Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 09-27-2013, 02:25 PM   #1
Corsica101 OP
Corsica101's Avatar
Oddometer: 426
Diet for my 1190
Am looking to bring my Adventure to under 200 kgs and raise the ground clearance a bit at the same time in order to make it more serious off-road capable but keeping traveling work horse properties.
As I'm not the expert in this field I'm am directing to you more knowledgeable fellow off-roaders and travellers for some interesting advice and ideas
I guess by upgrading suspension and rims I'll shed most weight?
Don't hold back!
Corsica101 is offline   Reply With Quote
Old 09-27-2013, 02:38 PM   #2
GVWR
GVWR's Avatar
Oddometer: 35
I would also suggest to replace the standard exhaust, remove the center stand and replace the battery with a li-on battery. Lighter is normally not cheaper :-)
Good luck!
KTM 1190 Adventure R
GVWR is offline   Reply With Quote
Old 09-27-2013, 04:08 PM   #3
Corsica101 OP
Corsica101's Avatar
Oddometer: 426
Good luck!
Ordered the short Wings exhaust this week. How much lighter you reckon the lithium battery is? I know some good forks could cost a bit but what else do you work for?
Old 09-28-2013, 12:34 AM   #4
Fireflyer
Oddometer: 6
http://advrider.com/forums/showthrea...hlight=Battery.
Fireflyer is offline   Reply With Quote
Old 09-28-2013, 01:20 AM   #5
rattis
rattis's Avatar
Oddometer: 1,146
Diet
Check your BMI
It's cheaper to loose your own weight but it's more fun to farkle.
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, double up now, a 990Adv and a 950 SER
rattis is offline   Reply With Quote
Old 09-28-2013, 01:29 AM   #6
Corsica101 OP
Corsica101's Avatar
Oddometer: 426
Originally Posted by rattis View Post
Check your BMI
Lol..what, you saying... I'm fat?
8 hrs/wk sports and 81kgs...I can barely eat enough to maintain my weight.
Lets stick to suspensions :)
Old 09-28-2013, 01:38 AM   #7
Corsica101 OP
Corsica101's Avatar
Oddometer: 426
Originally Posted by Fireflyer View Post
I'll get the batt as well...just another 10kgs left to shed off
Corsica101 screwed with this post 09-28-2013 at 09:49 AM
Old 09-28-2013, 12:04 PM   #8
Tom@s
1190 Adv R
Oddometer: 18
remove the passenger footpegs and brackets, and remove the passenger handgrips
Tom@s is offline   Reply With Quote
Old 09-28-2013, 12:33 PM   #9
Reddydr
Oddometer: 64
I had replaced OE exhaust with Wings short exhaust weight saving =4kgs
Replaced OE battery with P3 Litiuhm ion battery from KTM twins usa Weight saving of another =4kgs
Total of 8 kgs i could reduce
Centre stand can reduce by another=1.5kg
2k chain sprocket + Disc brakes + CarbonFibre wheels in total can REDuce a maximum of 6kgs (very expensive bits)
can pull down to a total of 8+6= 14kgs
228kgs wet weight-14kgs=214kgs
Reddydr is offline   Reply With Quote
Old 09-28-2013, 02:00 PM   #10
frog
frog's Avatar
Oddometer: 2,774
Only put 2 gal of fuel in.
Sent from my DROID RAZR
Thank you MX1WEST, Highway Dirt Bikes Lindsay Machine, Smart Performance, SPS for the Support
257x Solo Baja 1000
If I had not some strength of will I would make a first class drunkard--Shackleton
frog is offline   Reply With Quote
Old 09-28-2013, 02:03 PM   #11
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,735
O.k., so now we all hate you....
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is online now   Reply With Quote
Old 09-28-2013, 11:07 PM   #12
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,738
U saved 4kg by changing a battery???
How much did the OEM battery weigh? +5kg....
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is online now   Reply With Quote
Old 09-28-2013, 11:55 PM   #13
rallyreplica
out and about
Oddometer: 53
...is there smog stuff you can remove? Maybe go with a tubeless tire set up.
RR
rallyreplica is offline   Reply With Quote
Old 09-29-2013, 12:52 AM   #14
Corsica101 OP
Corsica101's Avatar
Oddometer: 426
Uoops shoot me...
Old 09-29-2013, 01:24 AM   #15
JohnnyWaffles
Oddometer: 239
Going minimalist on your camping setup is the easiest way to reduce large amounts of weight on any bike.
If your setup involves a 5.3lb (2.4kg) Kermit chair, the latest in lightweight battery technology isn't going to save you.
2013 KTM 990 Adventure Baja Edition
Originally Posted by Beefeater Steve
The KTM is the kind of bike you take behind the middle school and get pregnant. It's the kind of bike that, from the moment you light the fire, you know is downright nasty and makes you want to meet in the Burger King bathroom and lick its butthole.
JohnnyWaffles is offline   Reply With Quote
Times are GMT -7.   It's 10:59 PM.
