Old 10-04-2013, 07:51 AM   #31
Dune
Oddometer: 430
Originally Posted by DELTATANGO View Post
Hey Ya'll,
I'm in the process of swapping the 990 engine into my 950.
I have to change the pickup ring right? I have to put in the 950 ring since it will be carbureted.
Thanks,
To
I was planning on doing the same with an engine that I had which just sold until I just picked up a 950 that had 990 cams in it with 39mm carbs...
you should pick these up:
http://cosentino-engineering.myshopi...the-full-monty
runs awesome tons of torque! and tons of fun!!
Dune is offline   Reply With Quote
Old 10-04-2013, 07:55 AM   #32
DELTATANGO OP
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,909
Oooo, yeah. Maybe at some point...........crunk.
I have to get the fucking nut off the clutch first. I'm not going to do it sitting here though.
DELTATANGO is offline   Reply With Quote
Old 10-04-2013, 08:10 AM   #33
Dune
Oddometer: 430
I find that if you sit and stare at it long enough...
or when you cant sit and stare (for having to work)... use the force...
Old 10-04-2013, 08:19 AM   #34
DELTATANGO OP
DELTATANGO's Avatar
Oddometer: 13,909
I just pulled several times on it with a long bar, almost had an aneurism. Some fucking Schwarzenegger mechanic must have put it on.
I'm going to set it on the floor and get real in a minute after I recover.
It's not reverse threads is it?
Old 10-04-2013, 08:27 AM   #35
Dune
Oddometer: 430
I dont believe so...
There should be more How to Threads kicking around but here is one:
http://www.dirtymotorcycleadventures...t-replacement/
Old 10-04-2013, 08:48 AM   #36
DELTATANGO OP
DELTATANGO's Avatar
Oddometer: 13,909
"Its a normal nut, righty tighty and lefty loosy (hopefully the same for the RC8).
First time I had that nut off I had the bike laying on its side and hight gear and locked the rear wheel with a strap around the frame. Had tried both electric and air impact tools, ended up with a very long extension on the wrench and had to lay on the floor holding my feet against the bike to stop it from rotating BANG, first thought the wrench snapped but it was the nut coming undone."
Old 10-04-2013, 09:17 AM   #37
GrenDesb
Oddometer: 329
I think I'll keep looking for a 950 engine or rebuild this one.
I'm thinking now of a total rebuild.
You can use your carbs and wiring on a 990.
There have been FI engines converted to carbs.
Look on the HOW, simple matter of swapping a tooth ring.
GrenDesb is offline   Reply With Quote
Old 10-04-2013, 09:27 AM   #38
DELTATANGO OP
DELTATANGO's Avatar
Oddometer: 13,909
That's what I'm doing. It is simple, but getting that nut off wasn't easy.
I ended up using some leg power.
I just installed the trigger wheel and I'm putting it back together. I'm waiting on the big gasket to come it so no hurry.
Thanks,
Tom
Old 10-04-2013, 09:32 AM   #39
Dune
Oddometer: 430
Thanks,
Tom
Cool!
let us know how it turns out! what rig is this going into? 2004 ADV?
I would imagine that nut sees some heat so it can likely get 'welded' in pretty good...
Old 10-04-2013, 05:46 PM   #40
DELTATANGO OP
DELTATANGO's Avatar
Oddometer: 13,909
Cool!
Yeah, I'm putting it in an 04 Adventure.
I got the trigger wheel and the clutch installed. I'm going to check the valves and then put the side cover back on next and then install the engine.
I'm thinking the long pole will be those carburetors. I have no idea how they are jetted or what they should be for the 990. Those $1500 sure would be sweet but that is what I paid for the entire motorcycle.
I'm going to clean it good tomorrow and take it slow, don't want to get in a hurry.
Old 10-11-2013, 06:38 PM   #41
DELTATANGO OP
DELTATANGO's Avatar
Oddometer: 13,909
Jetting
I'm getting there.
I'm going to put the put the carbs, oil tank and radiator on Monday.
I got the Sporting Wood air filter and jet kit with stock mufflers for now.
What jets should I use for 8-900' msl?
I know it's on here somewhere but I can't find it.
DELTATANGO screwed with this post 10-11-2013 at 06:56 PM
Old 10-15-2013, 04:58 PM   #42
DELTATANGO OP
DELTATANGO's Avatar
Oddometer: 13,909
It's ALIVE.
ITS ALIVE!
It's pouring gas all aver the floor but IT"S ALIVE.......
And yes the oil light went off.......
HA. I got me a KTM motorcycle.
Old 10-15-2013, 05:03 PM   #43
DELTATANGO OP
DELTATANGO's Avatar
Oddometer: 13,909
I'm going to do some wheelies on it this weekend.
Maybe ride the old ball and chain.....
Old 10-15-2013, 06:45 PM   #44
Moose Lee
Oddometer: 13
Thats AWESOME
Moose Lee is offline   Reply With Quote
Old 10-15-2013, 06:53 PM   #45
DELTATANGO OP
DELTATANGO's Avatar
Oddometer: 13,909
Originally Posted by Moose Lee View Post
Thats AWESOME
I wanted to ride it to the gas station but a float is stuck and I have to work early.
I need to rejet the carb anyway.
Times are GMT -7.   It's 03:42 PM.
