Old 09-07-2013, 02:40 AM   #16
NitroMax
NitroMax's Avatar
Oddometer: 685
Love it !!
Like I mentioned in your other topic these LL's are called "Schwabel"
You could also alter the yokes/triple trees to what we call "Ed Pols platen" overhere.
Pic borrowed from Halflive's website
I do have a technical drawing for them on my computer somewhere ( specifically for the MZ ) still have to have them made for my own MZ someday.
1300cc 217Nm/207Hp NOS-injected VMax (1985), 500 cc 1950 BSA chopper (1983) in pieces, 750 cc CB750 chopper (1990), 300 cc MZ transporthack (1989) winterhack, 900 cc BMW R 90/6 hack (1976) summerhack, 1100 cc BMW R1100GS (1997) daily driver.
Age is an issue of mind over matter. If you don't mind, it doesn't matter ( Mark Twain )
NitroMax screwed with this post 09-07-2013 at 01:11 PM
NitroMax is offline   Reply With Quote
Old 09-07-2013, 10:26 AM   #17
altf4
altf4's Avatar
Oddometer: 127
...which is incredibly neat o) top stuff!1!!
g max ~:)
altf4 is offline   Reply With Quote
Old 09-07-2013, 03:08 PM   #18
Old Mule
Old Mule's Avatar
Oddometer: 433
future
VW beetle steering dampers are only $30USD, and you will need a eight gallon fuel tank next.
Old Mule is offline   Reply With Quote
Old 09-07-2013, 07:58 PM   #19
NortwestRider
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 4,105
A CHEAP way to improve steering is to find a set of LEADING AXLE FORKS that are the same dia as your stock forks.Mount them in your STOCK triple clamps and you have reduced the trail !!!.I did this on my outfit for $40 which included the forks,wheel,tire,fender and calipers !!.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is offline   Reply With Quote
Old 12-29-2013, 07:22 AM   #20
Bambi
Bambi's Avatar
Oddometer: 710
And a fork-brace on the sliders helps to stiffen the steering action, too. On my MZ-outfit in the 80s I had situations in really tight turns, that with the handle-bar at the left or right stop the frontwheel was still pointing straight - ok, not quite, but much of it.
Kind regards, Bambi
'Find me kindness, find me beauty, find me truth ...'
(Dreamtheater, Learning to live)
Bambi is offline   Reply With Quote
Old 12-30-2013, 07:41 AM   #21
warkshop
uncbob
warkshop's Avatar
Oddometer: 600
Love your rig, basic, does the job and the family image is awesome, good for you.
About the wobbles, be sure all the rigging is singing tight, flex = wobbles. Low tire pressures or too little toe in also = wobbles. Even slightly loose adjustment on head or swingarm bearings or worn wheel bearings = wobbles. I have found if all these things are good it is very rare one gets the wobbles,,,and avoid the whiskey = wobbles!
Keep it simple, find and fix the root cause.
Lastly, do the wide handlebar thing, it will do the job and for waaaaaaay less money, it will help eliminate the wobbles but zero bragging rights, you'll never be the farkle king.
"The business of life is far too important to take seriously" Oscar Wilde
http://www.warkshop.com
warkshop is offline   Reply With Quote
Times are GMT -7.   It's 05:08 AM.
