Old 08-24-2013, 02:57 AM   #16
ontic
Oddometer: 1,070
I can't wait to see this thing, that lathe work is wild.
What kind of surface is the main wheel going to have? Thinking about grip and tyre traction...
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 08-24-2013, 03:23 AM   #17
mousitsas
mousitsas's Avatar
Oddometer: 2,772
Very interesting built. Only 'objection' I might have is that it is inertial so you can't have measurements at constant rpms, but I don't know how important this is.
Old 08-24-2013, 05:54 AM   #18
anotherguy
anotherguy's Avatar
Oddometer: 6,387
An inexpensive upgrade for you. Next would be a load controller for steady state EFI mapping.
you don't see luggage racks on a hearse..........act accordingly
Old 08-24-2013, 05:55 AM   #19
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,671
great stuff
Or you could go the Norwegian way
Rob Farmer is offline   Reply With Quote
Old 08-24-2013, 05:58 AM   #20
adrenal OP
skrunkwerks.com
adrenal's Avatar
Oddometer: 555
The lump has 4mm machined cross grooves. All will be revealed !
Adrian
cafebeemer is now:http://www.skrunkwerks.com
farcebook page: http://facebook.com/skrunkwerks
instagram: #skrunkwerks
adrenal is offline   Reply With Quote
Old 08-24-2013, 06:15 AM   #21
adrenal OP
skrunkwerks.com
adrenal's Avatar
Oddometer: 555
I chose the inertia style because it is easiest to build. Basically just a mass spun by the back wheel. Same as that crazy Norwegian rig where the truck wheels are the mass. A brake or absorption dyno is what's needed to work out maps for EFI or an ignition curve for a particular cam.
You can do this sort of work after a fashion with inertia dyno but it is not ideal.
Adrian
adrenal screwed with this post 08-26-2013 at 04:36 PM
Old 08-24-2013, 03:35 PM   #22
adrenal OP
skrunkwerks.com
adrenal's Avatar
Oddometer: 555
The shaft
The sword of damocles. By design, almost 0.1mm (4 thou) interference between the shaft and the bore!!
How the F*#k are we going to get this puppy in?
KY just ain't goin to cut it.
Adrian
adrenal screwed with this post 08-24-2013 at 04:19 PM
Old 08-24-2013, 06:27 PM   #23
_cy_
Oddometer: 6,271
liquid nitrogen on center shaft .. heat up lump o steel ..
yeooooowwww .. what a press fit!
construct an I-beam structure to support a 20ton hydraulic jack.
assuming you don't have a big honking press ...
_cy_ screwed with this post 08-24-2013 at 06:35 PM
Old 08-24-2013, 07:38 PM   #24
adrenal OP
skrunkwerks.com
adrenal's Avatar
Oddometer: 555
Got it in one Maestro, but no press
I'll post some pics soon.
Adrian
Old 08-25-2013, 04:14 AM   #25
adrenal OP
skrunkwerks.com
adrenal's Avatar
Oddometer: 555
crunch time
While the shaft set the liquid nitrogen furiously boiling, I got to work heating the lump. After 20 minutes, the boiling stopped, signalling that both liquid and metal were at the same temperature: -196C or -385F.
Still lots of heating to do - over an hour.
Tense moment: if we didn't get things right the shaft could seize part way down.
The money shot!
Adrian
adrenal screwed with this post 08-25-2013 at 04:25 AM
Old 08-25-2013, 06:12 AM   #26
anotherguy
anotherguy's Avatar
Oddometer: 6,387
Nice to see someone do what's needed the simple way. Good on ya.
Old 08-25-2013, 06:39 AM   #27
_cy_
Oddometer: 6,271
The money shot!
WOW ... Good Job!!!!!!!
shaft is probably stronger from the cryogenic treatment....
Old 08-25-2013, 06:05 PM   #28
adrenal OP
skrunkwerks.com
adrenal's Avatar
Oddometer: 555
Thanks CY. It was ubernerd fun
Adrian
Old 08-27-2013, 08:36 AM   #29
drhach
gorillamanufacturing.com
drhach's Avatar
Oddometer: 2,421
Is this really cheaper/easier than building a brake dyno?
1976 R90/6
1972 XLCH
2010 Triumph Thunderbird SE
drhach is offline   Reply With Quote
Old 08-27-2013, 08:51 AM   #30
dom1104
dom1104's Avatar
Oddometer: 354
This is awesome. I love this.
dom1104 is offline   Reply With Quote
Times are GMT -7.   It's 08:06 PM.
