Old 09-02-2013, 02:27 PM   #1
Dan Alexander OP
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,597
So It's Started ... Dnepr Resto
I got the car off the frame today after cutting a few bolts. Started to sand with my angle grinder and a sanding disc and put a bit of primer on the sanded spots ... till I ran out of primer of course. They are still rough though.
So, the $64k question is .... now what??
I have no idea how to do this properly so any hints on killing the rust, fixing the dents and generally making it look decent will be appreciated. The PO cut the loops for the tonneau off and I'd like to replace them at some point.
[IMG] photo P9021332_zpsa65f64e7.jpg[/IMG]
[IMG] photo P9021331_zps5d46d194.jpg[/IMG]
[IMG] photo P9021330_zps4ed3ea7e.jpg[/IMG]
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 09-02-2013, 02:48 PM   #2
FR700
Heckler™©®
FR700's Avatar
Oddometer: 7,799
Trust me , just get it either sand blasted or chemical dipped to strip all that crap off inside and out.
The hours and hours and hours you'll spend doing it by hand will not be worth the money you thought you saved.
Paint jobs are all about preparation. Those sanding/grinding marks will show through the top coat unless you put a lot of effort into it. Thinking that an extra top coat of paint will hide things ... doesn't work.
Good high build primer of your choice with lots of final sanding before top coating it.
Followed by your choice of paint , 2K , acrylic etc. Avoid paint that is COB ( clear coat )
I'm diagonally parked in a parallel universe.
FR700 screwed with this post 09-02-2013 at 08:40 PM
FR700 is offline   Reply With Quote
Old 09-02-2013, 02:53 PM   #3
Dan Alexander OP
Oddometer: 7,597
this low budget rebuild isn't sounding as low budget as I thought
Wonder how much sand blasting would cost?
Old 09-02-2013, 03:00 PM   #4
FR700
Heckler™©®
FR700's Avatar
Oddometer: 7,799
Sand blasting a tub will be cheap. Not much more than what you would spend on sanding discs and sandpaper alone for one in that condition. Then you still need to figure in your electricity bill , time and effort ( getting into all the nooks and crannies will drive you insane ) ... and the mess it will make.
Old 09-02-2013, 03:03 PM   #5
Dan Alexander OP
Oddometer: 7,597
I told you I didn't know how to do this
OK, I'm googling local sandblasters as we speak, I'll call tomorrow as it's a holiday.
Frame too I suppose??
Old 09-02-2013, 03:08 PM   #6
FR700
Heckler™©®
FR700's Avatar
Oddometer: 7,799
Why not as the frame will be another day or so of stripping and prep.
Ask if they'll throw on a quick primer coat to seal it from flash rusting ( they likely will anyway )
Old 09-02-2013, 03:17 PM   #7
Dan Alexander OP
Oddometer: 7,597
I'm thinking of Rhino lining the interior and maybe the bottom as well, hopefully they have a grey.
This seem logical?
Old 09-02-2013, 03:22 PM   #8
Old Mule
Old Mule's Avatar
Oddometer: 430
how old is that machine?
Why would a bike that new need restoring? What kind of ham fisted brute owned it before you?
My sidecar is from 1954 and has only been restored three times!
If you spend time on prep it'll come out just fine, have fun.
Old Mule is offline   Reply With Quote
Old 09-02-2013, 04:13 PM   #9
usgser
Oddometer: 2,237
Low budget is smearing bondo and rattle canning, that you'll get to do over and over at way too early intervals. If you expect/want it to look good and last do it right once or sell it to someone that will. There are no magic smear on rust killers/encapsulator nonsense regardless of the products marketing hype. Even sandblasting only goes so deep. If it's into the metal beyond surface rust the only way to stop rust is to cut it out and weld in new metal. And yeah depending on your goals and the quality of results you can live with will very likely cost significantly more than you initially planned. Big eyes with a thin wallet gets you a middle seat tourist class ticket down the restoration rabbit hole. Good luck.
usgser is offline   Reply With Quote
Old 09-02-2013, 04:25 PM   #10
EvilClown
Reality show stunt double
EvilClown's Avatar
Oddometer: 16,747
Have to catch up later with the big boy PC to see pics but for now....
These are our Golden Years. ~ EC
The future is no place to place your better days. ~ DMB
The world is a book and those who do not travel read only one page.
~Augustine of Hippo
EvilClown is offline   Reply With Quote
Old 09-02-2013, 05:19 PM   #11
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,796
This seem logical?
Seems logical too me, you could coat the whole body.DB
Patience: A minor form of despair disguised as a virture.
Ambrose Bierce
davebig is offline   Reply With Quote
Old 09-02-2013, 07:30 PM   #12
Dan Alexander OP
Oddometer: 7,597
Guilty as charged.
Old 09-02-2013, 07:35 PM   #13
Dan Alexander OP
Oddometer: 7,597
I'd say it's had a tough, short life. There are dings and dents all over, some look like they were done at the factory though I bought it from a Harley dude who was going to use it for his dog. He already had a Velorex on the bike though so maybe this was too much work for him?
Even when I see pics of newer ones the sides and trunk area don't seem nice and smooth like a fiberglass one. There are marks from where the body parts were welded together etc.
So, I'm thinking a concourse finish isn't what these cars are all about. Plus I don't need it to look way better than the bike it's attached to
Rattle can and Bondo were my original thoughts! Rhino lining at least half of it would reduce the amount of major work for that smooooth finish though.
I'd like it grey to match the GS with those shark teeth decals on the sides.
Old 09-02-2013, 07:43 PM   #14
Dan Alexander OP
Oddometer: 7,597
I've read the Por 15 is supposed to be good at killing or at least sealing in the rust. Thought I'd try some Evaporust also ... not true ??
Old 09-02-2013, 08:02 PM   #15
FLYING EYEBALL
out of step
FLYING EYEBALL's Avatar
Oddometer: 10,562
get it blasted, or buy a blaster from hf and diy.
Get a gallon of bedliner and go crazy.
if you keep poor...the struggle is simple
my photos http://jskustoms.smugmug.com/
save yourself some $ with my smuggy discount code qvMaWy1bTFU7c
FLYING EYEBALL is online now   Reply With Quote
Times are GMT -7.   It's 09:21 PM.
