Old 08-08-2013, 04:13 PM   #1
klm4755 OP
Oddometer: 575
Homemade hiway pegs for vespa GTS 250 Project
Enclosed is a step-by-step walkthru outlining the fabrication of hiway pegs for a vespa GTS scooter. The intent of the hiway pegs is to provide cramped leg relief on long distance rides. Couple goals of the fabrication include:
1. No scooter frame drill
2. Minimal foot well loss when pegs in storage
3. No weld, as I have zero weld skills
4. Robust design
5. Locate pegs as to minimize no ground contact while in turns
6. removable system
7. easy on/off for scooter cleaning, maintenance and such
I ended up fabricating several concepts (mock-ups). This thread outlines iteration # 3.
Hiway pegs to mount (from e-bay at $26 USD) linky here:
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
hiway peg packaging label
need about 3 feet of .75 inch x.75 inch square 6061 aluminum square tubing
need ~12 inch of 3M dual lock (about 5x stronger than velcro)
about 2 ft x 2 ft section of 6061-T6 aluminum sheet, t = .125 inch
mark and trim sheet splice strips
attach splice strips to square tubing
butt-up to footwell hump
strip down the pegs retaining only peg, peg bracket and attach bolt
measure bolt diameter
maintain 2 diameter edge distance on bolt thru square tubing
trim and cut splice for hiway peg square tube attach bracket
rough fit check
splices attached to square tubing
peg mounted to bracket
need to fabricate attach pads (6x total) these will fit between the footwell protruding ribs and connect the hiway peg system to the scooter
tap (thread) hole to accept a M4 course thread bolt (I ended up just using a single fastener per pad).
get out hole punch 3/16 size
punch hole in dual lock
like so
bond to pad (adhesive backing) where threaded hole is located
pads attached to bracket with fastener
attach to hiway bracket at footwell between protruding ribs
right and left side in rough stage, need to connect the two sides
fits like so....
checking upper splice connection fastener grip length size
bracket in rough state
starting to reinforce with additional fasteners and swapping the protruding head fasteners with flush head fasteners (counter-sink)
filing the edges, deburring the splices and tubes
adding a decorative top cap
mount bracket....Notice all fasteners are flush, added center top cap, filed off all excess material
bolt on hiway pegs
hiway pegs mounted
front view pegs stowed
pegs stowed offset view
first person view....pegs extended
first person view pegs in use.
1/4 scooter view pegs stowed
3/4 scooter view pegs stowed
Notes and observations:
1. difficult fabrication, several iterations to get in to work
2. completely removable
3. loose little foot area with bracket installed
4. pretty robust system. Can push hard and load is transferred into the foot well without issue. Needed to connect the 2 sides to cancel out the induced moment developed by the eccentric load formed from the foot peg load transfer.
5. Nice to be able to extend legs during long rides. works well and complements the back-rest jacket lumbar system.
Enjoy!
Keithm
klm4755 is offline   Reply With Quote
Old 08-08-2013, 06:39 PM   #2
climbamt
climbamt's Avatar
Oddometer: 202
Nice job Keith!
03 BMW F650 GS ABS
05 Vespa GT200
06 Kymco People 150
02 Kymco People 50
Baltimore, MD
climbamt is offline   Reply With Quote
Old 08-08-2013, 07:23 PM   #3
damasovi
damasovi's Avatar
Oddometer: 2,637
you keep on improving that vespa man!!
D.
A motorcycle or scooter always turn a bad day into a great time!
KLR 650, Honda Beat scooter!!
damasovi is offline   Reply With Quote
Old 08-09-2013, 05:09 AM   #4
hayasakiman
Oddometer: 159
Are they stainless steel hardware on aluminum?
hayasakiman is offline   Reply With Quote
Old 08-09-2013, 07:32 AM   #5
klm4755 OP
Oddometer: 575
The fasteners are all stainless steel. I do not see any issues as with this combination as the area of the annode material (Aluminum) is much larger than the area of the cathode (stainless steel). There should be no dissimilar material or galvanic corrosion compatibility concerns.
Keithm
Old 08-09-2013, 07:33 AM   #6
klm4755 OP
Oddometer: 575
Here is a couple enhancement to the hiway peg bracket:
added center flush fastener, all fasteners are metric stainless steel
will finish the surface with wet sand paper at 120, 400 and 1000 grit
after 120 grit
after 400 grit
after 1,000 grit
brushed steel look
close-up of flush stainless steel fastener counter sunk head
attach tab holes
weight = 2 lbs 9.4 oz
as mounted after sanding + added fasteners
right side view
front view pegs down
close-up right peg down
close-up right peg stowed
left side peg stowed
offset view
Keithm
Old 08-10-2013, 02:51 PM   #7
TheReaper!
TheReaper!'s Avatar
Oddometer: 653
It's a good thing we're not neighbors , we would be up half the night fabricating shit .
TheReaper!
TheReaper! is offline   Reply With Quote
Old 08-12-2013, 05:03 PM   #8
Shirker
Oddometer: 456
Great fab skills!
What does the underside of the floorboards look like? Would strap bars mounted below with your rig for the outboard pegs lose you significant clearance?
Shirker is offline   Reply With Quote
Old 08-12-2013, 11:06 PM   #9
gogogordy
gogogordy's Avatar
Oddometer: 1,940
TheReaper!
I fab some of that daily, and get a good night's sleep while I'm manufacturing it.
Product distribution begins at 0600 daily.
Isn't it past your bedtime?
gogogordy is offline   Reply With Quote
Old 08-17-2013, 05:33 PM   #10
klm4755 OP
Oddometer: 575
Originally Posted by Shirker View Post
Great fab skills!
I did not desire to drill into the frame (metal part anyway). I considered an underside mount, but it would require fabrication of a curved bracket to match the outer mold line and drilling into the front metal fairing. I'm happy with the mount location, as a nice benefit, I recieve a cool breeze up the pant when in hiway pegs are in use. Probably not so nice on a cold day.
Keithm
Old 08-23-2013, 10:09 AM   #11
Motovista
Parts is Parts
Motovista's Avatar
Oddometer: 507
That is really neat. I like the way it doesn't require destroying the plastics on the bike and looks like it easily comes off.
Discount OEM, replacement and performance parts for vespa, honda, bmw, yamaha, suzuki, genuine, kymco, piaggio, aprilia, SYM, tgb, tomos and other scooters at http://www.scooterpartsco.com
GT200, GT200, ET2, Italjet Velocifero, Italjet Torpedo, Eton Beamer 3, Genuine Buddy Pamplona 150, Kymco Vitality 50, Honda Elite 50
Motovista is offline   Reply With Quote
Old 08-25-2013, 07:56 AM   #12
klm4755 OP
Oddometer: 575
I was tempted to attach to floorboard, but the dual lock is working well. As a side note, I receive lots of airflow up the pant lag to make for a nice cool run on hot days.
Keithm
Times are GMT -7.   It's 12:59 AM.
