Old 09-04-2013, 07:55 AM   #31
RomaDakota
Illuminatus!
RomaDakota's Avatar
Oddometer: 1,505
It is possible this is the mount type -
http://www.ural-zentrale.de/product_...-und-Ural.html
КМЗ Dnepr MT11 // КМЗ M72 // ИЖ Planeta 5 // КМЗ MV750 // Урал М63 // BMW R1200GS 30th
RomaDakota is offline   Reply With Quote
Old 09-04-2013, 08:36 AM   #32
RomaDakota
Illuminatus!
RomaDakota's Avatar
Oddometer: 1,505
Forget what I said above. I now think these are standard later model type.
Ural mounts must be different although the lenses are the same.
Picture from internet -
Old 09-04-2013, 10:08 AM   #33
jphii
OK, now what?
jphii's Avatar
Oddometer: 1,989
If you are seriously thinking about rhinoliner you need to look at this: https://www.dipyourcar.com/ Forget sand blasting and just spray it. For $250 you're done in a day.
jphii is online now   Reply With Quote
Old 09-04-2013, 10:28 AM   #34
Dan Alexander OP
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,650
I liked that idea but I bought a can and sprayed some metal brackets and didn't like the durability, but I only tried two coats, so I peeled the stuff off and painted instead.
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 09-04-2013, 10:30 AM   #35
Dan Alexander OP
Oddometer: 7,650
My fender is more rounded like that one in the pic and the lights are for a flatter fender. My fender is dinged up so I'm wondering if one of the new flatter fenders will fit, then I'll have the proper lights.
Old 09-04-2013, 10:34 AM   #36
Abenteuerfahrer
Deaf on Wheels
Abenteuerfahrer's Avatar
Oddometer: 2,303
Originally Posted by jphii View Post
If you are seriously thinking about rhinoliner you need to look at this:https://www.dipyourcar.com/ Forget sand blasting and just spray it. For $250 you're done in a day.
Hmmnn...for better surface adhension; rust removal, etc. sandblasting is still the best option for a greater long lasting durable finish.
This was mentioned in "Dipyourcar":
I have a bare metal, or primered surface, can I dip it?
Yes, there are several cases of people dipping bare metal to seal out moisture, and dipping over primer and both are still peelable. The biggest concern with bare metal is that there aren't any fingerprints or moisture trapped under the dip, to ensure no surface rust.
In other words, Rust is moisture !! Moisture creates Rust... remove it! Don't cover and trap it!
cheers..
Abenteuerfahrer is offline   Reply With Quote
Old 09-04-2013, 10:50 AM   #37
jphii
OK, now what?
jphii's Avatar
Oddometer: 1,989
It is easy enough to get rid of moisture before coating.
Old 09-05-2013, 10:29 AM   #38
Dan Alexander OP
Oddometer: 7,650
Here's a message I got from these guys
http://www.sodablastquebec.ca/en/sod...-restauration/
Hi Daniel,
We do not recommend sand because it's too strong for your project but we have multiple media that will give better results without damaging. Our price for blasting your sidecar would be 350$ and if you want, we could put 2 coatings of etching primer for 150$.
Pretty expensive!
Old 09-06-2013, 11:23 PM   #39
jbcaddy
Oddometer: 1,219
you might check to see if anyone in your area does pickup bed spray on liners. they might at least give you a few ideas. I'm going the DIY style on mine, but I do have a compressor that can do soda blasting. I'll do the bottom outside and inside with rattle can undercoating and paint the rest.
jbcaddy is offline   Reply With Quote
Old 09-07-2013, 09:56 AM   #40
Dan Alexander OP
Oddometer: 7,650
That's the line I'm going to take. $500 is waaaay to much for my blood.
I know some guys in Ottawa who work on big trucks and they weld and have a large compressor.
I'm doing a roof on one of their houses so I'll drive the tub up there one day, blast it with soda or glass or whatever and then weld whatever needs it.
The local auto/farm store has these for abrasives .... what do you guys think would work best??
http://www.princessauto.com/pal/Abra...-415-659-182.c
along with one of these siphon fed containers?
http://www.princessauto.com/pal/Siph...ster/8012660.p
Dan Alexander screwed with this post 09-07-2013 at 10:06 AM
Old 10-04-2013, 01:29 PM   #41
Dan Alexander OP
Oddometer: 7,650
OK, back in the saddle after getting sidetracked with To Blast Or Not To Blast questions.
My verdict was Not ...
Not going to pay $350 plus etching primer from one shop I got a quote from and a few unanswered emails to three other shops.
So, it's up to me from here on in.
I got a wire cup brush for my angle grinder and went to work for an hour. All the loose rust is gone. You can see daylight through pinholes in the bottom front
[IMG] photo PA021373_zps2837e7ea.jpg[/IMG]
Bottom rear is fine
[IMG] photo PA021371_zps3a187279.jpg[/IMG]
Did more finer sanding on the outside
[IMG] photo PA021374_zpsc9c1661c.jpg[/IMG]
[IMG] photo PA021377_zps2befbcd8.jpg[/IMG]
Shot the outside with POR15 Etching primer
[IMG] photo PA021379_zps6fb450cd.jpg[/IMG]
Two coats of POR15 in the front and back, can still see daylight even though they tell me it'll bridge gaps up to 3/8"
[IMG] photo PA021381_zps2eaff3e3.jpg[/IMG]
[IMG] photo PA021380_zps01d352ed.jpg[/IMG]
Got some primer over spray in there, the POR15 is actually very glossy and hard as nails.
I did a third coat of the POR just for good luck .. no pics of the shinyness yet.
I did the POR on a very windy day and didn't have my respirator handy. Take a deep breath and go in for a few brush strokes and back out. Still got a good buzz.
Dan Alexander screwed with this post 10-04-2013 at 01:34 PM
Old 10-04-2013, 01:45 PM   #42
Dan Alexander OP
Oddometer: 7,650
There used to be a windshield of some sort on there so I'm filling in the holes. The PO cut the loops off for the tonneau but I want that so I'll leave them alone.
[IMG] photo PA041388_zps55c113b1.jpg[/IMG]
Going around filling dents from the spot welder and other signs of the tough life this car has had
[IMG] photo PA041387_zpsc13f94b9.jpg[/IMG]
[IMG] photo PA041386_zps179dd806.jpg[/IMG]
Look Ma .. No holes!
[IMG] photo PA041383_zps4cd1434b.jpg[/IMG]
Old 10-04-2013, 01:48 PM   #43
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,350
Good start!
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 10-04-2013, 02:23 PM   #44
moto leo
Oddometer: 251
I always thought that you needed to put bondo onto rust free metal and not over primer paint. Reason being the bondo sticks better to roughed up metal than primer. After smoothing down bondo you would then use primer as fill coat and sand/prime/sand till smooth.
Anyone know for sure?
moto leo is offline   Reply With Quote
Old 10-04-2013, 04:36 PM   #45
Dan Alexander OP
Oddometer: 7,650
I was thinking about that very thing as I was doing it.
Like I said before I've got no idea how to do this so any advice is appreciated.
I'll sand again tomorrow and see what comes off easily.
BTW it was called Liquid Metal, came in a tube like spot putty.
Times are GMT -7.   It's 06:51 AM.
