Go Back   ADVrider > Fluff > Shiny Things
Old 07-30-2013, 04:14 PM   #1
TUCKERS OP
the famous james
TUCKERS's Avatar
Oddometer: 12,188
TDI cuts out momentarily
1999 VW New Beetle TDI:
Cut out three times recently on the freeway for just a split second.
Today cut out twice in town, completely. But restarted after a few minutes.
Besides overhauling the manufacturers mom, what can I do?
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is online now   Reply With Quote
Old 07-30-2013, 04:15 PM   #2
RedShark
Oddometer: 1,514
Fuel filter. My 2006 would cut for brief moments under full-load throttle at one point. Changed the filter and not since.
RedShark is offline   Reply With Quote
Old 07-30-2013, 04:16 PM   #3
Denis
Denis's Avatar
Oddometer: 675
TDIClub forum has all your answers.
Denis
Enjoy every sandwich!
Denis is offline   Reply With Quote
Old 07-30-2013, 04:16 PM   #4
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 9,040
Air in the fuel after cracking the T fitting while changing the fuel filter.
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 07-30-2013, 04:19 PM   #5
marty_uiuc
moran
marty_uiuc's Avatar
Oddometer: 293
could be bad fuel... did you recently refill at a station you don't normally use? my family had a '99tdi and ended up having to have it towed and the tank drained because of a similar symptom to yours. the car finally just straight up died and wouldn't restart. the problem turned out to be bad fuel from a shitty gas station.
another thing to look in to is how dirty the intercooler and charge piping is. ours had to be cleaned every few years due to oil vapors/sludge/whatever building up in the intercooler and piping. in the end we had to completely tear apart the charge piping and clean it all out due to it getting partially clogged.
the D in your DEMOT
marty_uiuc is offline   Reply With Quote
Old 07-30-2013, 04:51 PM   #6
TUCKERS OP
the famous james
TUCKERS's Avatar
Oddometer: 12,188
H'mm? Should be good fuel, same station for over a year.
TDI forum says 109 relay (fuel pump power)
I ordered two from iDparts.com $12 a piece. As iirc this is an ongoing problem since the VW Rabbit days. Carry a spare.
The Mrs Tucker is out in the car now, I do hope she gets home! It quit on her twice!
Old 07-30-2013, 05:25 PM   #7
Xeraux
Archvillain
Xeraux's Avatar
Oddometer: 30,892
Wait.
These things actually have problems?
Every saint has a past and every sinner has a future.
If, after I depart this vale, you ever remember me and have thought to please my ghost, forgive some sinner and wink your eye at some homely girl.
Xeraux is offline   Reply With Quote
Old 07-30-2013, 05:30 PM   #8
eatpasta
Lawnmower Target
eatpasta's Avatar
Oddometer: 10,944
Denis
and then some. and then s'more
We shall not cease from exploration, and the end of all our exploring will be to arrive where we started and know the place for the first time.
T. S. Eliot
Originally Posted by Burnszilla
I was SO high, I could have hunted duck with a rake
Originally Posted by VxZeroKnots View Post
MX stuff isn't my cup of tea, but falling down the side of a mountain is
eatpasta is offline   Reply With Quote
Old 07-30-2013, 08:16 PM   #9
TUCKERS OP
the famous james
TUCKERS's Avatar
Oddometer: 12,188
Oh yea, they can be problematic.
I've replaced all wheel bearings and both transaxles.
The electric fuel flap doesn't work.
The electric windows are getting slow.
The running lights now don't work.
I don't care for the 'screw in' brake caliper pistons, it's a special tool to change brake pads.
The electrical system in general on this New Beetle is third rate, very cheap and clunky door locks.
The underpan cardboard engine cover is crap.
it does 48 mpg constantly though and runs like a striped ape.
Old 07-31-2013, 04:32 AM   #10
ragtoplvr
Oddometer: 6,602
Diesels and cars with direct injection need a closed crankcase ventilation filter. There are vapors that condense in the intake tract and then set up, they can plug it. Gasoline port injection the additives in the gas take care of this. Diesel and direct injected gas have dry intake, and the stuff really builds up. You will need to clean the filter every oil change.
Rod
ragtoplvr is offline   Reply With Quote
Old 07-31-2013, 08:02 AM   #11
soldierguy
Location: California, sometimes the coast, sometimes Tahoe
Oddometer: 492
Interesting comment on the PCV filter. I just bought a car with direct injection and a turbo (Mazdaspeed3) and was thinking about something like a Mann/Provent filter for the PCV. Thing is, those are kind of large, and there's not much room under the hood because Mazda put lots of bits in plastic boxes under the hood, and because of the giant intercooler sitting on top of the engine. Looks like it'll be a pain to work on, but good gawd the Speed3 is just bonkers!
Back to the OP's issue though. I used to have a '96 Jetta GLX. It cut out for a split second every once in a great while...never found the cause, but I always suspected a loose/corroded electrical connection somewhere. Might be worthwhile to check every wire and cable to see that they are connected snugly and that the connectors are clean.
soldierguy
'13 Yamaha Super Tenere - my dream bike
soldierguy is offline   Reply With Quote
Old 07-31-2013, 10:17 AM   #12
TUCKERS OP
the famous james
TUCKERS's Avatar
Oddometer: 12,188
Well the Mrs got home. I'm going to check all the connections and when the 109 relay comes I'll replace that and keep a spare in the glove box.
I have a bad feeling it's going to stop and not start at all, probably on a cold rainy night whilst we are running to the hospital to visit our daughter having her baby!
Old 07-31-2013, 10:39 AM   #13
eatpasta
Lawnmower Target
eatpasta's Avatar
Oddometer: 10,944
Just get a new one!
T. S. Eliot
Old 07-31-2013, 10:45 AM   #14
TUCKERS OP
the famous james
TUCKERS's Avatar
Oddometer: 12,188
Originally Posted by eatpasta View Post
Just get a new one!
Love the new one......is it diesel...........
Old 07-31-2013, 10:47 AM   #15
soldierguy
Oddometer: 492
They are available in diesel, but I think I'd like the turbo gasser better. Love engines with hair dryers!
soldierguy
Thread Tools
Times are GMT -7.   It's 07:04 PM.
