Old 09-04-2013, 06:01 PM   #1
biggziff OP
Funk Soul Bruvah
biggziff's Avatar
Oddometer: 8,633
Anyone built a VW Bug....
I've built a few VW engines for aircraft, but a friend used to have a few old bugs that would wheelie and were *very* quick. I've got access to a couple late 60s rollers (a few run too) so I was wondering what to expect if I decide to dump some time and money into one. It would remain ugly...emphasis on building a drive train that would propel the car to unsafe speeds (ya, I know...unsafe at many speeds)
I've got a couple friends with Caymans and the like who I'd like to wipe the smug off their face with some fugly, 50 yr old piece.
So...how much should I expect to spend? I see 2900cc drop ins for $4K...what about the tranny? Suspension? Brakes?
Anyone?
"Fools you are. To say you learn by your experience. I prefer to profit by others' mistakes and avoid the price of my own."
- Otto von Bismarck
biggziff is offline   Reply With Quote
Old 09-04-2013, 06:06 PM   #2
purplepeopleeater
The Official VW Nut
purplepeopleeater's Avatar
Oddometer: 147
Decent 2176 turnkey will run you $8-9k, 2900cc? 4k wouldnt get you heads.
Tranny well, i spent 3k on mine it was "ok"
Hit the performance section on thesamba.com
purplepeopleeater is offline   Reply With Quote
Old 09-04-2013, 06:24 PM   #3
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
you're dreamin to wipe a Caymen... beetles are fun, cheap blasters, but not in the same league. I started with a '66 1300 beetle. chopped it up for a pipe buggy... J.C. Whitney "Big Bore Kit! More power! Better MPG!"
Old 09-04-2013, 06:27 PM   #4
biggziff OP
Funk Soul Bruvah
biggziff's Avatar
Oddometer: 8,633
My bad...2332cc $4K
http://jcsvwparts.com/type-1-2332-turnkey-complete/
No bueno?
Tranny...
http://www.kcrtrans.com/street.html
UltraStreet (Same as SuperStreet, but with Weddle 1st through 4th, 3.88 R/P, chromoly pinion retainer, KCR's meticulous race prep)
Swing Axle, T-1, Bus, T-3
$2,150.00 w/ exchange
IRS, '69 & Later, T-1 & T-3
BERG 5 SPEED
Basic 5 Speed
(Same as Superstreet Plus, 4.12 r/p, chromoly pinion retainer, 3.78 1st gear, Weddle "Sportsman" 3rd & 4th , stock 4th as 5th)
$3200.00
Ultra 5 Speed
(Same as Ultrastreet but with any ratio 5th gear)
$3750.00
Any good?
- Otto von Bismarck
Old 09-04-2013, 06:32 PM   #5
purplepeopleeater
The Official VW Nut
Oddometer: 147
If you are going to pull out the denero for a berg, get a subarugears 5speed conversion the motor you posted is ok at best.
Old 09-04-2013, 06:34 PM   #6
biggziff OP
Funk Soul Bruvah
biggziff's Avatar
Oddometer: 8,633
I know so little about these.....
What year(s) for the roller? Any suggestions? I found a nice looking 67 nearby...needs pans.
- Otto von Bismarck
Old 09-04-2013, 06:59 PM   #7
purplepeopleeater
The Official VW Nut
Oddometer: 147
Forget about racing porches, but a big CC engine is fun forsure.
ideal engine 1900cc-2100cc, nice thick cylinder walls
My 2276 I had in my 61, had mild head work, dual webber 40's, external oil cooler, all all new componets build most of it myself and had just under 8grand in it with all the tinware and a1 sidewinder exhaust system ( over $1200 alone) all the engine sensors, head, oil temp, pressure, gauges
stock type3 trans with beefy diff, this trans didnt last long.
Old 09-04-2013, 08:25 PM   #8
MiteyF
MiteyF's Avatar
Oddometer: 2,011
If you really want to trash a Porsche, I'd go with Subie running gear.
With that said, my 1835 cost me less than $1k done top to bottom, but I won't be breaking any speed records
People tell me I have a motorcycle problem. I tell them, I may have problems, but motorcycles are the solution.
MiteyF is offline   Reply With Quote
Old 09-05-2013, 04:41 AM   #9
jar944
jar944's Avatar
Oddometer: 713
This.
jar944 is offline   Reply With Quote
Old 09-05-2013, 09:37 AM   #10
Switchblade315
Switchblade315's Avatar
Oddometer: 5,697
the parts are out there to get a stupid as your bank account can handle. Find the solidest body you can find. and have fun. but with a bug you will spend time working on it. over and over and over again. the good thing is they are fun to work on a everything about them is simple. oh and they are like driving a big ass gocart. Mine had a tired 1500 and it was the most fun car to drive I have ever had.
i say go for it.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is offline   Reply With Quote
Old 09-05-2013, 09:57 AM   #11
MiteyF
MiteyF's Avatar
Oddometer: 2,011
i say go for it.
You will have to work on it... IF you build a high HP engine. I'm sure that's what you meant, but just reiterating. If the engines stay fairly low HP and are built properly, they are reliable as shit, with little more than oil changes and valve adjustments (and adjusting the valves on an ACVW is THE easiest valve job you'll ever do, takes me 20 minutes... sometimes I do it when I'm bored for no reason) are necessary.
My 1835 probably makes about 80ish HP (just a guess) as it's running rich, and I have never touched it since it was built a few years ago besides said oil and valves.
Old 09-05-2013, 12:24 PM   #12
Krazyjohnny
Oddometer: 450
Look into Northstar V-8 Conversions for one.
President and Founder of
Superhero Proving Grounds
"Where dreams are made and egos are checked"
2013 Ducati Multistrada, 08' 530 EXCR, 09' Yamaha FZ-6
Krazyjohnny is offline   Reply With Quote
Old 09-05-2013, 12:49 PM   #13
troidus
Oddometer: 15,239
At what point on the modification curve does it cease to be a bug?
troidus is offline   Reply With Quote
Old 09-05-2013, 12:53 PM   #14
josjor
Location: The largest geological formation in the U.S.A.
Oddometer: 2,875
I'd probably avoid the '67. One-off year for a lot of the body parts. Had one. No fun.
On the other hand, my '68 was a blast. It was pretty stock until a guy I knew totaled out his bug and the wife refused to let him rebuild it. I bought his freshly built 1835cc with dual Dellorto's on it for a measly $300.00.
Never did have money to buy a trans or do anything to it. Still, it would beat the current (this was in the '80's) Camaro's to the next light. But just to the next light. (Please, please, please don't make me shift into third.)
It was a fun vehicle and as others have said, keep up on the oil changes and the valve adjustments and they'll run almost forever. Such a bone basic engine. It's a fun one to have around if you have a teenager that wants to learn some wrenching. Did that with my foster son and the '73 Super Beetle we had at the time.
Neutiquam erro.
Originally Posted by Stagehand View Post
listen mister, we didnt evolve porcelin shitters just so we could squat to take a shit, like monkeys.
josjor is offline   Reply With Quote
Old 09-05-2013, 04:59 PM   #15
gozirra
Spam?
Oddometer: 161
I still called my '63 a bug and it had a rotary motor in it and a radiator and spal fans up front.
No not a 13b Turbo monster, only a street ported 12a rotary. A kennedy adapter plate, Carb, one motor mount bar added and some lines run to the front and I was basically done.
Faster than I ever needed on the street, really showed that a berg kit and susp/tires were BADLY needed.
But having a redline somewhere near 10K+ and being able to mess with cars on track days made it all worth while.
Sadly I have the city of San Jose to thank for using a trash truck to test my cars crush strength, while parked. I will always miss the little blue beast.
gozirra is offline   Reply With Quote
Times are GMT -7.   It's 02:36 AM.
