Old 09-03-2013, 12:13 PM   #1
halvor OP
Oddometer: 3
Changing brake lines on a R850r with ABS
Hi folks!
I'm about to change my brake lines on a bike with ABS. Haynes more or less tells me to keep off. Hmf, why did I buy the manual?
Any good methods out there? Bleeding the ABS-centre?
Hal
Hal
'74 R90 /6
'97 R850R
halvor is offline   Reply With Quote
Old 09-03-2013, 03:15 PM   #2
gsweave
Yinz, blinkers are on.
Oddometer: 11,972
http://advwisdom.hogranch.com/Wisdom...Maintenance.pd
http://www.ibmwr.org/r-tech/oilheads/index.shtml
better instruction
850 is same as 1100 procedure....
Grats on your 850R.
changing the lines is easy, so is the bleed
you will want to hang on to the Haynes for bigger project referance
1 Peter 2:16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave screwed with this post 09-03-2013 at 03:22 PM
gsweave is offline   Reply With Quote
Old 09-03-2013, 11:36 PM   #3
halvor OP
Oddometer: 3
[QUOTE=gsweave;22246516]http://advwisdom.hogranch.com/Wisdom...Maintenance.pd
Thanks GS, but the first link doesn't work for me. What I'm worried about is trapping air in the ABS/central unit. But I guess with some vacuum like the Mityvac it should be pretty straight forward. I've changed lines on older bikes before, like the R90 and just used MC for bleeding without any problems.
Cheers!
Hal
'74 R90 /6
'97 R850R
Old 09-04-2013, 02:33 PM   #4
gsweave
Oddometer: 11,972
Need to add an f to the pd. my bad
It is in the hall of wisdom bottom right of this page
Old 09-04-2013, 11:54 PM   #5
halvor OP
Oddometer: 3
Done!
This was easy! I just a vacuum sucker running on my compressor. Changed all the tubes with Steel-braided and sucked the air out of the system. Had to use the under-tank unit to bleed the front. Thanks for links and pat onthe back!
Cheers!
Hal
'74 R90 /6
'97 R850R
Times are GMT -7.   It's 01:47 PM.
