Old 09-02-2013, 03:25 PM   #1
iamcanjim OP
Face drop
Oddometer: 756
Chain guidance
Bought a new chain for my 1988 Suzuki GSX1100F. The PO put a 530 kit on it to change it from a 535. I checked the sprockets and they were fine, for I used a chain breaker to trim the new chain and used the master link to fasten the new chain on. I did not get an O ring chain, because it's an old bike and I am cheap.
I have put about 500 km on the new chain. Yesterday, the chain broke at low speed at the master link.
The chain was a bit too hot to touch sitting on the ground.
I had forgotten to put one bolt back in the plastic chain guard and it was rubbing the chain.
What happened?
Bad Chain?
Friction from the plastic rubbing heated the chain causing a failure?
Improper installation of the master link? I have never done that before, but followed the instructions precisely.
I had the rear tire changed the day before the failure. Did the shop somehow screw something up?
Is it safe to put a new chain on?
iamcanjim is offline   Reply With Quote
Old 09-03-2013, 05:40 AM   #2
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,481
What kind of master link was it? Clip or rivet? I wonder why the PO purposely decreased chain size (and strength) on an 1100cc bike?
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 09-03-2013, 07:22 AM   #3
kubiak
Oddometer: 4,845
which model chain did you use? if its not a oring it might have a very low tensil strength and got hot and broke from the power of the 1100.
Old 09-03-2013, 09:32 AM   #4
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 2,256
A high-quality 530 o-ring chain will have no problem handling the power of that bike. The mighty Hayabusa comes with a 530 chain. Converting older bikes to 530 is very common simply because 530 chain is so much easier to find nowadays.
A low-quality and/or non-o-ring chain won't last long on a moped, let alone a powerful streetbike. Plus, you installed the new chain on old sprockets, which is a sure recipe for fast wear, and you may have also installed the master link incorrectly.
That bike originally came with an o-ring chain (532 or 630, I think), so I'm not sure I follow your reasoning in installing a non o-ring chain.
In sum: you got very lucky because cheaping out didn't kill or injure you. A broken chain can also destroy the engine cases and create all sorts of havoc.
Park the bike until you can spend the money to replace the sprockets and chain with high-quality items.
An excellent source with great prices and the expertise to source the correct parts for vintage bikes is Z1 Enterprises -- they ship worldwide. You will need to email or call them, since they can't list every conversion application and gearing option on their web site.
http://z1enterprises.com
And before you ask, the cheap Chinese o-ring chains on eBay are complete garbage.
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR685 - Turd II.2, The ReReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is offline   Reply With Quote
Old 09-03-2013, 12:14 PM   #5
dmn0507
dmn0507's Avatar
Oddometer: 353
+1 on checking chain specs, 530 is good enough unless is really a cheapo chain.
well, most probably the chain was way too tight after they put the wheel back, it's a very common issue with many shops, hence the overheating. --> if the chain broke due to excessive tension i wouldn't trust it anymore
Perhaps the master link failure was just a coincidence, if the plate broke it's not because of bad assembly.
PS: an o-ring chain probably is cheaper in the long run, unless u dont ride a lot.
dmn0507 screwed with this post 09-03-2013 at 12:20 PM
dmn0507 is offline   Reply With Quote
Old 09-03-2013, 12:53 PM   #6
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,862
I'd bet the tension was too tight, along with the worn sprockets as the cause for the failure.
the bike may be old, but it can STILL bust a chain, it seems . . . .perhaps you should be less cheap ;-}
btw, the plastic rubbing on the chain had nothing to do with it.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 09-03-2013, 04:10 PM   #7
iamcanjim OP
Face drop
Oddometer: 756
Sprockets are fine. Really, they are. No really sign of wear. I should take pics and post them. I will when I get the front sprocket cover off.
Sounds like cheap chain and powerful bike = bad combination.
The clutch is soft now, so I may have destroyed the clutch slave cylinder.
And it was a clip.
Sorry, it was a 532 originally. PO changed it to get cheaper chains.
Old 09-03-2013, 05:29 PM   #8
lnewqban
Ninjetter
lnewqban's Avatar
Oddometer: 291
Cool2
..........Improper installation of the master link? I have never done that before, but followed the instructions precisely.
I had the rear tire changed the day before the failure. Did the shop somehow screw something up? .........
The direction of the clip is the most important instruction to follow.
If installed in the opposite direction, that loose chain-guard could have helped the clip getting loose and fall.
Once the external plate leaves the premises right after the clip, the master link will fail.
As others have mentioned, the chain could have been over-tensioned due to insufficient slack and/or misalignment of the rear sprocket respect to the front one.
Always quality control any work done to your bike, especially related to the chain and tires.
lnewqban is offline   Reply With Quote
Old 09-03-2013, 05:35 PM   #9
iamcanjim OP
Face drop
Oddometer: 756
Front Sprocket
Rear Sprocket
Inside of front sprocket cover. Destroyed one bolt and the link from the hydraulic clutch to the gearbox. Nicked the engine too, but nothing serious.
Looks like I will need a never front sprocket cover and a new clutch link between slave and clutch. Plus a new chain.
iamcanjim screwed with this post 09-03-2013 at 05:48 PM
Old 09-03-2013, 05:36 PM   #10
iamcanjim OP
Face drop
Oddometer: 756
Ok, I installed the master clip right. That's good.
Old 09-03-2013, 05:45 PM   #11
iamcanjim OP
Face drop
Oddometer: 756
Sorry about the size of the pics. I will fix them in a bit.
Old 09-03-2013, 05:53 PM   #12
Elkster88
Oddometer: 43
Don't use clip style master links!
You can buy an inexpensive chain breaking tool (for mushrooming the rivet style link pins) at Harbor Freight for cheap. Press the sideplate on using Vise-Grips or a C-clamp and a couple of sockets over the pins if you don't have a chain press.
You say the sprockets aren't worn, but how can that be if the previous chain (before you put on the cheap non-o-ring chain) needed to be replaced? I'd replace the sprockets to keep my new high quality chain from wearing out prematurely.
Elkster88 is offline   Reply With Quote
Old 09-03-2013, 06:16 PM   #13
iamcanjim OP
Face drop
Oddometer: 756
Take a look at the pics. Are they worn out? If so, I probably need to relearn what constitutes worn out. I understood if you use steel sprockets its 1:2 sprocket:chain changes.
Another problem is with the 530 conversion kit it's tough to find new ones.
I will keep that in mind though.
Old 09-03-2013, 06:27 PM   #14
iamcanjim OP
Face drop
Oddometer: 756
The chain was a DID. It was $112 CDN.
iamcanjim screwed with this post 09-03-2013 at 06:44 PM
Old 09-03-2013, 06:28 PM   #15
dnrobertson
Big Bike, Slow Rider
Oddometer: 852
I have never understood the problem with clip style master links.
I would have ridden 100,000 kms in my life (40+ years of riding) on dirt, sand, mud, gravel and bitumen and NEVER had a failure with a master link (or a broken chain).
But then I don't buy cheap shit chains either.
As an aside, how do you know if you have mushroomed a rivet style correctly?
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Times are GMT -7.   It's 01:07 AM.
