Old 08-06-2013, 02:36 PM   #1
WU7X OP
The Old Fart
WU7X's Avatar
Oddometer: 1,994
Heidenau K60 for rear tire
Sitting here blowing smoke rings with that new Washington state approved "tobacco" and started thinking about rear tires for hacks. I know, what a waste of good smoke. Anyway, does anyone have any experience using a Heidenau K60 rear tire on their hack? How is it wearing? Good enough grip? any comments at all to share with the deserving?
p.s. just kidding about the "tobacco".
"Seika" - 2013 DL650 + DMC M72D Sidecar
"Gracie" - 1983 R100RT 60th Anniversary Edition
"Dusty" 2011 Adventurized 4Runner
Adventure is worthwhile." ~ Aristotle
Airhead #14449
WU7X is offline   Reply With Quote
Old 08-06-2013, 05:52 PM   #2
Tom48
Tom48's Avatar
Oddometer: 433
I have K37 on my 06 Patrol. With 3k the front tire is cupping and the rear tire is wearing and the sidecar is nearly new
I ride it in mud and the tires are great
Thomas Sells
Tom48 is offline   Reply With Quote
Old 08-06-2013, 09:09 PM   #3
hahnda
hahnda's Avatar
Oddometer: 142
I use a K60 on the rear of my Guzzi sidecar rig, I also use it on the front. 2500 miles on the tire as a solo bike and 1000 miles as a rear hack tire so far. Still has lots of tread left. Tire wear will vary quite bit from rig to rig.
Lots of grip with the tire on my Quota. I actually wish it would slip a little in the corners.
www.scramblercycle.com
Vintage Cycle Sales & Service
Sidecars & Installation
Heidenau Tires
hahnda is offline   Reply With Quote
Old 08-06-2013, 09:36 PM   #4
MIXR
MIXR's Avatar
Oddometer: 662
Good tyre
Ran front and rear K60 for 9,000 kms or therabouts. Seemed good. Better grip on smooth marble dirt, but moost was on tarmac. Ok in the wet. It's only a tyre. It will will wear out fast enough if you don't like it.
And so ends my 'Adventure' era (SOLD)
IBA # 39193
MIXR is offline   Reply With Quote
Old 08-07-2013, 09:09 AM   #5
Melrone
Oddometer: 946
I'm thinking of putting one on the front of my GSA/Ural rig..Went and looked at on at Scrambler Cycle a couple of weeks ago.Nice looking tire but just wondering what kind of mileage do you get..Nice little shop by rhe way...
Melrone is offline   Reply With Quote
Old 08-07-2013, 09:18 AM   #6
hahnda
hahnda's Avatar
Oddometer: 142
9000km or 5500 miles out if the K60's with sidecar use sounds pretty decent to me considering the tire type. Was the front also wore out at that time?
It was good meeting you Melrone (Dave if I remember correct?) when you were here at the shop.
Heidenau Tires
Old 08-07-2013, 03:53 PM   #7
MIXR
MIXR's Avatar
Oddometer: 662
Mileage is ok
Front K60 is still on the bike (sans sidecar) and easily lasted the 9,000 kms with the chair fitted. I checked my records and I pulled the first rear K60 at 7,000 kms so it could be rotated to the chair. It definitely has another 2,000 kms of life left. Wear was slow while the tyre was still 'round', then wore quickly to a 'flat', and then wear slowed up considerably. Probably just a function of the contact patch growing as it flattened off.
Grip is good as the side lugs are still there if you get into wet grass or loose dirt. The zig-zag centre strip helps with road wear but still gives some decent grip. Doesn't howl, but will humm. Not intrusive.
I replaced the rear with another one just before I pulled the sidecar (it broke again!), so that's a sign that I thought they were ok.
IBA # 39193
MIXR screwed with this post 08-12-2013 at 06:17 PM
Old 08-11-2013, 09:17 PM   #8
swoody126
swoody126's Avatar
Oddometer: 422
watching this one
just bought a URAL GEAR UP & she came w/ a complete set of K37's
so far, there have been no surprises & about 1/2 of the 200 miles i have put on her were on gravel/dirt roads
sw
"Life isn't about waiting for the storm to pass,,it's about learning to ride in the rain."
swoody126 screwed with this post 10-07-2013 at 06:14 AM
swoody126 is offline   Reply With Quote
Old 09-07-2013, 09:43 PM   #9
NortwestRider
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 3,906
I run K60's on both my ADV solo's and LOVE them,I get over 10,000 miles out of the rears.I will be putting a 1/2 worn 130/70-17 from my wifes GS500 on the hack this winter.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is offline   Reply With Quote
Old 09-11-2013, 02:25 AM   #10
Tigris_GER
Adventure-Finder
Tigris_GER's Avatar
Oddometer: 62
I used several sets of Heidenau K60 on my Suzuki DR 800 solo bike, once - in 2003 - I even used them in Romania for Enduromania (http://enduromania.net/OLD/index.php?&lang=en).
They are very good on dry roads, very good on wet roads, good on gravel roads but bad in mud. They provide enough grip on paved and unpaved roads but the space between the blocks is not wide enough to allow to throw out the mud.
I used a rear tire for approximately 6.000km, a front tire for 12.000km.
In Germany they are one of the cheapest offroad tires.
Kind regards from Kabul
Take me down to the paradise city
where the grass is green and the girls are pretty
Four wheels move the body
and three wheels move the soul
Tigris_GER is offline   Reply With Quote
Old 09-11-2013, 10:27 AM   #11
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,760
In the U.S., they are one of the most expensive. A 150/70-17 which is what fits the GS will run you just under $200. About the only other dual sport tire that costs as much is the new Metzeler Karoo 3.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 09-11-2013, 10:36 AM   #12
NortwestRider
Oddometer: 3,906
From what I have read about the Karoo 3,the K60 last's upto 3x longer.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 09-11-2013, 10:57 AM   #13
Agent Wayward
Oddometer: 375
I fitted them to a Bonnie / Ural outfit, the rear lasted 4000 miles.
Works fine though.
SV650 Rat
R80 custom
Multistrada 1100
www.motopodd.com
Agent Wayward is offline   Reply With Quote
Old 09-11-2013, 08:12 PM   #14
Tigris_GER
Adventure-Finder
Tigris_GER's Avatar
Oddometer: 62
In Germany the K60 in 150/70-17 is available for 104 Euro (= 137 US Dollar), my personal favorite Continental TKC80 in 150/70-17 for 115 Euro (152 US Dollar).
Looks like tires are more expensive in the US.
Old 10-06-2013, 09:58 AM   #15
NortwestRider
Oddometer: 3,906
Just saw this pic on a Facebook group I belong to, no details yet.
Sent from my iPhone using Tapatalk - now Free
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Times are GMT -7.   It's 12:01 PM.
