Old 08-28-2013, 05:00 PM   #46
adrenal OP
skrunkwerks.com
adrenal's Avatar
Oddometer: 555
Thanks for the heads-up CY. Great VID that!
Adrian
cafebeemer is now:http://www.skrunkwerks.com
farcebook page: http://facebook.com/skrunkwerks
instagram: #skrunkwerks
adrenal is offline   Reply With Quote
Old 08-28-2013, 05:37 PM   #47
_cy_
Oddometer: 6,271
can't wait to see pic's of this beast in action!
Old 08-29-2013, 02:23 PM   #48
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,813
....is it time to ask if you would ship it to Rhode Island so that I can test my bike......
... freekin' amazingly awesome!!
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 08-29-2013, 03:46 PM   #49
pommie john
pommie john's Avatar
Oddometer: 1,455
He'll be too busy bringing it around Australia.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 08-29-2013, 03:54 PM   #50
adrenal OP
skrunkwerks.com
adrenal's Avatar
Oddometer: 555
It's only got one wheel! You guys have the two wheeled machines. Much easier for you to come to me...
Adrian
Old 09-01-2013, 05:22 AM   #51
adrenal OP
skrunkwerks.com
adrenal's Avatar
Oddometer: 555
Bolting it together
pretty pumped about getting it together:
Adrian
Old 09-02-2013, 01:15 PM   #52
_cy_
Oddometer: 6,271
OOOOoooohhhh ... NICE!!!!
_cy_ screwed with this post 09-02-2013 at 01:28 PM
Old 09-02-2013, 07:46 PM   #53
cam14
Oddometer: 181
The level of quality in your work and execution are very impressive. I have a question based upon my experiences with dyno tuning my race car. Under load, I adjust fuel pressure for better air/fuel ratio (I have a wide band) and I adjust ignition timing; per the rules, not allowed to adjust much else. I can tell if the changes I made were good or not based on the torque and horse power curves. So back to the question, does your inertia dyno have a way to measure TQ and HP? If yes, then how? If no, then how will you use your dyno?
TIA
cam14 is offline   Reply With Quote
Old 09-03-2013, 12:16 AM   #54
pommie john
Oddometer: 1,455
Originally Posted by cam14 View Post
......... So back to the question, does your inertia dyno have a way to measure TQ and HP? If yes, then how? If no, then how will you use your dyno?
TIA
Inertial dynos measure the rate of change of speed of the drum which is proportional to the torque at the rear wheel. If you measure at short enough intervals and read the RPM of the motor at the same time you have enough information to measure torque and from torque and RPM, you ( or your computer ) can calculate horsepower.
Bertrand Russell
Old 09-05-2013, 07:05 PM   #55
adrenal OP
skrunkwerks.com
adrenal's Avatar
Oddometer: 555
TIA
Thanks for your kind words.
The inertia dyno produces torque V HP V AFR curves just like all dyno's. I think you'll find that many commercial dynos out their are the inertia type simply because they are cheaper. Some do both.
So you must be using a brake or absorption style dyno if you are twiddling while the bike/car is being held at steady state at a particular RPM. As you describe, that's the big advantage of these types of dyno.
With an inertia dyno, you have to do a run (typically 6-12 seconds), check HP TQ, AFR etc along the curves for a series of RPM's, twiddle, then do another run to check the result, then repeat
The advantage of inertia dyno aside from cost is that it more accurately replicates the conditions that the machine will see on the road which is why they are also called rolling road dynos. Particularly if the rotating mass is well matched to the machine which is what I've tried to do - we'll see what happens at the first pull! Inertia dynos also stress the machine less since run time is generally shorter.
Hope this explains things.
Adrian
adrenal screwed with this post 01-23-2014 at 06:21 PM
Old 09-05-2013, 08:55 PM   #56
ttpete
Rectum Non Bustibus
Oddometer: 5,948
The biggest problem with an inertia dyno is that you can't do steady states and really tailor make an effective throttle opening vs. rpm fuel map. It's fine for a WOT max acceleration study, but there's a lot in between that needs to be addressed.
15 BMW RnineT
09 Kaw Versys
Old 09-05-2013, 09:31 PM   #57
Beemerboff
Oddometer: 2,303
If he had a Monolever a clever/knowledgeable man could link a strain gauge on the bottom link to an accurate rev counter, and on to a bit of electrickery, and get a reading , on the move, which would combine both inertia and brake dynos, that is instant HP at any given revs, and also the rate of change.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 09-05-2013, 11:55 PM   #58
weldingrod
Oddometer: 80
You lost me there Dude...but it sounds very impressive. All in all, anything which can help you measure modifications, be it benefit or detriment, helps with the learning curve....and if you get an instantanious read out, it all moves the process along faster.
weldingrod is offline   Reply With Quote
Old 09-06-2013, 08:02 AM   #59
ttpete
Rectum Non Bustibus
Oddometer: 5,948
You're still limited to transient data. It's not possible to run steady states, and that's how most development work is done. You could couple that drum to a water brake and have a more versatile rig.
15 BMW RnineT
09 Kaw Versys
Old 09-06-2013, 05:19 PM   #60
Beemerboff
Oddometer: 2,303
You could just put it on the centrestand and run it against the back brake, for a steady speed measurement.
And a pendant might point out that as torque can only be measured at a steady speed , UNLESS YOU MEASURE AT STEADY SPEED YOU AINT ACTUALLY MEASURING HORSEPOWER.
They are still a useful tuning/ comparative tool, which is what they are intended to be , but a 62 BRAKE HP Vincent will outperform most 120 INERTIA HP bikes.
Times are GMT -7.   It's 01:59 PM.
