Old 10-29-2013, 02:49 AM   #61
argo1974
Oddometer: 21
Justin, please give me an email: argo1974(at)hot.ee
argo1974 is offline   Reply With Quote
Old 10-29-2013, 04:35 AM   #62
Pardee
Oddometer: 9
Yamaha TX750 starter clutch mod!!. OH YA!!
Argo,
Email has been sent: justinpardee {at} hotmail {dot} com
Thanks,
Pardee is offline   Reply With Quote
Old 11-01-2013, 04:08 PM   #63
TonyAus
Oddometer: 5
Starter clutch sprocket new dimension request
Hi there everybody. I am a new member, but long time fettler of a TX750. I am wondering if someone could give me a brand new starter clutch sprocket diameter dimension for where the one way clutch runs.
My TX750 sprocket is 41.90mm and I suspect it is a little worn.
Thanks very much, Tony
TonyAus is offline   Reply With Quote
Old 11-01-2013, 07:13 PM   #64
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,412
Welcome!
I have a new one squirrelled away in the original paper... somewhere, as long as you're not in a hurry, I can get that number for you.
Old 11-02-2013, 12:23 AM   #65
TonyAus
Oddometer: 5
Thanks very much Concours.
Old 11-02-2013, 07:07 AM   #66
CalsXS2 OP
CalsXS2's Avatar
Oddometer: 138
Hey Concours,, are those Avon roadriders. What size did you go with.
Originally Posted by concours View Post
Welcome!
72 Yamaha XS650
73 Yamaha TX750
82 Suzuki GS650 G
CalsXS2 is offline   Reply With Quote
Old 11-02-2013, 04:48 PM   #67
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,412
120/90-18 and 100/90-19 Roadriders, handles great, better than my Commando
concours screwed with this post 11-03-2013 at 06:22 AM
Old 11-03-2013, 09:29 AM   #68
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,412
and I think I have a tread seam separation issue here..
Old 11-03-2013, 11:37 AM   #69
CalsXS2 OP
CalsXS2's Avatar
Oddometer: 138
OH MY!! That's not good.
Have you contacted Avon about it.
There was another problem with Avon sidewall's cracking. It was in the Suzuki GS community. But it seemed to be a certain size that had the problem.
My particular Suzuki took a different size than those that was having the problem. I've had no issue's with mine.
Now I'm afraid to put them on my TX since obviously your having problem's.
How did it turn out.
72 Yamaha XS650
73 Yamaha TX750
82 Suzuki GS650 G
Old 11-03-2013, 05:02 PM   #70
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,412
Got it on both the 18", and the pizza cutter 19" on the back of the Norton. It hasn't bothered yet. I didn't contact Avon, quite frankly, because my days are so full, and I reaaly can't bear to listen to some punk tell me I must have run it under inflated, over loaded or too fast. It hurts, I have to save my self for bigger fights, lol
Old 11-04-2013, 12:53 PM   #71
TonyAus
Oddometer: 5
XV250 starter clutch upgrade.
Hi Concours, I received some feedback from a parts distributor that the dimension is 42.17mm.
I am going to try the XV250 starter clutch upgrade to my TX750. With a new TX750 sprocket, I should be fine. While the XV250 sprocket is an overall larger diameter, it is the same dimension as a TX750 sprocket where the starter clutch runs, so I feel confident that the XV250 starter clutch will work with a TX750 sprocket, and the XV250 one way clutch fits snugly inside the TX750 flywheel.
I'll drill some new holes similar to what Argo has done with his Borg Warner clutches.
Old 11-04-2013, 02:33 PM   #72
TonyAus
Oddometer: 5
Aged NOS tyres
Hi Concours, not to hijack this thread with tyre talk, but your tyres look like new stock that has been sitting for a long time on the Dealer's shelf. You have probably made this assessment yourself. Out of curiosity what is the date code on the tyres? They might be quite old.
Old 11-04-2013, 05:30 PM   #73
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,412
Cool! Pics please!!
Old 11-04-2013, 05:43 PM   #74
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,412
Hi Tony, Not sure how you arrive at that... I bought the tire from Motorcycle Superstore in spring 2010, the bike is stored indoors except for when it's being ridden. Here's is the sidewall info. What do you think?
Old 11-14-2013, 04:29 PM   #75
appiebroomer
Oddometer: 36
Date code
The tire was made in the 38th week of 2009 (3809). Not that old.
appiebroomer is offline   Reply With Quote
Times are GMT -7.   It's 07:33 PM.
