Old 08-27-2013, 07:29 PM   #1
Armen OP
wrenchjockie
Oddometer: 29
Dyna weight loss project
Trying to drop 100 lbs off a 2001 Dyna FXDXTS. That's the pseudo sport touring HD. A bunch of stuff on the maybe list, some of it centering around the brakes. So.... before looking at the brakes, the wheels cry out for attention.
Looking for leads on lighter weight mag (tubeless) wheels. Bolt-on or at least semi-bolt on. Don't mind doing a bit of machining, but don't want a parrot-to-cat conversion.
Aftermarket? Other HD wheels? Other brands?
Appreciate any leads, experience, or info.
Not asking for permission, only information.
thanks,
-Armen
If you make a man a fire, he'll be warm for the rest of the day.
If you light a man on fire, he'll be warm for the rest of his life
Armen is offline   Reply With Quote
Old 08-28-2013, 03:27 AM   #2
Kennon
Kennon's Avatar
Oddometer: 323
you really want to save weight on the wheels look at BST carbon's they are used on the Confederate X132 Hellcat allot of tests with these wheels on superbikes due to the savings in weight made the bike lap 1 second a lap quicker than before, I'm not sure if they do never done much research into HD as I'm more a sport's orientated rider perhaps you can also get carbon fibre fairing replacements to save more weight.
If you really want to get as much weight off as possible could swap out all the mounting bolts for Titanium ones seen guys do it on my bike to save some weight plus means there easier to remove after a couple of years with its corrosion resistance.
Kennon
2009 Yamaha Jog 50RR LC sold 2011
2011 Rieju Marathon Pro 125 SM sold 2013
1990 Honda VFR 400 NC30 purchased 2013
Kennon is offline   Reply With Quote
Old 08-28-2013, 04:46 AM   #3
Armen OP
wrenchjockie
Oddometer: 29
Bst
Yes, I know those wheels. Amazing, but about $5K for the pair. And lots of fabrication to custom fit them.
Looking for something a little less effort :)
Old 08-28-2013, 08:45 AM   #4
tntmo
Oddometer: 533
If you want to install different wheels that require less effort, you are pretty much stuck using Harley wheels. I'm not sure how much weight savings would be involved. Light = expensive in the motorcycle world.
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 08-28-2013, 04:50 PM   #5
RedRaptor22
Oddometer: 161
For wheels it should'nt be too hard to knock some weight off, if you don't mind going with spoke wheels, go with some aluminium hoops and it should knock off quite a bit right there.
Plus looking at all the superficial parts is really worth it, as cruisers are mostly superficial parts, think fender supports and such, the fenders themselves can loose a lot of weight by going with fiberglass ones.
Even the controls are fifty times more porky than they need to be, master cylinders don't need to weight 3 pounds to work, handlebars don't need to be schedule 40 1 1/8 tube.
You can pretty much lose weight everywhere on those things depending on what you want to fabricate.
RedRaptor22 is offline   Reply With Quote
Old 08-28-2013, 05:06 PM   #6
Armen OP
wrenchjockie
Oddometer: 29
stuff
I was planning on making as much stuff out of unobtanium and drillium as I can. What I was looking for was someone saying "Try XYZ aftermarket wheels. Ten pounds less and only $1K each".
Performance Machine and a few others make wheels. Most of the websites are pretty painful, and weight is not real detailed, as the HD crowd seem to think bigger/heavier is better.
Supertrapp 2-1 is on order. System weighs pounds less and we ditch the bridge abutment holding the existing 2 muff system together.
Doing the headscratching on a single 6 piston caliper (and lighter rotor) to replace the dual disc boat anchors. Prob 10 lbs off.
When the battery dies, it'll get swapped for a Shorai. 10-20 lb off.
Rear rotor is being swapped for a Wave. A few pounds.
Footpeg brackets are insane. Fenders are made of deckplates from the SS United States.
I think 100 lb loss is possible without selling organs.
Weighed in at 666 lbs with most of a tank of gas.
Still waiting for some moron to say 'Just go on a diet!' It seems to always happen with bike-lightening threads.
Old 08-28-2013, 05:17 PM   #7
Kennon
Kennon's Avatar
Oddometer: 323
ahh you don't need to go on a diet look what has happened in moto2 with the minimum weight raised riders who were starving themselves to save weight are at a healthy weight now and can put more strength into hussling there bikes about, even with lightening a HD will still be heavy.
Kennon
Old 08-28-2013, 05:23 PM   #8
Armen OP
wrenchjockie
Oddometer: 29
Weight
Have to say, the bike as it is now works pretty well. If I can get it down to 550 lbs, it'll be faster, handle better, stop better, get better MPG and be right in the hunt weight-wise for a big sport tourer.
Old 08-28-2013, 10:23 PM   #9
yokesman
Oddometer: 530
can that beast of a motor be hung in a buell tube frame,they are 130 lbs lighter than the same engined sportster.
yokesman is offline   Reply With Quote
Old 08-29-2013, 07:23 AM   #10
Armen OP
wrenchjockie
Oddometer: 29
uh, Yoke?
I guess you could more completely miss the point, but only if you really tried.
Put a big twin motor in a Buell chassis to make a touring bike and devote my life to it? And have what when I'm done?
I'm looking for a tummy tuck you're proposing a sex change :-0
Old 08-29-2013, 08:43 AM   #11
XT_Driftwood
XT_Driftwood's Avatar
Oddometer: 598
I'll be watching this thread with interest. I have the same bike but mine has gotten heavier over the past couple years, if anything (come to think of it, so have I).
I'm pretty happy with the performance as it is but a better power to weight ratio is always welcome.
'83 XT550 - once the bane of my existence, now considered to be the pinnacle of reliability and engineering excellence
'85 GPz 750 Turbo
'01 Harley T-Sport
'99 Cagiva Gran Canyon - the bane of my existence
XT_Driftwood is offline   Reply With Quote
Old 08-29-2013, 09:46 AM   #12
yokesman
Oddometer: 530
This forum as all about info,more-buell cyclone has a 6 puck brembo cali,no sex change, the buell frame is made of chromoly-not wimpy.
anyway you have something in mind, the ideal DYNA. i throw out info if it doesnot fit well but something has been added,HD doesnot design lightness and gave you a basic example,look at all the oversized parts,even in al they are not helping your idea. i have 2 shocks to try on my build up one the gszx1000 is half the weight of the other-hayabusa.
woodies wheels could tell you how much you can save on going to alloy spoked wheels-if you like,i like mine tubeless ,so no go for me but i will be in the boonies 2up.I donot like plastic ,but i have a plastic oh japanese bike.
Classic brit bikes had some nice al fender and parts,easily gotten as they are going nuts over there restoring and building new bikes-engines included.
But all this is just to increase your inventory of possibilities.
By the way, i would not make that suggestion on an HD forum.
the dyna dry was specd at 597 lbs dry,639 lbs wet,which weight are you going for? myself if it was my bike i would just ride it and make changes over time.
see this,http://www.advrider.com/forums/showthread.php?t=515443
Old 08-29-2013, 10:05 AM   #13
Lizrdbrth
Wackjob
Lizrdbrth's Avatar
Oddometer: 865
Watching with interest, as I do all lightening threads. If done right it is ALWAYS worth doing, regardless of bike.
When your starting point is an HD there's nowhere to go but down, so ta speak.
Is there enough available real estate on a Dyna to go to a spun aluminum oil bag?
Lizrdbrth screwed with this post 08-29-2013 at 10:25 AM
Lizrdbrth is offline   Reply With Quote
Old 08-29-2013, 01:27 PM   #14
Armen OP
wrenchjockie
Oddometer: 29
Steps
Ordering a single caliper HD master tonight. Found an EBC rotor for not scary money. They come in wide and narrow band. I believe the PM 6 pot caliper would qualify for the narrow band rotor, but I'll order it first and take a looksee before ordering the rotor.
A bunch of the Glides had a single 4 piston caliper. Gotta figure a top shelf 6 pot will do the job.
Time to dust off the digital scale : )
-Armen
Old 08-29-2013, 03:49 PM   #15
RedRaptor22
Oddometer: 161
-Armen
Well I'm not sure about what bolts up and what does'nt but I know most aftermarket calipers are just prettied up copies of nissin and tokiko calipers and use the same pads and rebuild kits as suzuki and kawasaki sport bikes.
I have seen people swapping supersport calipers onto the rear of their cruisers, given most were japanese it's a little different.
But most of the suspension and brake parts harley uses is japanese too...so maybe some good used super sport parts may bolt right up and save you tons of money on restyled parts that are internally the same?
Some quick googling yielded:
http://www.hdforums.com/forum/dyna-g...e-upgrade.html
http://www.harley-davidsonforums.com...e-upgrade.html
RedRaptor22 screwed with this post 08-29-2013 at 05:11 PM
Times are GMT -7.   It's 11:45 AM.
