Old 09-05-2013, 12:40 PM   #16
hwunger
Oddometer: 500
Originally Posted by ST-DocLizard1 View Post
Honda ST1300 with a 7.76 gallon tank.....................I've pushed it as far as 350 miles, but normally I go about 280-300 before a refuel. Getting too low in the lower tank is not good for the fuel pump.
second that !!!!
best Touring bike in the world .... more range than any other OEM bike
for a smaller one the 650 V-Strom ain't bad either ....
hwunger is offline   Reply With Quote
Old 09-05-2013, 12:43 PM   #17
Scott of the Sahara
Oddometer: 362
Moto Guzzi Norge 1200. I usually fill up with my friends so we can compare mileage at around 150 miles. That being said, I have a 6 gallon tank and I can get near 47mpg. So 230 to 240 is pretty good. I usually don't want to push it past 225 since my mileage can vary from 42 to 47.
Scott of the Sahara is offline   Reply With Quote
Old 09-05-2013, 02:03 PM   #18
Mobiker
Mobiker's Avatar
Oddometer: 1,824
First Gen FZ1. Low fuel light came on regularly around 175 miles. Still had a gallon left.
'88 R100GS
'76 xl350
"Don't Panic"
"If I was in a hurry, I'd left earlier."
Mobiker is offline   Reply With Quote
Old 09-05-2013, 08:10 PM   #19
Chisenhallw
Avowed Pussbag
Chisenhallw's Avatar
Location: I've narrowed it down to 'earth'. Or 'Baltimore'.
Oddometer: 6,452
Another vote for the older Connies. I routinely go 200 miles on a tank.
2001 Kawasaki Concours 2001 Suzuki SV650
MD ABC TOR...I review motorcycles for 2wheelsandamotor.com
Chisenhallw is offline   Reply With Quote
Old 09-05-2013, 08:19 PM   #20
bug67
Hazard Avoidance
bug67's Avatar
Oddometer: 749
2013 Triumph Trophy SE
6.9 Gallon Tank
Getting well over 200 MPT...no matter what I do.
Past: '04 Ducati Monster 620, '05 BMW R1200GS, '11 Triumph Tiger 800 XC
Present: '09 Triumph Street Triple R, '13 Triumph Trophy SE
Check it out: http://www.vegetablesandwich.com
"If you are going through hell, keep going." -Winston Churchill
bug67 is offline   Reply With Quote
Old 09-05-2013, 08:24 PM   #21
Jim K.
Oddometer: 1,164
Originally Posted by Super Sneaky Steve View Post
http://en.wikipedia.org/wiki/Kawasaki_Concours
First gen Connie could hold 7.53 gallons.
+1. My old Connie was getting 49.8 MPG (after I had around 15,000 mi on it). Assuming you could access all that fuel, that would mean over 375 mi. per tank. I never tried it myself, mind you.My bladder would need emptying long before the tank needed filling.
Jim K. is offline   Reply With Quote
Old 09-05-2013, 08:31 PM   #22
atokad
wan⋅der⋅lust
atokad's Avatar
Oddometer: 2,817
2006 Triumph Tiger 955I. 6.3 gals, consistent 48 mpg for last 25k miles, aggressive riding style, race can with off road ecu tune, at altitudes of 5k plus ft, 270 lb rider/gear/tailbag, easy 250 miles before I refuel, right around. 300 miles I imagine if I ran it dry.
Sent from my SCH-I405 using Tapatalk 2
2006 - Triumph Tiger
1995 XR650L
atokad screwed with this post 09-05-2013 at 08:40 PM
atokad is offline   Reply With Quote
Old 09-06-2013, 12:29 PM   #23
wildbill
wildbill's Avatar
Oddometer: 90
My '92 BMW GS Paris Dakar had a 9 gallon tank with a range of 360+ miles. Once did over 400 miles and was running on fumes when I pulled into Cheyenne, WY at night.
The trip is the adventure. The destination is out there.
2012 Goldwing
wildbill is offline   Reply With Quote
Old 09-06-2013, 01:09 PM   #24
rider33
rider33's Avatar
Oddometer: 1,098
as mentioned, the ST1300 has nearly an 8 gallon tank which even at 40MPH is good for 300 miles, bone stock. Odds are good you'll want to stop before it needs to. They also don't break, have good weather protection, and are more comfortable than most for the taller rider. Clean copies used are a pretty good value too. The only bike I'm aware of with a larger tank, stock, is a GSA.
“many a trip continues long after movement in time and space have ceased”- Steinbeck
rider33 is offline   Reply With Quote
Old 09-06-2013, 01:39 PM   #25
FishHunt
slow poking...
FishHunt's Avatar
Oddometer: 1,345
My naked 2000 ZR7 would get an easy 220-230 miles per tank. My '07 650 V Strom can easily do the same.
<>< Fish
V-Strom 650 Averaging 100 Smiles per gallon
Be good and you will be lonesome - Mark Twain
____________________________________
FishHunt is online now   Reply With Quote
Old 09-06-2013, 02:45 PM   #26
ferrix
Oddometer: 666
This should do it - 45l tank! :)
ferrix is offline   Reply With Quote
Old 09-06-2013, 02:56 PM   #27
DarthJ
DarthJ's Avatar
Oddometer: 152
Honda Shadow Aero, 2011 - up, 50+ MPG, 3.7 gal tank, about 170 to fill up. (note, NO reserve as the bikes are injected)
DarthJ is offline   Reply With Quote
Old 09-06-2013, 03:35 PM   #28
celticus
celticus's Avatar
Oddometer: 671
2007 R1200R. 5.something gal tank. I regularly get 250 on a tank.
celticus is offline   Reply With Quote
Old 09-06-2013, 03:57 PM   #29
rico2072
rico2072's Avatar
Oddometer: 323
2007 KLR 650 with an aftermarket 6.6 gallon tank. 247 mile before reserve. 20 miles of reserve, but the tank is so big and goes lower than the carb, you still have about 1 to 1.5 gallons you can't use.
"Beware of the lollipop of mediocrity. One lick and you'll suck forever!"Brian Wilson
rico2072 is offline   Reply With Quote
Old 09-06-2013, 04:59 PM   #30
Yamarocket630
Honey Badger
Yamarocket630's Avatar
Oddometer: 630
94 vfr750, 5.5ish gallon tank, 47-50mpg, 200-220 miles till the low fuel light is on. Another 35 or so until empty.
Yamarocket630 is offline   Reply With Quote
Times are GMT -7.   It's 09:10 PM.
