Old 09-16-2013, 01:59 PM   #46
michael1968
michael1968's Avatar
Oddometer: 857
Originally Posted by DRjoe View Post
Are the earliey motors downdraft as well?
Nah, they're out the side. They're twin carb but if that was to wide you can get a single carb manifold of a ds650.
michael1968 is online now   Reply With Quote
Old 09-16-2013, 05:33 PM   #47
FloorPoor OP
Oddometer: 712
Laugh
Originally Posted by Whale Rider View Post
Sorry about the hijack FloorPoor back to your project. Have you thought about the BMW 650 X Challenge as a donor bike. All you would need then would be forks and rear shock. Walter Colebatch on this forum swears by them and looks like there are aftermarket parts available ex Europe.
Light reading here
http://www.advrider.com/forums/showthread.php?t=834987
WR
I do really like the x challenge, but they're not too common. One production year=limited supply. I think it might be the perfect DS bike (for what I like to do) when set up like Walters. If I find one for the right price, at the right time, Ill abandon this crazy idea. Or I might just try and find a low mileage 640 and ride it till it blows up, then work on a swap.
"You can have anything you want, but not everything you want."
"There's nothing like that fresh tire feeling "
FloorPoor screwed with this post 09-16-2013 at 06:51 PM
FloorPoor is offline   Reply With Quote
Old 09-30-2013, 11:19 AM   #48
johninlv
Oddometer: 39
Great thread, I have a well set up WR250R and have been looking at the TR650 Husky. The smooth motor and gear ratios seem to be spot on. I like the fuel under the seat but would need a larger tank. How about a TR650 motor in a Wr250/450 aloy frame. KYB suspension can be tuned to any level of performance.
2004 Yamaha xt225, 2008 Wr250R Works in Progress
johninlv is offline   Reply With Quote
Old 10-01-2013, 04:55 PM   #49
gatorgrizz27
Oddometer: 133
I'm all for complex projects, and build plenty myself. However if 100% reliability in a severe environment is what you're going for, I'm not sure it is the best way. They often have many little issues and teething problems, such as wires chafing, parts vibrating loose, etc. Unfortunaltey they also typically make use of one-off or difficult to find parts as well, which may be impossible to replace in certain locales. With my projects I try to use as many factory available parts as possible, and usually from the same brand, or at least readily available/easy to duplicate parts.
You might be better off having a 640 motor gone through and completely built up by someone reputable checking every part, making necessary upgrades, balancing it, etc. reducing the compression may also increase longevity, and I believe Rally Raid was producing a 450 kit for the lc4 that might improve reliability and increase fuel mileage. I don't know much about the Husky TE610/630, but they may be what you are looking for as well.
gatorgrizz27 is offline   Reply With Quote
Old 10-01-2013, 09:31 PM   #50
dnrobertson
Big Bike, Slow Rider
Oddometer: 841
Rallyraid kit is for the LC4-690 (Current model) not the 640.
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Old 11-19-2013, 12:38 AM   #51
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,144
The 600/625/640 motor is an antique. It is difficult to rebuild. To replace the shifter seal - split the cases. Kick start spring breaks - split the cases. Sand cast cases are very soft aluminum and strip easy. The casting shapes are somewhat random, sometimes you can't get a wrench on a case screw, sometimes there's not enough material to hold the screw. Heavy crank, way too small counter balancer. Expensive. Some parts are slow to order. Makes this bike a great idea for a fresh motor.
Love the frame, suspension, wheels, tank, fairing, etc. I've thought about stuffing a good light motor in these. Would love to squeeze an SV650 engine in there, but there's no way. The 640 motor is somewhat short front to back.
Right or left output is not a big deal. A japanese motor would be good. A wet sump motor would be easier. I think a DR650 motor would be a better candidate. These are everywhere.
"Son, you can't do both"
Old 11-27-2013, 11:54 AM   #52
Kawidad
Kawidad's Avatar
Oddometer: 4,981
That's what I was thinking too.
Although, the Rotax ideal has merit.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad screwed with this post 11-27-2013 at 04:29 PM
Kawidad is offline   Reply With Quote
Old 12-04-2013, 12:51 PM   #53
DC950
Microadventurer
DC950's Avatar
Oddometer: 2,921
I think it's a brilliant idea and have always said that when my 640 blows up, I'm putting a Rotax in it. It's been done though. Somewhere I have a picture from a guy in Egypt who's done it with a carb engine. I think he even rented it out for desert tours. Hopefully I can find it and post it.
Even an air cooled Rotax would be more reliable than the KTM and probablly easier to shoehorn in. People used to road race them 15-20 years ago. They made good power and were very reliable. They were flat tracked as well.
Pic stolen from these guys:
http://www.barebones.net/machines.htm
I have no doubt they could make it work in a 640 Adv frame.
The Suzuki 650 is a nice, reliable engine but it's a dog.
God. Family. Motorcycles. Guns. Music. Books. Dogs. Beer. Baseball. Work. That about covers it.
DC950 is offline   Reply With Quote
Old 12-05-2013, 12:17 AM   #54
michael1968
Oddometer: 857
Didn't the earlh KTM's run rotax engines before they developed their own?
Old 12-05-2013, 06:26 AM   #55
Kawidad
Kawidad's Avatar
Oddometer: 4,981
Yes
Old 12-05-2013, 09:47 AM   #56
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,669
I say put a CR500 motor in, and be done with it.
When they say Harleys are for 1%ers, I don't think they mean guys who sell crank and get in bar fights any more.
Roadracer_Al is offline   Reply With Quote
Old 12-05-2013, 05:28 PM   #57
zig06
zig06's Avatar
Oddometer: 164
You know, if he wanted to get really crazy he could find a Yamaha Banshee 350 motor, install a 500cc kit and go smoke some 600cc rockets! They would never know what beat them, but the slight mist of burnt oil would let them know that they really did just get "smoked"!
zig06 is offline   Reply With Quote
Old 12-05-2013, 06:04 PM   #58
Roadracer_Al
Oddometer: 1,669
I have it on good authority that those can be let out to nearly 800ccs and 90 hp. Ringadingdingding indeed.
Old 03-11-2014, 12:56 AM   #59
papublic
Oddometer: 2
KTM LC4 with rotax engine
hey guys-it has been done, tough not with an EFI engine.
Just read in the german bike mag (MOTORRAD, 17.1.2014), that Thomas and Marion Schmitt from germany have been doing it for years. they use the Rotax engine (with Keihin carb and aftermarket exhaust = 60HP) in an KTM 625 EXC frame AND in a sidecar setup (HEOS frame/chasis, 250kg incl. fuel!!).
apparently they travel aroung 20.000km a year and have been doing it for the last 35 years. They find the KTM/Rotax the best combination ever.
Oh, they also take their dog along on the trips ;-)
Sorry, no more info at this stage, would also be interested since I also believe that this combination joins a very good chasis with a reliable and driveable engine.
papublic is offline   Reply With Quote
Old 03-11-2014, 05:40 PM   #60
FloorPoor OP
Oddometer: 712
If work picks up this year, like it looks like it will, I may possibly start looking for a donor chassis and engine this fall.
Times are GMT -7.   It's 04:14 AM.
