Old 08-23-2013, 07:54 PM   #1
adrenal OP
skrunkwerks.com
adrenal's Avatar
Oddometer: 529
DIY dyno build
Here's the design of an inertia dyno I'm currently building:
The inertia of the main wheel has been designed to suit bikes form the last century - 70's-80's. Mainly airheads. The red wheels can be installed when more powerful bike are being tested. The build is about 70% complete..
Adrian
cafebeemer is now:http://www.skrunkwerks.com
farcebook page: http://facebook.com/skrunkwerks
instagram: #skrunkwerks
adrenal is offline   Reply With Quote
Old 08-23-2013, 08:22 PM   #2
adrenal OP
skrunkwerks.com
adrenal's Avatar
Oddometer: 529
lump O steel
almost 1/2 tonne K1045 steel! OD460mm x 300 wide
Drilling pilot hole for boring:
Boring to final ID:
Adrian
adrenal screwed with this post 08-24-2013 at 03:39 AM
Old 08-23-2013, 08:44 PM   #3
_cy_
Oddometer: 6,057
holy cow.. what a lathe!
_cy_ is online now   Reply With Quote
Old 08-23-2013, 08:50 PM   #4
adrenal OP
skrunkwerks.com
adrenal's Avatar
Oddometer: 529
yeah, don't want to get your tie caught in that one!
Adrian
Old 08-23-2013, 09:14 PM   #5
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,601
Oh, man this is gonna be good!
crazydrummerdude is offline   Reply With Quote
Old 08-23-2013, 10:15 PM   #6
dhallilama
Oddometer: 451
um. i've built plenty of my own equipment and such... but this is friggin' awesome. just. plain. awesome.
dhallilama is offline   Reply With Quote
Old 08-23-2013, 10:19 PM   #7
downdog
downdog's Avatar
Oddometer: 44
You just got this stuff lying around in your shop?
Cool!
downdog is offline   Reply With Quote
Old 08-23-2013, 10:20 PM   #8
k-moe
Oddometer: 2,590
Hmmm... I was hoping to see that lump being spun on a mish-mash of trailer tires driven by a pickup on a jackstand, and you working the OD with a file. Where is the adventure in doing things the right way?
k-moe is offline   Reply With Quote
Old 08-23-2013, 10:42 PM   #9
pommie john
pommie john's Avatar
Oddometer: 1,428
How are you going to calibrate it?
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 08-23-2013, 11:18 PM   #10
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,083
Dang! The initial post looked pretty unsubstantial - maybe something I could build.
No way, Jose!!
Old 08-23-2013, 11:48 PM   #11
victor441
victor441's Avatar
Oddometer: 899
VERY cool! something I'd mused about myself, will be following this with much interest...
victor441 is offline   Reply With Quote
Old 08-24-2013, 12:38 AM   #12
adrenal OP
skrunkwerks.com
adrenal's Avatar
Oddometer: 529
I've seen those rigs - much harder to improvise like that I reckon.
@pommiejohn. good question.Inertia dynos are not hard to calibrate. A matter of calculating the polar moment of inertia of the lump and plugging into the dyno software. Then there are ways of determining friction losses through the bearings etc and plugging these into the software as well.
But as final tweak/check, after a run on the dyno I'm going to ride straight over to a 'real' dyno which I know is well calibrated and compare numbers.
Adrian
adrenal screwed with this post 08-24-2013 at 02:21 AM
Old 08-24-2013, 01:54 AM   #13
adrenal OP
skrunkwerks.com
adrenal's Avatar
Oddometer: 529
While better machinists than me were producing big chips, I started on the frame:
Adrian
Old 08-24-2013, 03:08 AM   #14
pommie john
Oddometer: 1,428
I remember reading that Dynojet just couldn't get the calculations to match the readings, so they measured a known bike and used that as a starting point. ( I think that's what happened).
One thing to bear in mind ( that every dyno place I've been to in Brisbane ignores) is airflow through the dyno room. A 1000cc motor on full song flows thousand of litres of air through it each minute and it needs a good supply of fresh air delivered to the room.
Most dyno operators don't seem to realise this. I was at one place and we kept getting inconsistent readings that didn't make sense. We went back to the original jetting and didn;t get the same power curve. Then we noticed that our eyes were watering and stinging and it turned out that we had used up lots of the oxygen in the dyno room and that was making it run rich. Opening the doors and flushing the room with fresh air got us back to consistent reading. We ended up running with the doors open and finally got readings that made sense.
Bertrand Russell
Old 08-24-2013, 03:35 AM   #15
adrenal OP
skrunkwerks.com
adrenal's Avatar
Oddometer: 529
Originally Posted by pommie john View Post
.............Opening the doors and flushing the room with fresh air got us back to consistent reading. We ended up running with the doors open and finally got readings that made sense.
Interesting. Yep consistency and repeatability is key. In my book, the accuracy of the absolute HP number is far less important than knowing if your mods are heading in the right direction and by how much in percentage terms.
I've drawn up a dyno room. It has a huge ducted fan cooling the bike that pulls gob loads of air from outdoors. Sounds like a jet turbine!
Adrian
Times are GMT -7.   It's 02:01 AM.
