Old 09-03-2013, 10:20 AM   #1
DJFlowe OP
Ginger
Oddometer: 222
Changed my first tire- need guidance
Hi, folks!
Based on all the feedback I've gotten from lurking in this sub-forum, I bit the bullet and bought a tire changer. My dealer quoting me $200+ in labor for tires purchased elsewhere or paying MSRP for them didn't hurt.
I found a used Wikco changer on Craigslist, set it up and used it for the first time this weekend. The removal went smooth as silk. Bead breaker and demount bar both worked perfectly.
The problem came when I tried to mount. Using the mount bar, I could get the tire about 70% mounted when the wheel would start to slip and rotate. I cranked the clamp down as tight as I felt comfortable (pretty dad gum tight) and it still slipped.
Ended up using spoons to finish the mount, which worked OK. I'd just rather not have a large contraption taking up space if I'm going to end up using spoons.
Full disclosure- I used gaffer's tape on the rim clamps. Is that what's causing the slipping? Am I doing something wrong?
DJFlowe is offline   Reply With Quote
Old 09-03-2013, 10:34 AM   #2
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,872
What tire and size?
What kind of rim?
Tube or not?
Was the tire in the "well" opposite of the final section to go in?
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 09-03-2013, 10:52 AM   #3
DJFlowe OP
Ginger
Oddometer: 222
Originally Posted by AustinJake View Post
What tire and size?
What kind of rim?
Tube or not?
Jake- Great questions.
Stock Triumph 17" rim off a Street Triple.
Tubeless, Pilot Road 3.
The tire was in the "well" on the other side- I used a couple of clamps to compress it.
I also was using water/dish soap as a lubricant. I was able to pop the bead on using short spoons without too much trouble.
Old 09-03-2013, 12:11 PM   #4
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,862
I have a Harbor Frieght machine that I use with a Mojo Lever . . . . .and have Mojo blocks on the machine . . .. same wheel slippage . . . .
I run a tie down strap around a spoke (cast wheel) or a number of spokes (wire wheel) and then around a frame member of the machine.
No More Slippage.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
bomber60015 screwed with this post 09-03-2013 at 01:11 PM
Old 09-03-2013, 12:50 PM   #5
DJFlowe OP
Ginger
Oddometer: 222
Originally Posted by bomber60015 View Post
I have a Harbor Frieght machine that I use with a Mojo Lever . . . . .and have Mojo blokcs on the machine . . .. same wheel slippage . . . .
No More Slippage.
Thanks, Bomber. Any worries about tweaking a spoke on a cast wheel?
Old 09-03-2013, 12:59 PM   #6
bomber60015
Oddometer: 14,862
Cast wheel?
None whatsoever (they hold up the bike, after all).
Spoke wheels, that's why I go around several spokes ;-}
Old 09-03-2013, 01:05 PM   #7
bisbonian
bisbonian's Avatar
Oddometer: 1,054
No More Slippage.
I do the same.
My 2009 Alaska Adventure
bisbonian is offline   Reply With Quote
Old 09-03-2013, 01:20 PM   #8
DJFlowe OP
Ginger
Oddometer: 222
Thanks, guys. I'll try a strap next time and see how it goes.
I appreciate the help!
Old 09-03-2013, 01:39 PM   #9
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,355
Soap and water is better than nothing or dog spit, certainly, but using tire mounting lubricant is much better. Easier mounting and less tendency to rust/corrode your wheels.
Ruglyde from NAPA, XtraSeal from Advance Auto and others. A gallon is $10, and will last a loooong time.
HapHazard is offline   Reply With Quote
Old 09-03-2013, 03:02 PM   #10
gsweave
Yinz, blinkers are on.
Oddometer: 12,499
some of this/ One of these
1 Peter 2:16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave is offline   Reply With Quote
Old 09-03-2013, 05:41 PM   #11
jon_l
jon_l's Avatar
Oddometer: 3,459
I tried to buy a pint or 2 of tire changing lube from a local tire shop. They told me to use cooking oil, as it is about the same thing. Sounded messy, so I went back to a solution of water & Dawn dish soap, which seems to work well. I have also used Windex, which works, but evaporates quickly.
I'd buy tire changing lube like Ruglyde in reasonable qty, but only see shop-size containers (gallon or larger). Does anyone sell a reasonable amount, preferably in a bottle that doubles as a dispenser?
Has anyone tried Armor All? This guy promotes (but you can almost read anything in the internet): http://www.motorcycleclassics.com/Bl...#axzz2dsbdI7k1
The Wing guy in the above link also writes that (some) dish soap will ruin alloy wheels.
CBF1000 & PCX150, PCX Fuelly
jon_l is offline   Reply With Quote
Old 09-03-2013, 06:13 PM   #12
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,958
I have found that using three 3/4" blocks of wood on the underside quite helpful to keep the tire at the center of the rim. Also tire lube is your friend.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 09-03-2013, 08:28 PM   #13
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,742
Go to Princess Auto.
Have tools, will travel!
Old 09-04-2013, 11:51 AM   #14
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,641
Tire lube thread
http://www.advrider.com/forums/showthread.php?t=876340
Jayrod1318 is offline   Reply With Quote
Old 09-04-2013, 12:15 PM   #15
acejones
acejones's Avatar
Oddometer: 5,352
C'mon guys ! You're spending good money for tire changing tools, straps, tire irons, etc. Why not spend a little more and buy some real tire lube ?
Its like spending $100 for a really good toothbrush and then using baking soda instead of toothpaste.
I got tired of being here, so now I'm there
acejones is offline   Reply With Quote
Times are GMT -7.   It's 03:02 AM.
