Old 07-30-2013, 05:02 PM   #1
silverdog OP
silverdog's Avatar
Oddometer: 572
Triumph scrambler hacked?
Anyone hack a newer Triumph scrambler?
Any opinions, ideas, advice, bad idea,enough power, torque ???
Thanks...
silverdog is offline   Reply With Quote
Old 07-30-2013, 07:08 PM   #2
Mastercylinder
Mastercylinder's Avatar
Location: The Western Frontier,w/of Nevada,but just barely.
Oddometer: 105
Thanks...
Yes. Had Jay at DMC hack my 2013 Scrambler. Can't post pics here, (but I have posted some pics over at CURD forum). Depends on what you what to do with it. I wanted something for camping with the dogs. The power is sufficient to roll down the hwy. at speed, but like all boxed vehicles, headwind is a speed reduction factor. The Scrambler provides enough torque, but like some people more power is better. I like what Jay did. Very nice hack. That being said, the way the hack bottom brackets are installed and the way the triple tree raked out the front fork, cuts away some ground clearance. About one and a quarter inch.
I don't have any regrets when I see that my dogs are enjoying it. Hopes this helps.
The Moon is mine, not Felix's!
Mastercylinder is offline   Reply With Quote
Old 07-30-2013, 08:33 PM   #3
silverdog OP
silverdog's Avatar
Oddometer: 572
What hack did you put on?
Think a different hack would get you the ground clearance?
Happy with the handling?
Riding a ural now so the triumph probably seem like a powerhouse..
Thank for the info....
Old 07-30-2013, 08:55 PM   #4
FirstPath
FirstPath's Avatar
Oddometer: 2,304
Send Motoblag a PM. He has a Scrambler/Velorex combo.
http://advrider.com/forums/member.php?u=79384
Scott
'12 DR650
FirstPath is offline   Reply With Quote
Old 07-31-2013, 02:32 AM   #5
SwampFox883R
SwampFox883R's Avatar
Oddometer: 377
Anyone hack a newer Triumph scrambler?...
This couple from New Mexico are well traveled on their Scrambler/Velorex rig, and they rode right along with Ural rigs on East Texas county dirt roads during the 2012 Caddo Lake sidecar rally:
SwampFox883R is offline   Reply With Quote
Old 07-31-2013, 07:18 AM   #6
Mastercylinder
Oddometer: 105
silverdog
I had a Ural too. 2 to be precise. Tough as nails those Urals, but a tad too slow. Took a lot of long trips with the Patrol and never had any serious problems.
The sidecar is a M72D, (the one that looks like the Ural's), and the clearance has nothing to do with the sidecar, (a lot of clearance), but the bottom mounting brackets. Jay made sure the sidecar was attached securely. He came across and under both bottom frame rails of the Scrambler and secured the hack to both the right and left frame rail. Very secure. No welding. The brake line to the sidecar is a quick release, (attached to bike's rear brake line), and the electrical is a plug, so you can detach the sidecar from the bike without any problems. The handling is very good. So far going down the road at speed hasn't been an issue. I've cruised at 70 very smoothly. No problems. I have experience slow speed wobble, ( less than 10 MPH), but not an issue if you're ready for it, (had the same thing happen to me with the Ural, even with the steering dampener adjusted). There are a few things I've read about how to solve this, but haven't try them yet.
Again, hope this helps.
Mastercylinder screwed with this post 07-31-2013 at 09:13 AM
Old 07-31-2013, 07:51 AM   #7
jaydmc
Oddometer: 1,066
For what it is worth, We have made a new front lower mount design that does not cut into any of the ground clearance. Every thing is still 100% bolt on. We have a batch of the triple tree's in the works that should be done in about 3 weeks, all but one of this batch is sold.
We do a lot of the Triumphs, we have two new T-100's in the shop right now.
Jay G
DMC sidecars
www.dmcsidecars.com
866-638-1793
jaydmc is offline   Reply With Quote
Old 07-31-2013, 09:16 AM   #8
Mastercylinder
Oddometer: 105
Jay G
DMC sidecars
www.dmcsidecars.com
866-638-1793
Jay
Do you have any pics of this new front mount on a Triumph Classic? Please post if you do. Might want to change ours out if this is better.
Old 07-31-2013, 06:59 PM   #9
Motoblag
Replacing skill with will
Motoblag's Avatar
Oddometer: 394
I've responded to his post in the Scrambler thread in Beasts.
Also the Velorex has been gone for a while, replaced with a Dauntless tub.
Motoblag is offline   Reply With Quote
Old 08-01-2013, 06:46 AM   #10
DirtyDR
Dana
DirtyDR's Avatar
Oddometer: 2,530
This was down at Sipapu last year, pretty sure it is the same rig as above.
06 Ural Patrol
03 R1150 GS Sport/ Friendship II
94 R1100RS
99 Rokon Ranger
71 Rokon RT140
Hack'n the TLH
http://www.advrider.com/forums/showthread.php?t=592860
http://dirtydr.smugmug.com/
Proud Member of the Patrol Patrol
DirtyDR is offline   Reply With Quote
Old 08-01-2013, 07:08 AM   #11
RedMenace
Adventure Sidecar
RedMenace's Avatar
Oddometer: 5,269
Mileage?
what sort of fuel economy, range from a tank are you guys getting with the hacked scramblers? Matt, did you see a drop in mileage when you switched from the Velorex to the DMC?
" I need to stop talking and start drinking" ...Mom
RedMenace is offline   Reply With Quote
Old 08-01-2013, 07:52 AM   #12
RidingDonkeys
Purveyor of Awesome
RidingDonkeys's Avatar
Oddometer: 8,922
I'm pulling in the 30's with a hacked Bonnie. Normally around 33mpg.
Plenty of power and all day comfort. I ride it more than any bike we own. If it were to get stolen today, I'd be buying another tomorrow. No questions asked.
Sit Stay Ride: The Story of America's Sidecar Dogs
More info at www.sidecardogs.com
Clinging to sanity, one motorcycle at a time.
RidingDonkeys is offline   Reply With Quote
Old 08-01-2013, 04:30 PM   #13
silverdog OP
silverdog's Avatar
Oddometer: 572
How's first gear,low enough? Did you gear down?
Old 08-01-2013, 05:09 PM   #14
JustKip
JustKip's Avatar
Oddometer: 4,661
Speaking of modern Bonnevilles; what did they do about the spoke problem they were having? A friend has an '07 I can get for a very reasonable price, but it has a broken spoke right now (and I wonder how long till more break?)
JustKip is offline   Reply With Quote
Old 08-01-2013, 07:11 PM   #15
RidingDonkeys
Purveyor of Awesome
Oddometer: 8,922
1st gear is just fine. No changes in gearing at all.
Also, not a single spoke issue. I haven't run into anyone with that problem yet either.
Times are GMT -7.   It's 09:13 AM.
