ400 motor? Jetted carburetor? Header? Coil? Ignition module?
Old 07-30-2013, 12:40 PM   #52
Bluebone
straight to hell
Bluebone's Avatar
Oddometer: 2,527
hell yeah, i'm in!!
You can only be young once, but you can always be immature!
Bluebone is offline   Reply With Quote
Old 07-30-2013, 12:56 PM   #53
Rode2Nowhere
Oddometer: 2,206
No, but
- Jonathan
IBA #45896
Adirondack Tags
Old 07-31-2013, 05:31 PM   #54
tonymorr OP
tonymorr's Avatar
Oddometer: 2,496
Engine came today!
Stripped and weighed...
That's 91.8 lbs. I checked it with a second scale that said 92. Initial (inconclusive) research shows that the DRZ engine weighs 84 lbs. I don't know what state that is in. I'm going to look some more. http://www.thumpertalk.com/topic/803...g-a-drz-motor/
The wiring harness, the throttle bodies, and all of the magic boxes including the regulator weighed 9.2 lbs.
And just for reference the Ninja 300 frame stripped of everything but the kick stand weighed 36 lbs.
tonymorr screwed with this post 07-31-2013 at 05:38 PM
Old 07-31-2013, 06:50 PM   #55
Navin
Navin's Avatar
Oddometer: 7,658
Just for comparisons sake. I had my EXC530 engine shipped in a cooler, no carb, no shifter or kicker, dry after a rebuild. The whole thing, packed in a cooler was 92 lbs. This has to be within 7-10 lbs. of that engine considering the extra parts and the cooler/packing materials.
Not a bad starting point!
Old 08-01-2013, 10:05 AM   #56
MrBracket
MrBracket's Avatar
Oddometer: 256
Wow! you got more than just the engine... What a great package, may I ask how much you had to pay for that? If I remember correctly you got it on eBay right??
This is gonna be a great build, I can't wait to see it happen!
http://www.facebook.com/MotoMule http://www.moto-mule.com
2010 Husaberg FX450, 2011 Husaberg FS570, 1994 Yamaha TW200, Next bike?? - A twin cylinder adventure bike. Why? Because most thumpers sound like two skeletons making whoopie in a trash can!
MrBracket is offline   Reply With Quote
Old 08-01-2013, 11:21 AM   #57
tonymorr OP
tonymorr's Avatar
Oddometer: 2,496
Oh yeah, it's a plug and play engine. I wanted the Ninja frame in case the KLX frame is too far off. If I have to I can graft the two together.
$800 for everything shipped.
Ninja gauge cluster came today. I pick up the KLX tomorrow night. Then the fun begins!
** If anyone is thinking about trying this project send me a PM. The guy I got the gauge from has an engine for sale. He's in Cali. I think he could possibly be an idiot so I'm not going to vouch for him but I can say he is real. I paid him, he sent my stuff.
tonymorr screwed with this post 08-01-2013 at 11:26 AM
Old 08-03-2013, 02:01 PM   #58
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,560
Smokin' deal!
I'm assuming you got this through an individual sale, not through an eBay junkyard. Those guys are awful for this kind of project. If they could figure out how to sell each thread on a bolt separately, they would.
In for the build.
Suck, Squeeze, Bang, Blow
New Rider Training in the San Francisco Bay Area at Motorcycle University". Learn to Ride...Better!
Roadracer_Al is offline   Reply With Quote
Old 08-03-2013, 06:59 PM   #59
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,559
Ain't that the truth.
I've found Copart a great place to buy bikes like this. That's where I got the Ninja 650. It helps to bid on bikes in states where you don't need a dealer license. I paid $560 for mine OTD and it was a complete bike. Minus the front end laying on a pallet
There is a 2013 ninja 300 for sale in Pittsburgh Copart sale on 8/27 it appears. If anyone is interested, I'm local and have purchased form there before if you want a ADV inspection. With 252 miles on it I can only imagine...
http://www.copart.com/c2/homeSearch....SEARCH_RESULTS
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 08-03-2013, 06:59 PM   #60
BigPigDaddy
ADV Dreamin'
BigPigDaddy's Avatar
Oddometer: 20
This is going to be good. :)
Truth!
Micah 6:8
Don't infringe on my rights because someone else abused theirs!
BigPigDaddy is offline   Reply With Quote
Times are GMT -7.   It's 09:48 PM.
