Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 08-14-2013, 07:52 AM   #1
PS-RagE OP
PS-RagE's Avatar
Oddometer: 649
1190R + Offroad Wheels?
As I was saying in the other thread before Tancakar came along:
I'm seriously considering replacing my '04 950 with an 1190R next year. Do you think my offroad Woody's Wheels are going to swap over OK? They are a 1.6" A60 up front and a 2.5" rear with 606/908 tires. Maybe with new spacers?
Allow me to add to this that I basically ride my 950 as though it was a big dirt bike and I imagine the 1190 will see the same. I intend to keep the original wheels for touring.
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
2014 KTM 1190 Adventure R
PS-RagE screwed with this post 04-11-2014 at 05:16 AM
PS-RagE is offline   Reply With Quote
Old 08-14-2013, 09:43 AM   #2
mousitsas
mousitsas's Avatar
Oddometer: 2,950
I think the rear hub is the same, but the front is different. It is not something I have found out myself, but I'm quite sure I've read it on the internet!
Old 08-14-2013, 09:48 AM   #3
charlie264
charlie264's Avatar
Oddometer: 8,367
Have you asked Woodie, I suspect he's investigate the options available...
Old 08-14-2013, 05:20 PM   #4
PS-RagE OP
PS-RagE's Avatar
Oddometer: 649
They are not sure yet either. I was hoping one of our European riders might have made the switch.
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
Old 08-14-2013, 06:01 PM   #5
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,308
Found this on the SA forum:
The 1190 R comes with tubeless tyres. I cannot live with this idea, it had to change. So, we had to make a plan. Long story short: Rear wheel consists of 990 hub, spokes, rim and 1190 ABS sensor and brake disc. Front wheel: 1190 hub, 950SE spokes and front rim, 1190 discs and ABS ring. (1.85" DID Dirt star)
What we learned from the other (and far more interesting ) thread was that Joe Pichler used the front 1190 hub too so it looks like your front won't fit. Not familiar with woody's, maybe you just need the hub?
Jaime
Big, Loud and Orange KTM 990 Adv
Jaimoto is online now   Reply With Quote
Old 08-14-2013, 08:55 PM   #6
PPiA
Pete
PPiA's Avatar
Oddometer: 1,182
I have also asked the question to Woodies. They were going to try and find out.
The info above would probably help them.
PPiA is offline   Reply With Quote
Old 08-15-2013, 07:45 AM   #7
LukasM
Oddometer: 5,426
Interesting that the front wouldn't fit....
In all likelihood it will be easy enough to adapt the old wheel with a set of custom axle and disc spacers? With the wide radial calipers more clearance is needed so probably the triples and hub are wider. I doubt the disc bolt pattern has changed, it's been the same on every 125cc+ KTM made in the last 20 years.
KTM even has a front disc spacer that could used, they put it on the LC4 SMs with the fat gold 4 piston Brembo caliper. 210mm width fork spacing on those bikes vs. 190mm for most other KTMs incl. 950/990.
Old 08-19-2013, 11:39 PM   #8
Yascher
Yascher's Avatar
Oddometer: 388
990 and 1190 wheels are not fully compatible.
1- the hubs itself will fit just fine on the axels and have exact same width,
BUT
2-the fitting diameter foir the brake discs is wider, therefore you can noit switch brakes between the 2 as the hubs/discs are different in dia 310/320 and have different fitting diameter, therefore custom drilling for the disks or adaptors will be required
if this is not a problem-then it is almost staright fit, once adaptors are made
Yascher is offline   Reply With Quote
Old 08-20-2013, 08:23 AM   #9
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,597
...and no Cush Hub.
Old 08-20-2013, 07:09 PM   #10
crashmaster
ow, my balls!
crashmaster's Avatar
Oddometer: 5,298
Why would anyone want to replace the wheels? They are perfectly fine. You must not know anything about off road.
Riding the Americas: No Fumar Español
_____________________________________________
crashmaster is offline   Reply With Quote
Old 08-22-2013, 07:23 AM   #11
Toors
Toors's Avatar
Oddometer: 120
The 990 or equivalent rear wheel fits - in the front you have to use the 1190 hub and then fit new spokes and the 990 rim.
We (in South Africa) have been having a number of problems with bending the front rims - they seem to be to soft for aggressive off-road riding and getting an instant flat on the tubeless tyres is a hair raising experience, so, me for one, will be going back to tubed, narrower and stronger rims - just waiting for the yanks to get their 1190's (and get their ducks in a row) so that I can order some nice heavy duty excel ones with blue hubs and blue rims with orange spoke nipples form KTMTwins
Toors is offline   Reply With Quote
Old 08-23-2013, 03:32 AM   #12
Toors
Toors's Avatar
Oddometer: 120
This is the rubber that I have fitted:
Old 04-11-2014, 03:20 AM   #13
Baronsamedi
Mr. Flippin' Happy
Baronsamedi's Avatar
Oddometer: 3
Soft rims.
I'm in agreement with South Africa. I've had issues with bending of the front rim on my 2013 1190r on rough terrain. Pulling wheels, tires and knocking back the sides of the rim out in the middle of BFE is no fun.
I've looked for Excel rims but can't find a direct fitment yet. What was the overall best solution for this? I don't wan to retrofit a 990 wheel on the front, but would rather find a suitable replacement wheel or at least rim.
BTW - I've had this 1190R for a year now and absolutely love it. Very capable on and off road. Just need to work out the niggles like the soft front rim.. And yes, this is my post #1 on this forum.
Cheers, Don A.
Kuala Lumpur, Malaysia
Baronsamedi is offline   Reply With Quote
Old 04-11-2014, 04:32 AM   #14
PS-RagE OP
PS-RagE's Avatar
Oddometer: 649
Woody's accepted my order for a set last week. 1.6" A60 front and 2.5" Takasago rear with billet hubs. They'll be the first set out-the-door for the 1190
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
Old 04-11-2014, 04:57 AM   #15
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,415
Rad manufacturing
Has hubs in the works. Rear is very close to the 990 but the front hub is a different animal. I believe woodys uses rad hubs for the builds ( other than the BMW hubs they make) Rad is about a month out for the hubs. Might have to swing down there and ask what they are doing.
Please hold
ebrew is offline   Reply With Quote
Times are GMT -7.   It's 03:39 AM.
