Old 08-28-2013, 05:42 AM   #1
Elvie OP
Oddometer: 6
Fill yer boots - with water
Hi. Looking for boot equipment advice.
I have discovered that my waterproof riding boots are doubly waterproof - both from the outside and inside. There have been numerous times where the water has been coming into my boots over the tops. Not too bad through the summer months but fall is coming.
I was wondering what others have done to prevent this. I have seen ads for gortex, neoprene and waterproof socks but this is not a solution since they do not close fully at the top. Latest thought is something like a short waterproof gaiter from the boot top to the knee or so - but I cannot find this as a product. It would be convenient to carry or just wear under the rinding pants on days when you knew that streams and bogs were on the menu.
Any thoughts / suggestion.
Elvie is offline   Reply With Quote
Old 08-28-2013, 05:59 AM   #2
SRG
SRG
SRG's Avatar
Oddometer: 1,285
Hiking suppliers have the waterproof gaiters - the intended use is keep snow out I think. Make sure the openings are big enough for your boots. You may have to put the gaiter on before the boot.
I don't think water will really come in the top of a waterproof sock much, but you still end up w/ your boot full.
Lazy Traveler
SRG is offline   Reply With Quote
Old 08-28-2013, 06:10 AM   #3
Gale B.T.
Oddometer: 1,537
If I take a ride and I am concerned with water over the top of my boots , I wear my boots outside my riding pants. I use 'super tape /duck tape/ and I tape the top of the boots to the pants. NO water will come in if you layer it on properly.
me 2 cent
Gale B.T. is offline   Reply With Quote
Old 08-28-2013, 06:14 AM   #4
Elvie OP
Oddometer: 6
Thanks guys.
I have looked at a few hiking sites. The gaiters they advertise are no higher than the tops of my boots - usually lower. The gaiter solution does seem best though.
Regarding the duck tape solution - my pants will not fit inside my boots. Of course I could get different pants or duck tape the boots to my legs - ouch.
Old 08-28-2013, 06:25 AM   #5
Gale B.T.
Oddometer: 1,537
Originally Posted by Elvie View Post
Thanks guys.
Ok, them bare leg will be full of hair so wrap an elastic wrap around the top of the boot /your leg to protect the leg and cover the elastic wrap with super tape. There must be a way to keep your feet half way dry
Old 08-28-2013, 06:48 AM   #6
Elvie OP
Oddometer: 6
Yes - this works. Essentially creating what I hoped could be purchased - in Gortex would be best.
Old 08-28-2013, 07:39 AM   #7
rick3foxes
rick3foxes's Avatar
Oddometer: 105
Chest Waders!
Alaska blog: www.rick3foxesalaska.blogspot.com
IBA #34583
2003 Connie
"...I have promises to keep, and miles to go before I sleep." - Frost
rick3foxes is offline   Reply With Quote
Old 08-28-2013, 09:55 AM   #8
JustRon
ex-broadwayron
JustRon's Avatar
Oddometer: 1,228
Funny, I just started a thread like this a few days ago...
http://www.advrider.com/forums/showthread.php?t=913078
I wonder why no one makes waterproof in-the-boot pants? My Gore-tex pants go outside my boots (as they all do), and I regularly have water splash up the bottom of the pants, and into my boots. Using a gaiter (or something similar) would be much easier with an in-the-boot pant. Hell, if anyone (Klim, are you listening?) designed these, they could come with built-in (removable) gaiters.
2010 520RR, 2013 TR650
Baja crash Report
JustRon is offline   Reply With Quote
Old 08-28-2013, 01:21 PM   #9
Thorgrim
Used'ta could
Thorgrim's Avatar
Oddometer: 524
Just like "nature abhors an empty space", "water abhors a barrier". You're going to get wet either from the outside-in, or from the inside-out. It depends mostly upon the ambient temperature as to which one is more miserable.
2013 DR-Z400SM
Thorgrim is offline   Reply With Quote
Old 08-28-2013, 03:40 PM   #10
Elvie OP
Oddometer: 6
Just ordered a set of these.
http://www.amazon.com/dp/B005YMGGMA/...410_item_image
Proline Neoprene Boot Gaiters , Fits Motocross-Enduro-Trials Boots , Supplied In Pairs , Colour Red
Old 08-28-2013, 03:55 PM   #11
Gale B.T.
Oddometer: 1,537
WAY TO GO ELVIE, those look great. Test them in a local pond/stream and give us your 2 cents worth on how they work. I am impressed
Old 08-28-2013, 07:11 PM   #12
JustRon
ex-broadwayron
JustRon's Avatar
Oddometer: 1,228
Yeah, report back on those. I may buy a pair, depending on what you think.
Baja crash Report
Old 08-29-2013, 09:07 AM   #13
Elvie OP
Oddometer: 6
3 week delivery but I will post my thoughts in time for Santa.
Old 08-29-2013, 09:32 AM   #14
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 1,997
hmm, no way my riding pants will fit in my boots. My boots barely close as it is
wouldn't it be easier, even if just when it's raining, to wear your pants outside your boots?
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 08-29-2013, 09:38 AM   #15
Elvie OP
Oddometer: 6
Definitely easier to keep pants over boots for rain / puddles / shallow streams. The problem occurs when the water is higher than your boot tops and flows into the boot. If the gaitor does its job then the water will not enter under your pants and over the boot top.
Times are GMT -7.   It's 08:46 PM.
