Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 08-22-2013, 02:02 PM   #1
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,007
CNNA 2014.2 has been released.
If I can get the updates to work.
Old 08-22-2013, 09:02 PM   #2
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,523
You might find some info to help you in one of the posts of the WaFT.
Emmbeedee is online now   Reply With Quote
Old 08-22-2013, 09:19 PM   #3
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,007
Thanks. I think my problem was that although I had bought the lifetime update card, I had failed to assign it to a unit (the Montana) so it wouldn't work. Managed to assign it through "my dashboard" and am now attempting to load the maps via the old right-click on Montana internal memory in BaseCamp. Fingers crossed.
Old 08-22-2013, 09:28 PM   #4
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,523
I've never heard of right clicking the map in Basecamp to update it. I find the only successful method is through the Mapupdater software I linked to in the WaFT.
Old 08-23-2013, 06:23 AM   #5
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,007
I think BaseCamp calls the map updater software when you do this. I right-click on "Internal storage" then select "Install maps on..."
But, although it did successfully load 2014.2 to the unit, it did NOT remove 2014.1, even though the software claimed it would remove older versions. Any thoughts about what I should do, if anything?
Old 08-23-2013, 06:39 AM   #6
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,523
You can probably just delete it via mass storage mode. That's what I do.
Old 08-23-2013, 06:54 AM   #7
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,007
Worth a shot. I'll hook it up and see if I can figure out the correct file to delete.
ETA: Ok, that was easy. It had 2014.1 in the filename.
Old 08-24-2013, 09:27 AM   #8
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,464
I thought that pic just called MapInstall? Which would mean you'd have to have already installed the Maps to BaseCamp in order to install them on the Montana with MapInstall.
You folks on the East Coast must be special - I still don't see 2014.20 LM update on the Garmin site.
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 08-24-2013, 09:51 AM   #9
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,007
The sun rises on us first, too.
Well, my installation process was maybe a little unusual because I have both a Zumo 350 and a Montana with "lifetime" maps. I had done the map install for the computer and Zumo before I grabebed the Montana to update its maps. So, yes, the map set was already on the hard drive.
Old 08-24-2013, 03:41 PM   #10
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,523
That makes more sense. I didn't think Basecamp could make a map update call.
Old 08-24-2013, 03:49 PM   #11
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,007
I started the whole thing off by hooking up to the Garmin "my dashboard" because that has been an easy way to get GPS software updates. For no particular reason, it has been my habit to always do the Zumo first, followed by the Montana. I had read in the big Montana thread about 5.30(?) being out, so thought I'd hook up and check both GPS units because maybe there would be a Zumo update too (there wasn't), but was surprised to see that it listed my maps as out of date, so off I went.
Old 08-26-2013, 04:30 PM   #12
PhilSpace
The Gov
PhilSpace's Avatar
Oddometer: 35,351
So far I'm good to go on everything but the old zumo 550. In the past, there has always been the option to select a paired down region that met my requirements, this time there was no eastern seaboard option, so I'm trying to figure out how to blow away what is on the GPS so I can selectively install what I want.
PhilSpace is offline   Reply With Quote
Old 08-26-2013, 10:21 PM   #13
lhendrik
Truffle Rustler
lhendrik's Avatar
Oddometer: 2,327
Do you have an SD memory card installed in the Zumo? If so, and if you have the space you can load the entire file in a Garmin folder on the SD card, and then select the map file you want to use. An inexpensive 8gb card holds both US and Europe for me.
Normal is just a setting on the dryer.
2009 R1200GS A, 2008 K1200GT
lhendrik is online now   Reply With Quote
Old 08-27-2013, 07:26 AM   #14
PhilSpace
The Gov
PhilSpace's Avatar
Oddometer: 35,351
Thanks, I didn't need the entire thing, the new Express Update didn't give me the selective options I wanted. Solution from Garmin was to use the old trusty Map Update program which is still out there and works. The two options are to take one of the regions that it provides (there are a couple more), or download the entire mess to the PC and use the Mapinstall program to select what I want.
I'm good to go now, didn't want the world, just the eastern US and CaNaDa.
Old 09-02-2013, 06:21 AM   #15
Too Tall
Too Tall's Avatar
Oddometer: 184
Is the new City Navigator NA 2014 available on CD yet for loading onto a PC?
www.2wheel-adventure.blogspot.com
2014 KTM 350EXC-F
2012 Triumph 800XC
2010 KTM 990 SMT
2007 Suzuki DR650
Too Tall is offline   Reply With Quote
Times are GMT -7.   It's 09:20 PM.
