Old 09-03-2013, 04:39 PM   #1
bhp-equals-fun OP
Oddometer: 22
MZ ETZ Build from Blackpool UK
Hello from a long time lurker!
I thought it was about time I should step out of the shadows and
share my contraption and story with you guys.
It started just before summer 2012 when I sold my K100 - due to hooliganism
I thought I should get something a little more sluggish. I've always yearned
for a Dnepr rig but nowadays they all seem to be too expensive for what you
get... or don't get for that matter. Instead I bought another ETZ250 as I'm quite
a fan of MZ and decided to go forth and engineer myself a hack!
So armed with a £20 gasless mig, angle grinder and some cider I leaped in at the
deep end.
I had chunk of steel frame that I modified, some spare swing arms and general MZ
parts floating about - the only steel I bought was for the main connection bar & suspension aswell as the diagonal struts. The rest was all skip finds.
bhp-equals-fun is offline   Reply With Quote
Old 09-03-2013, 05:01 PM   #2
bhp-equals-fun OP
Oddometer: 22
Pics to follow...
Old 09-03-2013, 05:31 PM   #3
bhp-equals-fun OP
Oddometer: 22
Ok there are quite a few photos missing but here is part of the semisubframe without the main structural parts - the chair was originaly tried as a mono-shock but I later found that needed tweeking.
Note: My skills don't result in asthetics, just simple and strong! Plus the uglyness is an anti-theft device in its own right!
Old 09-03-2013, 05:40 PM   #4
bhp-equals-fun OP
Oddometer: 22
After winter I decided I needed a "proper" sized box!
Test for size... also note the upgrade to twin shock.
Recent mod for a parking brake:
Finished(ish) family day out:
Old 09-03-2013, 06:04 PM   #5
bhp-equals-fun OP
Oddometer: 22
Struts were 3mm walled tubing with a nut welded onto the end and secured using connectors from scaffolding clamps, I got 6 knackered clamps off a local scaffolder and chopped them up to make my bits, for example, under the tank I welded part of a clamp to the frame. To that connects one of my struts - one end has the nut and connector, the other end I made a slot and in it put a plate of metal with a hole drilled in it - effectivly a fixed and and an adjustable end.
For the main connection to the bike I made a clamp that clamps to the center stand mounts, the inside of the clamp is a kiln dried wooden block - idea being that I tightend it all up good and tight and as the wood gets wet it expands and makes everything a little more snug.
I have a total of 5 connection points, front and rear diagonals, main connection bar, a rear stabiliser bar that connects to the pillion footrest and a bar that runs from the front of the sidecar to the exhaust mount under the engine that acts as a front stabiliser/sway bar - I know its far from an idea connection point as the engine is floating on rubber mounts but its better than nothing!
Old 09-03-2013, 06:13 PM   #6
FR700
Heckler™©®
FR700's Avatar
Oddometer: 7,805
Welcome to the asylum.
That has to be one of the best pic's on this forum.
A reflection of what life should be about , love it
I'm diagonally parked in a parallel universe.
FR700 is offline   Reply With Quote
Old 09-04-2013, 02:30 AM   #7
Sidecarjohn
Sidecarjohn's Avatar
Oddometer: 738
Welcome. Will always have a soft spot for MZ, having owned a solo, plus a factory produced sidecar outfit.
Enjoy.
SidecarJohn
http://www.sidecarjohn.co.uk/
Sidecarjohn is offline   Reply With Quote
Old 09-04-2013, 08:01 AM   #8
Agent Wayward
Oddometer: 375
Christ that's ugly!
Congratulations. :)
We need more Brits on here, the colonial types think they are in control.
SV650 Rat
R80 custom
Multistrada 1100
www.motopodd.com
Agent Wayward is offline   Reply With Quote
Old 09-04-2013, 05:43 PM   #9
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,597
Waaaay better than I could build
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 09-05-2013, 06:52 PM   #10
Old Mule
Old Mule's Avatar
Oddometer: 430
Love this
MZ ES 250 was my first bike...
Old Mule is offline   Reply With Quote
Old 09-06-2013, 01:55 AM   #11
bhp-equals-fun OP
Oddometer: 22
Thanks for the comments, next mod im thinking some bolt-on LL forks based on the ones in this pic:
http://upload.wikimedia.org/wikipedi.../MZ-Diesel.jpg
Might happen in the next few months... hopefully....
Problem is im pretty rubbish when it comes to accuracy and to get within
5mm would be a real acheivement for me!
Old 09-06-2013, 04:04 PM   #12
altf4
altf4's Avatar
Oddometer: 126
yup,
this is a relatively simple and definitely cheap alternative to 'proper' leading link forks...
go for it, it will totally traqnsform your riding experience o)
g max ~:)
altf4 is offline   Reply With Quote
Old 09-06-2013, 04:27 PM   #13
Dan Alexander
Oddometer: 7,597
I can't understand Brit speak was that a resounding Yes or extreme sarcasm??
Old 09-07-2013, 01:14 AM   #14
altf4
altf4's Avatar
Oddometer: 126
no sarcasm here, although, come to think of it...
oh - and wider handlebars would make a big difference, too.
g max ~:)
Old 09-07-2013, 01:55 AM   #15
bhp-equals-fun OP
Oddometer: 22
Haha yeah it'll totaly transform it alright - wether i just plough into the side of a parked car or not will be more luck than judgement me thinks.....
But if i can keep things close to parallel it should be an upgrade to the low speed head wobble i sometimes get, i was thinking of putting a damper on it but i may aswell try and make some forks that do the job properly, winters coming and last year a bit of wobble nearly caught me out at 15 mph on a slippery adverse camber whilst following some nervous tin can driver.... Only get it between 15 and 20 which makes riding around town in traffic even more unpleasant.
Times are GMT -7.   It's 08:25 PM.
