Old 08-17-2013, 10:23 AM   #1
GO_OUTSIDE! OP
dirty hippie
GO_OUTSIDE!'s Avatar
Oddometer: 292
Scottoiler lube or ATF and Oring chains?
I have an RK Xring chain that has thrown its orings in under 10,000 miles with no other signs of wear(stretching). The front sprocket has also worn down to nubs while the rear is beautiful.
I have been using a Scottoiler with the recommended alternative lubricant of ATF fluid. It is set up to keep the chain wet but not throw oil everywhere.
I am replacing the chain and sprockets today and am hoping to avoid having similar results.
Does anyone have any input?
If it helps, the chain the chain had 3 tight links from the beginning that never worked themselves out.
Thank you!
Now Go Outside!
GO_OUTSIDE! is offline   Reply With Quote
Old 08-17-2013, 10:55 AM   #2
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,336
If one listens to what Scottoiler states, one drop per minute is the optimal rate. The one drop of oil per minute is applied to the rear sprocket just inside the gear ring. ATF is a substitute oil; I am considering 2-stroke oil in my Scottoiler. There is always the option of contacting Scottoiler and asking them about your configuration and how it should best work.
Stan_R80/7 is offline   Reply With Quote
Old 08-18-2013, 08:35 AM   #3
GO_OUTSIDE! OP
dirty hippie
Oddometer: 292
looking around the internet I am hearing rumors of ATF "rotting" and "swelling" orings and therefore being an unsuitable replacement for oring chains. I have contacted DID and am awaiting their reply.
Thank you!
Now Go Outside!
Old 08-18-2013, 10:57 AM   #4
ohgood
ohgood's Avatar
Oddometer: 2,630
just see here
http://www.advrider.com/forums/showthread.php?t=345397
scrolling through the words to get to the pictures is cool, but i'm really just here for the tracks and waypoints... post some ok ?
ohgood is offline   Reply With Quote
Old 08-18-2013, 11:20 AM   #5
joexr
Oddometer: 3,773
Originally Posted by ohgood View Post
That guy and his threads are a joke.
Old 08-18-2013, 11:43 AM   #6
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,336
Contacting RK to ask why their o-ring disintegrated from ATF would be a good idea also. Most o-rings are Buna-Nitrile and have good compatibility with ATF. But, if it seems the o-rings are dissolving or swelling then a different oil is needed. Good luck!
Stan_R80/7 screwed with this post 08-18-2013 at 11:53 AM Reason: revised text
Old 08-18-2013, 12:01 PM   #7
BluByU
BluByU's Avatar
Oddometer: 497
When I had a Scott oiler on my old ZX I filled it with 20w50. Heck it was a Kawasaki so having a spare bottle of oil on hand was not unusual as she liked to sip her share. O rings never rotted out and the chain life was fantastic. Although the back of the bike was a mess
BluByU is offline   Reply With Quote
Old 08-19-2013, 09:07 AM   #8
GO_OUTSIDE! OP
dirty hippie
Oddometer: 292
I havent contacted RK but DID replied with "we have not tested the compatability of atf with our chains... use lube listed as safe for oring chains"
Thank you!
Now Go Outside!
Old 08-19-2013, 09:37 AM   #9
ohgood
ohgood's Avatar
Oddometer: 2,630
I scanned through a few pages, and didn't find a punchline.
do you have a better resource ?
Old 08-19-2013, 05:54 PM   #10
HapHazard
t00 0ld 2b n00b
HapHazard's Avatar
Oddometer: 2,231
It's hard to imagine that ATF "ate" the O-rings -automatic transmissions have lots of O-rings in them, no?
I don't use a Scottoiler, but I wouldn't lube any chain with ATF, though. It's very thin with low film strength.
I've been using Maxima (or other similar) chain wax products on my street bikes for years, and never had any O-rings vanish.
HapHazard is offline   Reply With Quote
Old 08-19-2013, 09:08 PM   #11
slidewayes
slidewayes
slidewayes's Avatar
Oddometer: 541
How dose any lube get past the O ring to the pin and the "ID" of the roler ,
slidewayes is offline   Reply With Quote
Old 08-19-2013, 09:18 PM   #12
AviatorTroy
AviatorTroy's Avatar
Oddometer: 1,627
I would be inclined to use some real oil, like Rotella or something cheap but known to be good.
AviatorTroy is offline   Reply With Quote
Old 08-19-2013, 10:03 PM   #13
joexr
Oddometer: 3,773
The pins are internally lubricated , hence the O-rings. Lubing is for the O-rings and the rollers. The rollers aren't sealed.
Old 08-19-2013, 10:07 PM   #14
joexr
Oddometer: 3,773
Yeah , ME. He made a good attempt , there just wasn't any experience or knowledge behind it.
Old 08-19-2013, 10:30 PM   #15
e.Rock
No Guts, No Story
e.Rock's Avatar
Oddometer: 211
I've been running ATF through my Scottoiler for I don't know how many thousands of miles... on the same chain. I always have mine set at the slowest drip rate.
Have you ever cleaned your chain with a non-safe solvent, like brake kleen, or mineral spirits?
e.Rock is offline   Reply With Quote
Times are GMT -7.   It's 07:27 AM.
