Old 08-30-2013, 07:33 PM   #1
Joevano OP
Oddometer: 130
Will paint thinner ruin my air filter?
I'm tired of researching and being undecided about what to put in my parts washer.
I think I'll just go cheap with paint thinner.
Main concern is, will it eat up my Twin Air filters?
Joevano is offline   Reply With Quote
Old 08-30-2013, 07:43 PM   #2
kubiak
Oddometer: 4,829
i use diesel in my washer and it hasnt messed up my foam filters yet.
kubiak is online now   Reply With Quote
Old 08-30-2013, 10:02 PM   #3
FlyingPenguin
FlyingPenguin's Avatar
Oddometer: 212
I've used Chevron "Mineral S pirits Thinner" in my parts washer with no problem on foam filters. I use the thinner to pre-wash and then finish with warm soapy water. I also use a separate pan to keep the fine particulate aircleaner dirt out of my parts washer.
"We'll burn that bridge when we get to it"
Deadhorse- 2002, 2012
ALCAN 5000- 2004
COBDR- 2014
FlyingPenguin is offline   Reply With Quote
Old 08-31-2013, 12:46 AM   #4
mcma111
mcma111's Avatar
Oddometer: 12,267
I use mineral spirits/paint thinner from Home Depot on my UNI air filters with no ill effects.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 08-31-2013, 05:30 AM   #5
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,413
Don't wash your air filter in the parts washer, not clean enough.
Old 09-02-2013, 02:52 PM   #6
jar944
jar944's Avatar
Oddometer: 695
Its the Best way to remove the filter oil. Then do a wash in soapy water to remove any dirt.
And I use odorless mineral spirits in my washer.
jar944 is online now   Reply With Quote
Old 09-02-2013, 06:04 PM   #7
baloneyskin daddy
bikaholic
Oddometer: 2,141
I use automatic dishwasher detergent and it works great.
baloneyskin daddy is offline   Reply With Quote
Old 09-02-2013, 07:45 PM   #8
jar944
jar944's Avatar
Oddometer: 695
To cut through filter oil?
Other than pine-sol, I've yet to find a soap or citris based degreaser that will break maxima fft filter oil.
Old 09-05-2013, 12:32 PM   #9
kantuckid
Oddometer: 3,079
Whats the diff in using kerosene for cleaning parts? I don't have a washer and don't do it often enough for a washer as such but it sure is cheaper.
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85
kantuckid is offline   Reply With Quote
Old 09-06-2013, 06:06 AM   #10
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
I do this also. Make sure to dry the filter off thoroughly with paper towel and hang it up for awhile before you soak or spray filter oil too.
buls4evr is offline   Reply With Quote
Old 09-07-2013, 04:57 PM   #11
ttpete
Rectum Non Bustibus
Oddometer: 5,940
K-1 doesn't evaporate as quickly as mineral spirits. With the latter, you can clean a part and then rinse with hot water, and it will dry quickly with no solvent residue.
15 BMW RnineT
09 Kaw Versys
Old 09-07-2013, 07:08 PM   #12
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,622
kerosene, mineral spirits, paint thinner, napatha, diesel fuel. ect.
All close together fractions of the petroleum distillate spectrum.
Jayrod1318 is online now   Reply With Quote
Old 09-08-2013, 01:05 PM   #13
kantuckid
Oddometer: 3,079
I know kerosene is "more oily" but it sure is cheaper & is a safe solvent that works for most shop grunge.
Old 09-08-2013, 03:26 PM   #14
DirtyOldMan
Oddometer: 1,909
I keep low odor mineral spirits in the parts washer but I also keep a couple of gallons of it in a 5 gal. bucket for washing filters. I wadded up some chicken wire (poultry netting for you sophisticates) and put it in the bottom of the bucket so the dirt can settle down in there. I keep a lid on the bucket so it doesn't evaporate. It gets a bit added to it when I do my final rinse with clean spirits. Lasts forever, if it gets too funky I strain it through a rag into a new clean bucket. Been working out of the same thinner for over 10 years.
Sandy Jackson
04 250 RFS
13 650 Terra
96 R1100R
DirtyOldMan is offline   Reply With Quote
Old 09-08-2013, 03:40 PM   #15
Motopsychoman
Not a total poseur
Motopsychoman's Avatar
Oddometer: 752
Eek Cleaing air filter
Actually paint thinner shouldn't hurt it at all. Neither should gasoline.
Try Simple Green. It cuts through just about everything. Mix 1:4 SG to water. Let it soak.
Works on foam and K&N type filter materials.
"It's a topsy-turvy world, and maybe the problems of two people don't amount to a hill of beans. But this is our hill. And these are our beans!" - Frank Drebin
Current Rides: '13 Sertao, '98 Bandit 1200, Currently a 1200 piece puzzle: '86 R80G/S PD
Past: '66 Suzuki T10, '72 CL350, '74 GT550, '80 GS750, '7? XT500, '83 RM250, '85 XT500
Motopsychoman is offline   Reply With Quote
Times are GMT -7.   It's 09:12 PM.
