Old 08-13-2013, 04:06 PM   #16
Rugby4life OP
Rugby4life's Avatar
Oddometer: 725
Originally Posted by acejones View Post
How do you feel about BMW of Baton Rouge now ?
Now everybody, understand that I'm not bashing the dealership (wasn't dealing with Baton Rouge BTW). They have a hourly rate and a service manual that tells them to remove all this stuff just to get to the bulb. Simple math says it's gonna cost an arm and a leg. The point I made to the customer relations rep is that this is not the kind of German engineering I've come to expect. Changing a headlight bulb is the kind of thing any owner should be able to do in 10-15 minutes. How hard is it to design an access panel? I would be happy if you could remove the right side glovebox and gain access. Is that too much to ask?
"Before attempting to beat the odds, first determine if you can survive the odds beating you."
Rugby4life is offline   Reply With Quote
Old 08-13-2013, 04:37 PM   #17
DudeClone
DudeClone's Avatar
Oddometer: 1,839
how many German's does it take to change a BMW scooter headlamp bulb?
well, its supposed to be a joke but i can't think of a punch line!!
bikes
DudeClone is offline   Reply With Quote
Old 08-13-2013, 05:19 PM   #18
Jimbozini
Misadventurer
Jimbozini's Avatar
Location: The Church of the Twisty Road - East Tennessee
Oddometer: 453
Can you post a picture of what you see after removing the right side panel? I have minimal experience with the 650GT (don't have Pop's here for reference) but it has many similarities w/ my GSA. Replacement should not be all that tough... only akward Post a pic & I'll try to help.
Originally Posted by Rugby4life View Post
After nearly 8k miles, my low beam bulb died. I think it shook to death over the "streets" of New Orleans. Any way, I checked the owners manual and it said to remove the right side panel to gain access to the bulb. Removed the panel and the battery and multiple fuse blocks are in the way. Removed the battery but couldn't see how to remove the battery box and fuse blocks. Called the dealership and the service manual calls for the entire front end to be disassembled for access. I'm not going to pay 2-3 hrs of shop time to change a stupid bulb. Anybody know a better way to gain access?
-Jim
TiMe WaRP vINtaGe mOTOrCyCLe cLuB
Moto Images
$5 off on a Smugmug accout Use this coupon code: LlVtvdPX4gIjg
Jimbozini is offline   Reply With Quote
Old 08-13-2013, 05:31 PM   #19
andoulli
CAJUN
andoulli's Avatar
Oddometer: 2,114
I did the warranty research first, no need to call them, I was wrong, get it, I was wrong, I posted I was wrong, get it?
andoulli is offline   Reply With Quote
Old 08-13-2013, 06:35 PM   #20
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,276
You might want to mention it again, just to be sure.
Oh - by the way you were wrong
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is offline   Reply With Quote
Old 08-13-2013, 07:46 PM   #21
Jimbozini
Misadventurer
Jimbozini's Avatar
Oddometer: 453
The easiest way my be to remove the headlight assembly. Can you gain access to the assembly by removing the left & right fairing panels? I ask this as it is very cumbersome to access the back of the headlight assembly on a GSA as directed but a piece of cake with the assembly removed!
-Jim
Moto Images
Old 08-14-2013, 06:57 AM   #22
andoulli
CAJUN
andoulli's Avatar
Oddometer: 2,114
Actually I'm rereconsidering my position on this issue.
Old 08-29-2013, 07:52 PM   #23
Rugby4life OP
Rugby4life's Avatar
Oddometer: 725
Sorry it took me so long to update this thread but life has been getting in the way. After speaking with the customer service rep, I got a follow-up call from a tech services rep. After reviewing the shop manual, they tinkered around with a GT and came up with an alternate procedure that doesn't call for disassembling the entire front of the bike. It was supposed to be a 20 minute service but it took me 45 since it was my first try, plus I got everything buttoned back up before realizing I hadn't replaced the rubber socket cover and had to pull it all apart again. Thankfully it can all be done with a T-25 torx head driver and a Phillips head screwdriver.
1. Remove the right side panel
2. Disconnect and remove the battery
3. Remove the 2 screws holding the battery box (bottom left side and top right back?
4. Cut 2 zip ties on back of battery box
5. move the box out of the way
6.If your arm is small and limber enough, you can gain access to the rear of the headlight socket
7. *** Bonus good news, the instrument panel retains it's memory so you don't have to reset the clock after reconnecting the battery.
Times are GMT -7.   It's 05:11 PM.
