Thread Tools Search this Thread Rating: Thread Rating: 66 votes, 5.00 average. Display Modes
Old 08-29-2013, 02:48 AM   #31
Myway OP
Myway's Avatar
Oddometer: 3,099
mount
i think you want it close to the bar.
http://www.advrider.com/forums/showp...&postcount=240
Myway is offline   Reply With Quote
Old 09-02-2013, 02:30 PM   #32
silli
Into SM
Oddometer: 24
I noticed that when I use iGo8 the map shows unpaved roads as brown lines. Not so with iGo Primo: unpaved or paved, it's all light yellow. The funny thing os it' the same exact map file. So the data is there but Primo's just that little bit more rough when visializing it.
Any clues on how to fix this? I tried all the color schemes That came with Primo to no avail. I could create one myself, but the format is cryptic enough to make it a good few hours iteration if doable at all.
silli is offline   Reply With Quote
Old 09-03-2013, 05:38 AM   #33
-Macca-
Oddometer: 79
Does this one charge via the cradle like the Peaklife one?
-Macca- is offline   Reply With Quote
Old 09-03-2013, 06:55 AM   #34
silli
Into SM
Oddometer: 24
Yes, it charges via the cradle.
Old 09-20-2013, 02:55 PM   #35
Myway OP
Myway's Avatar
Oddometer: 3,099
Does the Gstart menu work on the "rage".
By a friend it is on but not working properly, he said.
Someone else have the problems
Old 09-20-2013, 02:57 PM   #36
rpeter
rpeter's Avatar
Oddometer: 89
I haven't had any luck getting any other software running, besides the navigation program. This wasn't the case for the Peaklife, I had all sorts of stuff running on that.
rpeter is offline   Reply With Quote
Old 09-20-2013, 03:00 PM   #37
Myway OP
Myway's Avatar
Oddometer: 3,099
That should not be a problem, it is just a ce.
I do not have one here.
Maybe someone can explain how to install all.
Myway screwed with this post 09-21-2013 at 10:43 PM
Old 09-21-2013, 05:51 PM   #38
rpeter
rpeter's Avatar
Oddometer: 89
I wonder if you are using the same unpaved road settings in Primo as you were with iGo8. The Primo manual has this to say:
You can choose whether you want to use or avoid certain road types (page 74). However, when your software cannot avoid such roads, the route will include them and it will show them in a colour that is different from the route colour.
Old 10-06-2013, 07:53 AM   #39
Tickrr
Tickrr's Avatar
Oddometer: 23
How does the Rage compare to the Peaklife in terms of glare and visibility under the sun? Is it worth the upgrade?
Tickrr screwed with this post 10-06-2013 at 08:04 AM
Tickrr is offline   Reply With Quote
Old 10-06-2013, 11:57 AM   #40
Myway OP
Myway's Avatar
Oddometer: 3,099
A GPS contact wrote
The Rage is a beter model than the Peaklife, also the engineering is beter.
The screen is equal bad/good as the Zumo660, Montana is clearer.
The Holux 61cs is on the same level as Garmin
Only the update to a 4.3 screen is a step forwards.
Old 10-06-2013, 02:01 PM   #41
Tickrr
Tickrr's Avatar
Oddometer: 23
The screen is better because it's bigger? Or also because it's easier to read in the sun?
My situation is my bike was stolen with the wiring harness attached, as well as the RAM mount. So I can spend about $25 to replace those, or I can get a new, and possibly better unit for about $100 more.
Old 10-06-2013, 02:04 PM   #42
rpeter
rpeter's Avatar
Oddometer: 89
The larger screen is no easier to read in sunlight. My Rage has a thin plastic film over the touchscreen, and this film bows outwards on warm days. The result is it takes a good deal of pressure for touches to register. That's annoying. It's the only issue I have with the Rage so far.
Old 10-06-2013, 07:16 PM   #43
Tickrr
Tickrr's Avatar
Oddometer: 23
Thanks, that's good info. I'll probably stick with the Peaklife then. If I ever do upgrade it will probably be more substantial.
Old 10-06-2013, 09:48 PM   #44
Myway OP
Myway's Avatar
Oddometer: 3,099
I think when you used to ram mount, you probably will have this again if you wanted the "rage".
more substantial?
Then you thinking of a waterproof sunlicht readbele tablet, with handelbar remote.
Old 10-10-2013, 02:11 AM   #45
Myway OP
Myway's Avatar
Oddometer: 3,099
http://www.adventurebikerider.com/fo...s-systems.html
SEE IT!
Times are GMT -7.   It's 12:26 AM.
