Old 08-05-2013, 03:11 PM   #1
MustHaveRM250 OP
Steve
MustHaveRM250's Avatar
Oddometer: 25
Question What To Do
I bought an 85 RM250 thats been sitting 10-15yrs, Would it be ok to try to start it or what should I do first ? The top half was rebuilt before it was stored in a garage. Look's like it just came off the showroom floor, only gave $450 for it. Replys would be greatly appreciated. Thanks
MustHaveRM250 screwed with this post 08-05-2013 at 05:13 PM
MustHaveRM250 is offline   Reply With Quote
Old 08-05-2013, 05:14 PM   #2
Yooper_Bob
Yooper_Bob's Avatar
Oddometer: 2,875
Start with the basics:
Change all fluids.
Fresh fuel.
New spark plug.
Grease everything.
Check that all cables work freely.
Kick that puppy over and see if she'll start.
New tires/tubes should be next.
Yooper_Bob is offline   Reply With Quote
Old 08-05-2013, 05:25 PM   #3
MustHaveRM250 OP
Steve
Oddometer: 25
Another issue
The Clutch is sticking it wont engage either, dont know if it will free when I fire it up.
Old 08-05-2013, 05:34 PM   #4
Firemanmike69
Firemanmike69's Avatar
Oddometer: 125
Change all fluids.
Fresh fuel.
New spark plug.
Grease everything.
Do this. Only thing I'd do different is kick it over real gentle first to make sure nothing seized
Firemanmike69 is offline   Reply With Quote
Old 08-05-2013, 05:43 PM   #5
trailer Rails
trailer Rails's Avatar
Oddometer: 4,869
Probably needs a new cable.
Check the air filter, they have a way of dissolving and getting sucked into the carb, don't ask how I know.
trailer Rails is offline   Reply With Quote
Old 08-05-2013, 05:44 PM   #6
MustHaveRM250 OP
Steve
Oddometer: 25
it is free
Old 08-05-2013, 06:01 PM   #7
MustHaveRM250 OP
Steve
Oddometer: 25
cable is good
Old 08-05-2013, 06:10 PM   #8
Benesesso
Benesesso's Avatar
Oddometer: 9,898
How do you know it won't engage? It was probably engaged all the time it was sitting.
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 08-05-2013, 06:16 PM   #9
joexr
Oddometer: 3,773
I assumed he meant disengage. It's probably engaging , but without a chain.
Old 08-05-2013, 06:25 PM   #10
MustHaveRM250 OP
Steve
Oddometer: 25
it will free up i think
Old 08-05-2013, 06:31 PM   #11
MustHaveRM250 OP
Steve
Oddometer: 25
may need a new one
Old 08-05-2013, 06:38 PM   #12
rufus
We're burning daylight...
rufus's Avatar
Oddometer: 4,270
Replace the air filter, it WILL be rotten. Drain and replace all gas and oil. Put in a new spark plug, and then try to start it.
Most likely the crank seals will need to be replaced. Electrical connections could be corroded. There could be rust on the flywheel and corrosion where the stator plate bolts to the motor.
It shouldn't be to hard to get it running. But you will most likely need to replace ALL gaskets and seals in the motor.
If you get it running, ride it for a bit with the clutch lever pulled in. Blip the throttle and the clutch plates should free up.
rufus is online now   Reply With Quote
Old 08-05-2013, 06:43 PM   #13
rufus
rufus's Avatar
Oddometer: 4,270
The most obvious thing that it WILL need is the carburetor cleaned.
Old 08-05-2013, 06:49 PM   #14
MustHaveRM250 OP
Steve
Oddometer: 25
and if it dont drip oil will it be ok
Old 08-05-2013, 06:52 PM   #15
MustHaveRM250 OP
Steve
Oddometer: 25
so if no driping it will be ok
Times are GMT -7.   It's 07:26 PM.
