Old 08-27-2013, 09:39 PM   #1
thesurvivalist OP
Backcountry Rider
thesurvivalist's Avatar
Oddometer: 551
Jetboil and other small stoves
Im looking to purchase a small propane stove for boiling water. I like the jet boil but does it require special jetboil canisters*or can I use regular propane canisters?
Also are there any cheaper alternatives to the jetboil? I need something rugged for military use.
2008 Buell Ulysses Xb12X
2015 Honda PCX
Custom Leather Work-Made In England www.lordofleather.com
thesurvivalist is offline   Reply With Quote
Old 08-27-2013, 09:54 PM   #2
mookybird
Gramps
mookybird's Avatar
Oddometer: 213
The jetboil uses a standard thread canister and any of them will work fine.
In comparison to many others the Jetboil is bulky. heavy and a bit expensive but I don't regret buying mine and it gets hauled along more than the others just because it's very easy to use.
mookybird is offline   Reply With Quote
Old 08-27-2013, 10:01 PM   #3
Pokey66C23
Oddometer: 481
jetboil
I've used a jetboil for years, did 260 miles of backpacking a few summers ago with my kids. Worked great for sometimes 5 of us sharing one stove.
The propane/butane mix works well in higher elevations/colder conditions than straight propane in the Jetboil.
For snow camping I use a white gas powered MSR. The snow peak stoves are nice and light especially the TI one.
Pokey66C23 is offline   Reply With Quote
Old 08-27-2013, 10:02 PM   #4
steveWFL
steveWFL's Avatar
Oddometer: 1,344
lovin' the jetboil
KTM EXC - in 530 flavor
'10 Concours14 with >85,000 miles and ticking'
'99 ZX9R Ninja - rolling retro style
'99 ZX9R - because I like the other one so much
'08 ZZR600 minty
steveWFL is offline   Reply With Quote
Old 08-27-2013, 10:12 PM   #5
Hikertrash
Oddometer: 2,913
I've got the jetboil, and don't mind carrying it since I only boil water with it. However, I was turned onto this stove from another inmate and may purchase one if I decide to carry a mess kit.
http://www.ebay.com/itm/310406431284...84.m1423.l2649
Hikertrash is offline   Reply With Quote
Old 08-28-2013, 05:35 AM   #6
Carluset
Carluset's Avatar
Oddometer: 25
Hi!
I borrowed a Jet Boil for my last trip and I liked it a lot, except that the valve wasn't precise when I tried to put it to the minimum. It get closed (or not enough gas for a flame) and I had to adjust it every few minutes.
Is this a problem of my unit?
Carluset is online now   Reply With Quote
Old 08-28-2013, 05:53 AM   #7
nonamehorse
Concrete Jungle
nonamehorse's Avatar
Oddometer: 207
I carry a Jetboil on my motorcycle and mountain bike. They are a bit on the bulkier side, but super easy to use and boil up quick--no fuss no muss. If you're a caffiene junkie, get the french press lid accessory and bring your favorite grind. It brews a great cup o'joe. Use white gas stoves in the winter, the butane doesn't do well in colder temps.
nonamehorse is offline   Reply With Quote
Old 08-28-2013, 06:30 AM   #8
1911fan
Master of the Obvious
1911fan's Avatar
Oddometer: 3,224
Another idea: this is one, but there are several variations on the theme of small, folds flat, burns debris:
http://wildernessinnovation.com/surv...folding-stove/ I'm looking at getting one for simplicity, though I've been using the MSR Whisperlite for over 25 years. Same one.
1911fan
Read The Patriot Post -- It's Right. It's Free.
http://patriotpost.us/subscribe/
Sometimes the light to see your way forward is provided by the bridge burning behind you.
1911fan is offline   Reply With Quote
Old 08-28-2013, 06:43 AM   #9
Chisenhallw
Avowed Pussbag
Chisenhallw's Avatar
Location: I've narrowed it down to 'earth'. Or 'Baltimore'.
Oddometer: 6,298
I really like my swedish camp stove. Ten bucks.
2001 Kawasaki Concours 2001 Suzuki SV650
MD ABC TOR...I review motorcycles for 2wheelsandamotor.com
Chisenhallw is offline   Reply With Quote
Old 08-28-2013, 11:39 AM   #10
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 6,088
They were/are extremely popular with troops in Iraq and Afganistan.
Check out jetboil.com for some really good camp recipes for the jetboil. My favorites are 'oink-oink cooscoos' and upside down peach cobbler. Simmering can be fussy but do-able.
The bigger cannister costs like a buck more - won't fit in the pot but lasts and lasts and lasts.
IMO they're the best invention ever. From 15% efficiency of a regular stove to 85% efficiency with the flux ring jetboil. They just work fantastic. The inventors should be rich!
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is offline   Reply With Quote
Old 08-28-2013, 11:52 AM   #11
groop
So much to ponder
groop's Avatar
Oddometer: 3,287
Because you cannot eat a salad with a spork.
groop is online now   Reply With Quote
Old 08-28-2013, 11:55 AM   #12
Farkler
Farkler's Avatar
Oddometer: 16
MSR Pocket Rocket
Just to throw one more idea out there, I use the MSR pocket rocket. It is just a few ounces, fits in a little triangular container a few inches long and is essentially idiot proof. I've used it on several back country camping trips as well as some of my longer rides in the past two years. Uses standard Isopro fuel available at walmart and lights very quickly. At $40 or so, it's hard to go wrong with it!
Just my 2 cents.
Ride on.
Farkler is offline   Reply With Quote
Old 08-28-2013, 01:07 PM   #13
sagedrifter
Southern Explorer
sagedrifter's Avatar
Oddometer: 1,453
Yes, it uses a different canister. Its not a propane device per say. JetBoils and other compact stoves use a butane fuel mix. I burn iso-butane with propane mixed in. Its a good all weather mix. Walmart has the 220g canisters at $4.88 per and I've found the fuel blend works well year round. If you shake the canister before using it the fuel stays blended a bit more. I burn mine till its all gone even in freezing weather.
Walmart also has a compact stove for $28, use it with the Stanley 24 oz mess kit at $15 as a cheap and useful alternative to other $80 devices. Slide a $4 18 oz stainless cup over the Stanley and it makes for a nice piece of kit. Stove fits inside with tea, coffee etc..
There is also the Stever stoves that burn Yellow bottle Heet and weigh almost nothing. Sold right here on the forums.
I do go back to my Coleman butane stove the most on the bike because the added weight doesn't matter and its still plenty small to pack. If I'm back packing I prefer the ultra light Stever set up, the more you use it the lighter the load. Fuel bottles are very light weight.
sagedrifter is offline   Reply With Quote
Old 08-28-2013, 04:18 PM   #14
fatboy
Oddometer: 312
Love my jetboil. However, I find its either on or off. So, it brings stuff to a boil fast. Perfect tool for making hot water you can use: coffee, tea or anything you add hot water to when making it like instant oatmeal. The small bottom of the jetboil canister means the heat is concentrated and its easy to burn anything thick like beans or chilli. Google alcohol stove for cheap camping stove. I like my jetboil though. I can set it up, dump water in it, boil the water, pour it through a coffee filter and have coffee in like 90 seconds. And it cools down instantly and can be packed back up immediately. Nice!
fatboy is online now   Reply With Quote
Old 08-29-2013, 07:58 AM   #15
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,234
I have the Primus Eta Express stove which is very similar to the jet boil. The main difference is that the pot is larger in diameter and shorter allowing the standard size canisters to pack up in it. It's also a bit less expensive than the Jet boil. It's worked very well for me, boils and cooks quick and is easy to manage the flame for simmering or slow cooking.
Ed
2009 BMW F800GS, 2008 BMW K1200GT
MCMXCIVRS is offline   Reply With Quote
Times are GMT -7.   It's 07:25 AM.
