Old 08-28-2013, 03:46 PM   #1
ChuckS OP
Adventurer Wannabe
ChuckS's Avatar
Oddometer: 652
What do I want? Actuated hack wheel, swaybar, or?
If I get time, a ride report is coming. 9 days, 1850 miles through mostly 2 lanes in Wisconsin & Michigan. My K1100/Ural worked admirably, but is going to need some modification before the next adventure.
Mostly I use my hack as my work truck, carrying me plus about 40 lbs of tools/junk/whatever. It's a bit heavy on the steering, buy nothing I've bothered to change in 2 1/2 years and 25,000 miles. I'm pretty happy that the hack is aligned properly- on average, no pulling, good tire life, and mpg. After returning from our trip, I did finally take Claude's advice & reverse the forks, which did give me a bit lighter steering.
Loaded for the trip, it was more like me, plus camping gear for 2, plus my better half. Steering a bit heavier, but still manageable. What is causing me pain is fighting the very variable crown in the roads. The 2 position adjuster on the hack shock is not enough.
What are my options? Swaybar? Actuated wheel on the hack?
I'm adjusting to the new economy-- right now, I'd rather spend my cash touring and not so much on mods, but....
I have access to a wide variety of skills and tools, but I'll have to know how to explain what I want.
SPOT track of my Newfoundland adventure
What? Me Worry?
1993 K1100LT w/Ural hack
DL650 K4
ChuckS is offline   Reply With Quote
Old 08-28-2013, 05:42 PM   #2
dholaday
dholaday's Avatar
Oddometer: 342
Chuck:
I think the answer is an electric camber control - also called a tilt control - it uses a linear actuator to allow you to compensate for different car loadings and/or road crown and/or prevailing crosswind and/or . . . .
Claude and Jay and Dave Hannigan each use them. Boxermetal installed one on a rig he built.
Duncan
It is better to have ridden and crashed, than to have never ridden at all.
dholaday is offline   Reply With Quote
Old 08-28-2013, 06:54 PM   #3
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,666
Swaybar
http://www.advrider.com/forums/showt...=913352&page=2
http://www.hpsidecar.com/sidecararti...ar/Page31.html
Solves multiple issues, stabilizes acts as overload spring and may save your bacon someday,whats not to love ?DB
Patience: A minor form of despair disguised as a virture.
Ambrose Bierce
davebig is offline   Reply With Quote
Old 08-29-2013, 08:16 AM   #4
Melrone
Oddometer: 953
I have to agree with Dave. The sway bar is alot better setup than my Electric Camber adjuster.I'm in the process of looking into switching..But the funds aren't there right now..In my oppion stay away from dmc if you want it done right..Talk to Claude he set you right...
Melrone is offline   Reply With Quote
Old 08-29-2013, 09:37 AM   #5
Abenteuerfahrer
Deaf on Wheels
Abenteuerfahrer's Avatar
Oddometer: 2,300
Originally Posted by dholaday View Post
Chuck:
Duncan
Hi Duncan... how's the rig serving you. Rest assured the fork bridge and ball joint were set in properly; torque; thread locker constant inspection. Do inspect it annually by lifting the the front end and check for play.. I am sure my line markers have dissipated by now.
By the way you do now sport a swaybar in addition to your electric tilt, don't you?
cheers..
Abenteuerfahrer is offline   Reply With Quote
Old 08-29-2013, 10:11 AM   #6
dholaday
dholaday's Avatar
Oddometer: 342
DaveBig - Melrone - Elmer - Dan
I run both a swaybar AND a tilt control. Swaybar does NOT help with varying road crown or crosswinds or sidecar loading or off-camber; the tilt control does. AceRph said he even uses us TC to help with left-hand sweepers.
Once you set the swaybar it is set until you get off the rig and disconnect-reconnect the attachment points. If I understand things correctly it is a mor-or-less fixed suspension component. The electric tilt control can be adjusted dynamically, on the fly.
Again, 2 of the 3 major builders [Claude and Hannigan] mentioned above use both tilt/camber control AND a swaybar, especially for their adventure-bike based rigs. Hannigan and DMC recommend a tilt control for most, if not all, their rigs; not sure whether Claude does too.
Chuck: IF I wanted better handling and IF I were forced to choose between a swaybar and a tilt control, I'd choose the swaybar; but it will not solve your problem with road crowns [or badly-cambered roads or crosswinds]. I don't know how your rig is built. It is relatively easy to add a swaybar. It may not be easy to retrofit a tilt control. Claude will know I'm sure.
Elmer: re fork bridge. I have complete trust in your install. But I'm going to have my dealer check it out in the next week or so.
Thanks,
Duncan
Old 08-29-2013, 10:22 AM   #7
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,666
Thanks,
Duncan
If you started all over with a setup or possibly preloaded the swaybar a little that tilt control would be excess baggage,DB
Ambrose Bierce
Old 08-29-2013, 10:46 AM   #8
dholaday
dholaday's Avatar
Oddometer: 342
Not really. The Tilt Control does things the swaybar can't. And vice-versa. One is not a substitute for the other.
Duncan
Old 08-29-2013, 12:32 PM   #9
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,666
Duncan
Duncan you just love gizmo's, I've gottten along nicely without one but I like simpler.DB
Ambrose Bierce
Old 08-29-2013, 12:50 PM   #10
dholaday
dholaday's Avatar
Oddometer: 342
Re me and Gizmos: You bet - anything to make my life easier and more fun
Re you and simpler: Baloney!
Just like car tires and swaybars, lots of folks have tilt controls and like them. Don't knock something you have never used - we both know people who do and you are wiser than that.
Regardless, a tilt control would deal with Cliff's problem; a swaybar won't.
Duncan
Old 08-29-2013, 12:53 PM   #11
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,666
Duncan
Consider me appropriately caned by both you and Mary today ! Standing up to me works !
Ambrose Bierce
Old 08-30-2013, 08:53 AM   #12
Melrone
Oddometer: 953
Duncan: I'm now thinking of switching mine to the swaybar system alond wwith everything They built..I've said this once I'll say it agin I don"t trust those guys.. After riding Daves rig that sway bar system is quite nice..I don't know if I will keep them both but I am considering that option also..After what you told me on the PM just prove my point about the owner of the company..enough said!!!
Old 08-30-2013, 09:46 AM   #13
ChuckS OP
Adventurer Wannabe
ChuckS's Avatar
Oddometer: 652
Excellent discussion.
My understanding is that a sway bar will improve handling over bumps & uneven terrain by transferring load between the rear wheel & hack, which definitely has a place. Michigan uses a LOT of SMS (Simulated Moon Surface) for both paved & dirt roads. My rig handles great (this is rig # 5 for me), so a sway bar probably should not be my first choice. Even when I had a spinning cage try to take us out on the E-way, the rig handled great under maximum brake & steering inputs at 70 mph. Always room for improvement though...
Tilt control will give me control over lean out of my rig, which will allow me to compensate for widely varying loads & road crown/camber. It won't help me soak up the bumps, or keep the tires planted, but it will help me for the seemingly endless miles of fighting road camber or trying to pick a lane where the rig wants to drive somewhat straight. It would be simpler if the loading of my hack didn't change by 300 lbs (yeah- we camp comfy).
I think I've been talked into tilt control first, then maybe a sway bar. I'll try to tackle the tilt control myself. Lots of pics in the threads here http://advrider.com/forums/showthread.php?t=854135 , a friend was a welder at a nuke plant, and it seems like a fun project. (Also my rig is my primary transportation; getting it to & from Claude is a bit inconvenient.) If /when I add a sway bar, it seems there are more variables with a sway bar and I'd be wise to enlist Claude's experience.
What? Me Worry?
DL650 K4
Old 08-31-2013, 06:24 AM   #14
AceRph
Affluenza Free!
AceRph's Avatar
Location: Where the stupidest people on earth run things
Oddometer: 24,653
I really like the tilt control. Duncan's right. I'll use it on left hand sweepers to counter the body roll, because I don't have a sway bar. You could use it going right or left if you set the car up high & have tilt control raised up to level the rig. I've been too lazy to try that. I have not ridden a rig w/ a sway bar. My understanding is that they roughen up the ride making the setup less sensitive to small bumps. But the handling in corners improves.
I just installed new Wilburs on my GS & am waiting for the custom hack shock to come. I've already had a great improvement in handling w/ just new shocks on the tug. A lot less roll on corners now. The stock rear had too many miles on it, ~40K. It was hosed.
I'll do a write up on the Wilbur install when the hack shock comes in. I expect more handling improvements with the better shock. I'm using a cheapo Progressive on the hack now. I know, what's to tell about installing new shocks on the rig, right? Just take the old ones off & stick the new ones on. Well, it didn't work out that way. The write-up will be less about what to do and more about what not to do.
Equal to all of you of roads and good luck! - krokodil al-kashi
“We are turning into a nation of whimpering slaves to Fear—fear of war, fear of poverty, fear of random terrorism, fear of getting down-sized or fired because of the plunging economy, fear of getting evicted for bad debts or suddenly getting locked up in a military detention camp on vague charges of being a Terrorist sympathizer.” —”Extreme Behavior in Aspen,” February 3, 2003
"The State sees the spectre looming ahead of terrorism and anarchy, and this increases the risk of its over-reaction and a reduction in our freedom." - Stanley Kubrick
AceRph is offline   Reply With Quote
Old 08-31-2013, 06:46 AM   #15
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,666
I find allot nicer ride by turning the damping down on my new Yacugars.I don't think one can have it both ways a bike that's capable on rough surfaces and one that rides like the sitting room couch.The handling in the corners doesn't just improve it's extraordinary.Have you seen a HP sidecar without a swaybar ? Camber controls are not cornering devices but do what you think is right, I'd bet even DMC would agree on that one.DB
Ambrose Bierce
Times are GMT -7.   It's 04:40 AM.
