Old 08-06-2013, 04:54 AM   #1
arcanum OP
Oddometer: 316
Removing truck wheel with locking lug nut
My BIL died recently,and I am fixing his truck to sell,a '94 Dodge with alloy wheels. My main task is replacing the brakes. While doing so,I noticed that the PO to Tom must have removed a wheel by drilling around a locking lug nut with a drill bit and breaking the alloy wheel recess out. some of the other wheel studs are damaged and I figure that that also might have been related to the same issue.
I am wondering if any of you have ever had to remove a locking lug nut after you lost the key? How did you do it,or how would you do it? It seems like drilling the stud out would be the way to do it,but what do I know?
BTW,the brake job went well.Replaced both calipers ,one rotor,and new pads and rear seals for the bearings. Re-packed the bearings.
The rotor on one side had huge divots an the rear side and had turned a pretty shade of blue.
Found a new wheel at a local scrap yard,and the net price was $30.00 for the thing after he bought back the old wheel for the metal content Everyone else wanted $100.00 to sell me a wheel. The same guy turned the good rotor for $5.00. And de-mounted /mounted the tire for another $5.00
arcanum is offline   Reply With Quote
Old 08-06-2013, 04:58 AM   #2
anotherguy
anotherguy's Avatar
Oddometer: 6,356
Weld a large nut to the locking nut. Then remove it.
you don't see luggage racks on a hearse..........act accordingly
Old 08-06-2013, 05:26 AM   #3
mcma111
mcma111's Avatar
Oddometer: 12,265
There are sockets with a reverse twist that you use with an air impact gun. The ridges of the twist grab the locking lug nut and spin it out. Easy-Peasy.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 08-06-2013, 05:32 AM   #4
ohgood
ohgood's Avatar
Oddometer: 2,804
I like the way you talk
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is online now   Reply With Quote
Old 08-06-2013, 05:39 AM   #5
gravityisnotmyfriend
gravityisnotmyfriend's Avatar
Oddometer: 1,470
Most auto parts stores sell a locking lug nut remover. Which is why locking lug nuts are pretty useless.
Not sure why the video won't embed. Here's the link:
http://youtu.be/LGpuFwEKpUM
gravityisnotmyfriend is offline   Reply With Quote
Old 08-06-2013, 05:42 AM   #6
Auto-X Fil
Oddometer: 661
Yep, I've done this. Piece of cake.
Auto-X Fil is offline   Reply With Quote
Old 08-06-2013, 06:42 AM   #7
mjydrafter
evil boy for life
mjydrafter's Avatar
Oddometer: 4,155
Get an impact socket that is slightly smaller than the OD of the lock, pound the socket on to the lock and spin it off. Punch the lock out of the socket in a vise.
1974 Suzuki TC-185 (The little 10 speed)
1986 BMW K75c
Yes! Whenever bicycles are broken, or menaced by International Communism, Bicycle Repair Man is ready!
mjydrafter is offline   Reply With Quote
Old 08-06-2013, 01:26 PM   #8
wmako
bored in NJ
Oddometer: 627
Air Chisel
I have worked them around with an air chisel. Probably could be done with a chisel and hammer with enough patients.
wmako
RRMC
1979 CX500
1990 DR350
Ride Reports
Wmako's moped army rides from Jersey to Una-F'n-dilla (August 2010)
wmako is offline   Reply With Quote
Old 08-06-2013, 03:41 PM   #9
troidus
Oddometer: 14,663
I once had to remove an overtightened rounded off standard lug nut that was in a recess. I'd read that you could remove the other four and just break off the stud, but whoever did that must have been some kind of gorilla. Anyway, I ended up drilling out the stud until the lug nut separated, then drove out the remainder and installed a new stud and nut. A hardened, closed-end nut would have been harder to drill through, but an air chisel might fracture one of those.
troidus is offline   Reply With Quote
Old 08-06-2013, 07:30 PM   #10
rdrce698
Oddometer: 199
Split it down the middle with a cut off wheel then split it with a tapered chisel. Worked for me
Pete
rdrce698 is offline   Reply With Quote
Old 08-07-2013, 07:18 AM   #11
arcanum OP
Oddometer: 316
Ok,here's the situation as of now.
Even though I replaced the front brakes ,installed by someone who obviously did not care, now the rear lug nuts will not come off. By not come off,we are talking about a 3/4' Ingersoll Rand Air Impact. At least 500 Ft Lbs. What the hell kind of air wrench monkey tightened those things??? The rear drum brakes are making a dragging noise. No way am I gonna sell a truck with that issue.
Once you hammer long enough,the chrome cover on the fancy smanchy lug nut spins free and then still no dice on the remaining lug nut. I do have a spiral damaged nut remover set, but do not have the correct size to bite the nut.
Since my wheel has a recess, I will go with Troidus' suggestion to drill out the stud. I was already able to determine that a decent drill bit is hard enough to drill out the stud by doing a small test hole. I plan to use only quality drill bits to complete the job as a broken bit would be a disaster.
Thanks again,will report back in a week or so when I have the chance to work on it again
Old 08-07-2013, 09:13 AM   #12
Mrmerlin
K1300S fast as shi..
Mrmerlin's Avatar
Oddometer: 335
Any chance the nuts are unscrewed CW as opposed to CCW,
it wouldnt be the first time this has happened
Mrmerlin is online now   Reply With Quote
Old 08-07-2013, 12:07 PM   #13
troidus
Oddometer: 14,663
Originally Posted by Benesesso View Post
The nuts were probably installed dry and now they're rusted on. I always lube them with synthetic grease.
I use silver anti-seize.
Old 08-07-2013, 03:33 PM   #14
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,938
If the truck is a Dodge 1/2-ton pickup, then the lug nuts were 3/4" across the flats with the tin covers. Without, they're 18MM, and can be a real first-class bitch to get off with either a 19MM or 3/4" socket. Get ahold of an 18MM impact socket and give it another go.
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Old 08-07-2013, 06:40 PM   #15
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,014
Originally Posted by Bigger Al View Post
the tin covers.
What a great idea THOSE things were.
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Times are GMT -7.   It's 06:24 PM.
