Old 08-29-2013, 05:15 PM   #1
Ken Hubbell OP
Oddometer: 20
Cry Boots Make My Legs Itch BAD.
Gaerne Ballance Oiled boots. They make my legs itch really bad. I have tried several different socks and no socks at all. Washed the socks in baking soda only. Nothing works. I washed the inside of the boots with baking soda and vinegar,(Wife said it might work). Still no good. Has anyone had a problem like this? They didnt always make my legs itch, just the last few months. Seems worse when I sweat more. Tried lotion too. Help!
Ken Hubbell is offline   Reply With Quote
Old 08-29-2013, 05:44 PM   #2
oldtouring B
oldtouring B's Avatar
Oddometer: 415
It sounds like there is a fungus or mold growing inside your boots.It could be coming from your closet where the boots are kept.
Make a 50/50 mixture of Isopropyl alcohol and warm water. Apply with a cloth. Let them air dry for 2 days. Then repeat.
In the meantime look for a backup pair. Good luck with your problem..
oldtouring B is offline   Reply With Quote
Old 08-29-2013, 06:51 PM   #3
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,336
Meybe it's just too hot for boots. I can't wear my Sidi's during the summer, so I wear my hiking boots.
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is online now   Reply With Quote
Old 08-29-2013, 06:56 PM   #4
luckychucky
luckychucky's Avatar
Oddometer: 1,237
Hemp Oil
Rub oil on the itchy spots, oil last longer than lotion, if that doesn't work maybe you could try to drink the hemp oil. WARNING: Not responsible for anything anyone else does because of my suggestions.
luckychucky is offline   Reply With Quote
Old 08-29-2013, 07:55 PM   #5
acejones
acejones's Avatar
Oddometer: 5,158
What size are they ?
I got tired of being here, so now I'm there
acejones is offline   Reply With Quote
Old 08-29-2013, 08:02 PM   #6
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 1,990
Try gold bond foot powder all the way up your legs and make sure your socks go at least as high as the boots.
Mine itch from the heat of being trapped inside. No GB powder and i'll scratch the skin right off, with the powder, no itch at all.
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 08-29-2013, 09:02 PM   #7
Ken Hubbell OP
Oddometer: 20
Thanks for the input. Ill try the gold bond this weekend. If that doesnt work then the fungus route. Size 13 not for sale yet, pretty beat up anyway. thanks again!!!
Old 08-29-2013, 09:10 PM   #8
Reddog*
^ "Look up"
Reddog*'s Avatar
Oddometer: 2,754
Originally Posted by trc.rhubarb View Post
try gold bond foot powder all the way up your legs and make sure your socks go at least as high as the boots.
Mine itch from the heat of being trapped inside. No gb powder and i'll scratch the skin right off, with the powder, no itch at all.
+1
Reddog* is offline   Reply With Quote
Old 08-30-2013, 01:02 AM   #9
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,398
Hopefully you're still around. It's actually heat rash. The skin gets hot and yes little fungi or whatever then decide your legs are a fun place to hang out. Too bad they're itchy!
I too have found that powder helps,and if at all possible, cool your legs at the end of a riding day with cold water. It seems to keep down the inflammation too.
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is offline   Reply With Quote
Old 08-30-2013, 02:13 AM   #10
ADZ
ADZ's Avatar
Oddometer: 140
Get some knee high skins or similar compression gear.
ADZ is offline   Reply With Quote
Old 08-30-2013, 05:02 AM   #11
Thorgrim
Used'ta could
Thorgrim's Avatar
Oddometer: 510
Go to an online barber supply like this one:
http://www.appletonbarbersupply.com/...t=Neck+Dusters
and buy one of the "neck dusters" that has a reservoir for talc. Fill it with Gold Bond or similar powder instead of talcum, and give your itchy places a good dusting before you dress.
2013 DR-Z400SM
Thorgrim is offline   Reply With Quote
Old 08-30-2013, 10:31 AM   #12
Sevv
Oddometer: 99
Buddy of mine recently developed an alergy to leather. We'll not leather, but the chemicals used too cure the hide. Swells anything that it touches and itches like crazy. Even through other clothes or layers.
Might be worth getting tested.
Sevv is offline   Reply With Quote
Old 08-30-2013, 11:51 AM   #13
dsauer
Oddometer: 153
Yep, sounds like heat rash. AKA prickly heat. Hydrate more to keep yourself cooler. Add lime juice to your water, it's supposed to help. Can you loosen your boots to let in air? Try Roadgear coconut socks, they help too.
Deb
Golden, CO
dsauer is offline   Reply With Quote
Old 09-03-2013, 09:15 PM   #14
Ken Hubbell OP
Oddometer: 20
Thanks Everyone! The Gold Bond worked awesome!!!! Rode out in the Black Rock Desert for two days. No itching!!! Thanks again!
Old 09-03-2013, 09:23 PM   #15
Thorgrim
Used'ta could
Thorgrim's Avatar
Oddometer: 510
Yep, I knew I was washed up as a ladies' man when the day came to replace the sweet smelling shaving talc in my brush, the stuff that made my neck so smooth to the touch, with Gold Bond which makes my ... aww, nevermind.
Glad you found something that helps.
2013 DR-Z400SM
Times are GMT -7.   It's 06:39 AM.
