Old 08-16-2013, 07:03 PM   #1
bobframe OP
Oddometer: 320
Torque wrench with 1/4" to 3/8" adapter
I need to use my 1/4" torque wrench in a situation that requires 11Nm of torque. My wrench's range is from 6-32Nm...so it is my preferred tool since my 3/8" torque wrench's dial begins at 20Nm. I am using it to tighten an oil filter and the oil filter wrench requires either a 3/8" square drive or a 19mm socket, which I only have in 3/8". However, I do have a 1/4" to 3/8" adapter that would allow me to use the 1/4" torque wrench.
Anyone see a problem using a 1/4" torque wrench with such an adapter? Obviously the parts all connect and work...but any reason to doubt the wrench's accuracy with such a setup?
bobframe is online now   Reply With Quote
Old 08-16-2013, 07:22 PM   #2
emti
Oddometer: 254
Others may correct me but the only issue I can think of is that if the adapter is of a significant length there would be a loss of torque due to torsional losses? Maybe.... Its been a while. I believe there is a formula to correct the loss? emti
emti is offline   Reply With Quote
Old 08-16-2013, 07:38 PM   #3
KeithinSC
KeithinSC's Avatar
Oddometer: 1,443
Torsional loses due to twisting of the adapter would be negligible/non-existent at 11 N-m. That is barely a 'two finger' torque
There is noting to worry about using an adapter, we use them all the time and have no calibration issues.
KeithinSC is online now   Reply With Quote
Old 08-16-2013, 07:42 PM   #4
ZEmann
want to be riding
ZEmann's Avatar
Oddometer: 653
non issue
agreed
ZEmann is online now   Reply With Quote
Old 08-16-2013, 08:23 PM   #5
anotherguy
anotherguy's Avatar
Oddometer: 6,208
Yeah use it without worry.
you don't see luggage racks on a hearse..........act accordingly
Old 08-16-2013, 11:09 PM   #6
Imachimper
Newer than Noob
Imachimper's Avatar
Oddometer: 131
https://www.google.com/url?sa=t&rct=...50768961,d.aWc
Page 6. You can use an extension like a torque adaptor(see picture below) at a 90 degree angle. The extension and 1/4 to 3/8 converter will have no affect.
Imachimper screwed with this post 08-16-2013 at 11:15 PM
Imachimper is offline   Reply With Quote
Old 08-17-2013, 12:35 AM   #7
Beezer
Oddometer: 5,746
n o... it's the law...Newton's 3rd law, don't matter how long an extension is in the same plane, it does matter if the lever arm is changed though. Imachimper covered that
Beezer is online now   Reply With Quote
Old 08-17-2013, 05:03 AM   #8
bobframe OP
Oddometer: 320
Thanks guys!
Old 08-17-2013, 06:02 AM   #9
damurph
Cold Adventurer
damurph's Avatar
Location: The far east of the far east of North America
Oddometer: 1,756
I know I am not as fussy as some but it is an oil filter. Tens of thousands are put on daily and I have personally put on hundreds ....BY HAND.
Don't overdo it on the thinking or the torqueing.
R1150 GSA, KLR650, K75s, RD350, PS250 (Big Ruckus), R65, 990 Spyder
If I still had every dollar I spent on motorbikes I would be a richer man but a poorer person.
damurph is offline   Reply With Quote
Old 08-17-2013, 06:18 AM   #10
pelvis_98
Havin A Time
pelvis_98's Avatar
Oddometer: 1,979
I agree.
Putting on a oil filter doesn't have the that perfect a torque. Lots of people tend to over tighten them and then have a hard time getting them off.
pelvis_98 is online now   Reply With Quote
Old 08-17-2013, 10:01 AM   #11
DrDaytona
Oddometer: 101
Some filters aren't accessible by hand....in which case, I always recommend people use a torque wrench. Mostly because people do tend to get over zealous and tighten the crap out of them.
DrDaytona is offline   Reply With Quote
Old 08-17-2013, 10:23 AM   #12
damurph
Cold Adventurer
damurph's Avatar
Oddometer: 1,756
And I agree that people do just this.
Put your oil filter socket onto a 3/8 wratchet and grab it by the head of the wratchet. Spin. When you feel any resistance go a shade further and it is on.
By all means torque every nut and bolt to your hearts content. What procedure do you use on the road??? Sometimes you just have to get a feel for things.
Old 08-17-2013, 11:10 AM   #13
bobframe OP
Oddometer: 320
Completely agree and, in this case, I understand that hand tightening would work fine. But I have a new torque wrench and want an excuse to use it. The wrench's instructions had several warnings about using handle extensions and adapters and it was written in "pig-English"...hard to understand. Just wanted to understand the do's and don'ts of adapters. Thanks for all the help.
Old 08-17-2013, 12:29 PM   #14
Beezer
Oddometer: 5,746
does it have a floating handle? some beam type wrenches do... the handle pivots on a pin. if so, then the handle has to float during the check... if one of the ends contacts the beam it will be inaccurate. on the other types with solid handles it doesn't matter how you hold it. just an fyi
Old 08-17-2013, 01:35 PM   #15
bobframe OP
Oddometer: 320
It does not, but thanks for the info. Mine have solid handles like a "normal" ratchet wrench.
Times are GMT -7.   It's 05:21 PM.
