Old 08-18-2013, 07:39 PM   #1
GREY.HOUND OP
GREY.HOUND's Avatar
Oddometer: 349
Took the sportcity up over 9000' today
pics and a short report are here:
http://advrider.com/forums/showthread.php?t=912908
After the riding on the super bumpy road, I had some sputtering and stalling during Idle and also stalling few times in the parking lot on the stops home. My buddy suggested checking the spark plug so I did:
I'm no expert, but I think it needs to be replaced. I cleaned it a bit and stuck it back in. It seemed to do the trick, but I'll get a new one.
Love this bike.
'13 BMW C600
'09 Aprilia Sportcity 250
GREY.HOUND is offline   Reply With Quote
Old 08-18-2013, 08:16 PM   #2
longhaul747
Oddometer: 653
Probably would not hurt.
Even though many Aprilia's (if not Piaggio products in general) come from the factory and spec a champion plug I would suggest that you replace it with an NGK equivalent plug. It has been reported that you will get smoother idle and it will be a little less cold blooded in the SportCity 250's. Also NGK plugs will usually outlast a champion plug by a significant margin. Champions are not necessarily bad but they are not real good for single cylinder power sport products.
longhaul747 is online now   Reply With Quote
Old 08-18-2013, 10:44 PM   #3
Chillis
Iron toocus
Chillis's Avatar
Oddometer: 3,838
Plug looks pretty good to me without seeing down further into the porcelain.
If bumpy riding caused problems you may want to drain the float bowl as you could have dirt floating in there. Possibly an issue with dirt causing the float to stick open. Also good to check oil level just in case.
Originally Posted by Skowinski View Post
Speaking of dumps, that coffee is working for sure, gotta scurry and perch on the thundermug...
Chillis is offline   Reply With Quote
Old 08-18-2013, 11:05 PM   #4
JerryH
Oddometer: 5,069
Plug looks fine to me. You might want to clean and regap it. It's not fouled, shows no sign of rich running, and from what I can see of the insulator, it looks about the right color.
JerryH is offline   Reply With Quote
Old 08-19-2013, 06:35 AM   #5
klaviator
klaviator's Avatar
Oddometer: 6,249
My Kymco dealer told me to use NGK, not champion plugs. I don't remember what I put in my SC but most likely it's an NGK as well.
I ride, Therefore I Am.
klaviator is online now   Reply With Quote
Old 08-19-2013, 07:12 AM   #6
GREY.HOUND OP
GREY.HOUND's Avatar
Oddometer: 349
Thanks for the advice. I will look into the NGK spark plug.
'13 BMW C600
Old 08-21-2013, 09:44 PM   #7
blugg1
Oddometer: 490
Yeah, plug looked fine to me also. Gap seemed a bit wide, but hard to tell from a photograph.
Also, NGK is the way to go.
2014 Kawasaki 300 Ninja, 2012 SYM HD200 EVO
blugg1 is offline   Reply With Quote
Times are GMT -7.   It's 10:37 AM.
