Old 01-03-2014, 10:46 PM   #46
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,384
Luke, that's awesome!
GatosBros · Crux Studio · Trails Less Traveled
jesusgatos is offline   Reply With Quote
Old 01-03-2014, 10:51 PM   #47
Lutz
Killer Rabbit
Lutz's Avatar
Oddometer: 1,412
All kinds of cool, there! Enjoy the ride, can't wait to hear about it.
Lutz is offline   Reply With Quote
Old 01-08-2014, 01:02 AM   #48
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,172
I didn't dent it.
I went on an easy trail ride on Saturday, we had a mix of bikes so nothing too tricky. (for my bike. for the Triumph Tiger there were definitely some tough spots )
(pic by Scott_PDX)
The ride confirmed initial impressions. It's definitely lost a lot up top and gained it on the bottom. The jetting was a bit off, which I worked on after the ride.
All three plugs were run on the same stretch of road with different main jets. The right was the original 260 jet which was a bit rich on the old pipe. It seemed a little lean on the new one. Middle is 270, and left is 280. The top speed was 42ish up the hill on the 260 and 48ish with both the 270 and 280. I'll probably stick with the 280. I'm not particularly confident that I'm reading the plugs right, but the top speed is a pretty good clue.
Luke is online now   Reply With Quote
Old 01-09-2014, 10:21 PM   #49
ttime4four
ttime4four's Avatar
Oddometer: 256
Originally Posted by Luke View Post
... for the Triumph Tiger there were definitely some tough spots )
And one of those tough spots modified my shifter.
'14 KTM 690 Enduro R
'14 BMW R nine T
'06 Husaberg FE450e (Oregon Plated)
ttime4four is offline   Reply With Quote
Old 01-10-2014, 01:32 PM   #50
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,172
I was most impressed by the 18" log that got out of your way when you hit it.
Old 01-23-2014, 09:20 AM   #51
Loud Al
Loud Al's Avatar
Oddometer: 3,907
Wow you have been busy, the bike is looking good.
A Quick Trip to Big Sur
Allan
Loud Al is offline   Reply With Quote
Old 01-23-2014, 11:30 AM   #52
WERA456
WERA456's Avatar
Location: North Ga. (The site of the first major gold rush)
Oddometer: 204
I have been thinking about the same thing. Do we know if anyone else has tried this?
Originally Posted by dirt hokie View Post
I have the same idea for a nice light cheap bike, only mine will be street legal.
What is the finished weight, is it lighter then a kdx 220?
I was thinking along the lines of a xt 225 engine in a yz 125 frame.
so a little heavier but with e start.
WERA456 is online now   Reply With Quote
Old 01-25-2014, 11:21 AM   #53
operose
Mama tried
Oddometer: 608
Nice one, Luke! I really like the hydroformed pipe... Now you've got me thinkin' and that can be dangerous
operose is offline   Reply With Quote
Old 01-25-2014, 10:03 PM   #54
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,172
Thanks, I'm really impressed by what changing the pipe does for the power.
Speaking of the pipe, it got its first dent last week:
The bike landed an 11 o'clock wheelie over a log right on the pipe. Considering the hit it took it's not in bad shape. Good thing it still works, because I tried pounding it out from the backside with a hammer and punch and the dent didn't budge.
The offending log:
So, time for the worlds most expensive skidplate mod.
Start with a new welder and add some sheet aluminum:
Here are my first three aluminum welds in years. I like this machine.
It'll take a lot of practice to get them looking nice, but this should get the job done.
Finished with the front tray:
The footpeg mounts and shock linkage hang below the frame rails and they tend to get hung up on logs. So I added a slider to the back. It's got a little too much clearance to the shock mount, giving up a little extra ground clearance, but that'll be easy to fix if need be. I would have liked to box the sides in for strength, but the front triangle would fill with mud.
Complete.
Testing today:
Small; still have to work on landing the wheelie, but at least the pipe survived:
Medium; not bad:
large; excellent:
Old 03-09-2014, 12:01 AM   #55
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,172
A long update:
I've been riding the bike. It's working pretty well. The clearance with the new pipe is sometimes necessary:
And it's easy to pick up when things don't go so well.
I've done a little maintenance, the front wheel bearings went out and the rear brake pads wore out.
That pad was new less than 400 miles ago. Clearly I like to use the rear brake.
The original hand guard clamps were interfering with the brake line, so I replaced them with mounts made by GatosBros.
Before:
After:
I also replaced the Ram U-bolt bracket with a bolt-mount ball.
Combined with their pinch clamps on the bar ends the guards are much more secure. The left ones work great. I don't know about the right ones, I haven't crashed on that side yet.
The bar end pinch clamps:
Full disclosure: Jesse of GatosBros is a friend and wouldn't let me pay for them when I tried. So I'll spam for him instead. http://gatosbros.com/
I added a steering damper. I had a Motosportz damper from my Husky, it worked great but the mounting setup isn't very good. A Scotts damper would bolt right up, but I like the action of the Motosportz better. Started with a Scotts upper triple clamp from ebay. Modified the Motosportz mount to fit the Scotts bolt holes. I made a bracket to clamp the damper body more securely to the mount. Added some spacers to the mount to get the right bar height. I welded them together to make the Jenga tower more stable. Extended the damper arm to reach beyond the triple clamp and added a frame bracket for the pin. End result:
The best is saved for last. I made a new gas tank. The XR tank was working, but it was wider than the seat and got in the way of my knees when leaning forward.
Start with 0.09" 6061 aluminum.
I have two rides on it now and it makes things much better. It also holds slightly more fuel than the original tank. The downsides are that it's heavier than the plastic tank, will eventually get dented and must be moved to access the spark plug.
Old 03-09-2014, 05:17 PM   #56
TwinDuro
Befuddled Adventurer
TwinDuro's Avatar
Oddometer: 318
Awesome Luke! Beautiful work on the new tank, it looks fantastic. Some tight confines for the TIG torch for sure! Out of curiosity, where did the aluminum filler neck come from?
I can definitely appreciate the Gatosbros complete redesign of the Cycra bar-end and triple-clamp hand guard mounts... I ran into a nearly identical issue with the brake line/master on the '03 YZ250 front-end on my '89 YZWR when installing a set of Pro Bends, so it's good to know these awesome parts are out there.
So, is there an ADV "Woods Bike Of The Year" award?
"Remember, you may have to grow old, but you don't have to mature." - Red Green
TwinDuro is offline   Reply With Quote
Old 03-09-2014, 10:12 PM   #57
Lutz
Killer Rabbit
Lutz's Avatar
Oddometer: 1,412
Love the updates.
Old 03-09-2014, 11:03 PM   #58
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,172
The water cooled torch is tiny compared to my old air cooled one. It's so much easier to use. I even have a shorter back cap for it, but haven't worn any tungstens down enough to be able to use it.
The gas cap is from clarke. It's meant for converting dry break tanks to a regular gas cap.
http://clarkemfg.com/clarke-dry-brea...-cap-p-12.html
Homebuilt aircraft suppliers also sell a variety of weld-in caps, some of which are affordable. All the motorcycle ones I found that were meant for a weld-in application were either steel, too small, or poorly described.
Old 03-10-2014, 11:43 AM   #59
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 733
Just trying to keep up with Luke and his hybrid woods bike on Saturday, I had a great view all day of how well that machine works! Luke really outdid himself on this one!
"Nothing can stop us but fear and common sense”
LC Garage is offline   Reply With Quote
Old 03-11-2014, 11:10 AM   #60
bobfab
bobfab's Avatar
Oddometer: 1,410
keeps getting better
CRF250L | KTM200SX
bobfab is online now   Reply With Quote
Times are GMT -7.   It's 06:44 PM.
