Old 08-13-2013, 09:15 PM   #1
KPD OP
Oddometer: 16
Question Clutch Stuck After Sitting for 35 Years
Hi All!
I recently bought a 1971 Honda CB100. It has 690 Original Miles (not a typo). Basically the guy bought it in 1971 and put a few miles on it and then bought a bigger bike and left this one to sit, which it did for 35 years until I bought it last week.
Bike now has new battery, new oil, cleaned carb. Still won't run for long, won't idle, and the clutch is sticking. Even when I have the clutch lever pulled in the bike won't roll sometimes... but sometimes it will.
The guy I bought it from also has his bigger bike (CB350) and had a lot of the same issues after it also sat for 35 years. Said that the carb needed rebuilding and once the engine would run long enough to heat up, the clutch issue went away.
Anyone have experience with this clutch issue with an older bike that sat for a really long time?
Thanks everyone!
KPD is offline   Reply With Quote
Old 08-13-2013, 11:57 PM   #2
Beezer
Oddometer: 5,878
ya... the plates stick together. drain the oil, pull the engine cover, remove the 4 clutch nuts & springs, take out the plates... clean or replace as required
Beezer is offline   Reply With Quote
Old 08-14-2013, 09:20 AM   #3
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,715
^this -- after you get it to run long enough to warm up . . . . the plates MAY beak free .. ..
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 08-14-2013, 03:04 PM   #4
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,331
I would not suggest this for confined areas, but if you live in a remote area or have a large lot next door once the bike idles and runs OK you can get pushed on it while it is idling and clack it into first gear and with the clutch lever held in accelerate and decelerate and you can often pop them free.
Having said that, if it is a reasonably nice bike I'd suggest there is nothing wrong with simply replacing them at this point in time and being done with the worry of having them either stick again in the future or else having the lining disintegrate on you at some embarrassing or inconvenient time.
GreaseMonkey is offline   Reply With Quote
Old 08-14-2013, 04:20 PM   #5
ttpete
Rectum Non Bustibus
Oddometer: 6,054
With that mileage, the clutch plates are just stuck from sitting. Pull them out and wash them off with solvent and reassemble. Provided you ride it regularly, you shouldn't have a problem in the future. If you store it for any length of time, just tie the clutch lever down with a zip tie so they won't stick again.
ttpete is online now   Reply With Quote
Old 08-14-2013, 07:06 PM   #6
showkey
Oddometer: 1,974
[QUOTE=ttpete;22102667If you store it for any length of time, just tie the clutch lever down with a zip tie so they won't stick again.[/QUOTE]
That way you can replace the clutch springs because they lost their tension from being compressed.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 08-15-2013, 07:19 AM   #7
KPD OP
Oddometer: 16
Thanks everyone, I'll focus on the carb and getting the engine running smoothly, maybe the heat will take care of it. Otherwise I'll end up taking it apart and cleaning the plates. The bike only has 690 miles so they probably don't need replacing.
Thanks for your help I'll keep you all posted
Old 08-15-2013, 07:48 AM   #8
ttpete
Rectum Non Bustibus
Oddometer: 6,054
Not so. The pressure plate only moves about 1/8 inch to release the clutch, and that's not enough to cause a problem.
Old 08-15-2013, 04:04 PM   #9
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 983
I've seen old clutches stuck such that the plates had
to be separated with a screwdriver or prybar,
with some wear-plate material sticking to
the steel plates. Long-term sitting causes
many problems.
CycleDoc59 is offline   Reply With Quote
Old 08-15-2013, 04:22 PM   #10
Lomez
Yea...Sunday too
Lomez's Avatar
Oddometer: 285
Happens on my CB750 all the time, when it sits for a long time. What I've done:
Method 1 (when it's in running condition)- bump start and ride around in 1st gear, rolling on and off the throttle for a while. I've done this and eventually broken the plates loose.
Method 2 (if running and have a center stand)- start in neutral, with rear tire off the ground....I rev the motor up and drop into 1st gear. This usually breaks them loose the first time (for me), and pulling the clutch in again disengages.
Method 3- same as 2, but with the tire on the ground...just do a tranny drop. This method doesn't seem to work as well for me. Usually takes 3-5 "drops" to break them loose.
However, I've worked with more like 6 months...not 35 years
Yeah. well I figured since I was lying about my income for a couple of years, I could afford a fake house in the Hamptons.
Lomez is offline   Reply With Quote
Old 08-15-2013, 09:01 PM   #11
broncobowsher
broncobowsher's Avatar
Oddometer: 1,795
Sitting a week or a month or even a year and sticking is usually fixed by holding the clutch in and riding around getting on and off the throttle.
But 35 years. That won't work. Pull the clutch cover, peel each of the fibers and steels apart, if not too much fiber stuck to the steel and the fiber is still in solid then put it all back together and run it. Sitting that long requires an inspection. The fibers can be so glued to the steel they never come apart, or the fibers may just come apart and spray fibers through everything.
Dealing with age related issues is a lot different then mileage or abuse related issues.
broncobowsher is offline   Reply With Quote
Old 08-18-2013, 06:30 PM   #12
rufus
We're burning daylight...
rufus's Avatar
Oddometer: 4,247
Originally Posted by broncobowsher View Post
......., or the fibers may just come apart and spray fibers through everything.
That would be my main worry. The price of a few clutch plates is cheap compared to a ruined motor if the clutch sheds enough debris to clog an oil passageway.
I have freed up many stuck plates by riding the bike around, but i wouldn't do that on a 35 year old bike. ESPECIALLY if it a nice low mileage bike.
rufus is offline   Reply With Quote
Old 08-27-2013, 07:15 AM   #13
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,247
Ever seen a fiber clutch plate come apart? I doubt that's going to happen, they are held in there (captured) very well. I've repaired quite allot of clutches and have yet to see a fiber plate come apart. If it were to happen, you will know as soon as it occurs.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is online now   Reply With Quote
Old 08-27-2013, 07:16 PM   #14
rufus
rufus's Avatar
Oddometer: 4,247
Yes I have.
I had a small chunk break off on a YZ 250 I had. It locked up the clutch.
My brother had a plate break into pieces on one of his dirt bikes. Saw that on a friends bike also.
I had an old DT 250 that would turn the oil black in 5 minutes because the plates were disintegrating. The plates looked fuzzy.
I have seen a couple of old bikes that were working fine but 1 or more clutch plates came out in pieces.
Old 08-28-2013, 11:05 AM   #15
Yamarocket630
Honey Badger
Yamarocket630's Avatar
Oddometer: 597
The clutch stuck on my Vfr750 after sitting overnight last night. Started it in gear and damn near drove through the wall of my garage.
I'm betting after 35 years its stuck good.
Yamarocket630 is offline   Reply With Quote
Times are GMT -7.   It's 11:42 AM.
