Old 07-05-2014, 03:19 PM   #241
mathewst
Oddometer: 8
Hi I am doing something similar as you have done.
Most of mods im doing myself. My target is co petitive rallye budget bike. I have proly chosen wrong base. But im too far in to switch. Bought bike this march.
I have done wp fork 18 wheel ohlins complete custom rallye roadbook tripmaster dashboard exhaust front fairing back side mods etc.
Have you done hymec clutch? I got some installTion issues :)
mathewst is offline   Reply With Quote
Old 07-05-2014, 04:15 PM   #242
jaumev OP
jaumev's Avatar
Oddometer: 1,487
Hi!
Well.. I think you can ride a rally with the Tenere but I don't think it could be competitive.
What are you going to do with the rear suspension? same travel?
No. I didn't do anything with the clutch, does it work well?
Bikes, trips and farkling at http://traildreamer.com/
Yamaha Super Ténéré off road modifications: http://advrider.com/forums/showthread.php?t=797977
jaumev is offline   Reply With Quote
Old 07-06-2014, 02:33 AM   #243
mathewst
Oddometer: 8
My suspension travel is 300/240
Front is whitepower mxma48
Rear is ohlins with reservoir
About the clutch its hydromechanical. Theres actuator piston at clutch lever in the engine. Goes smooth lets say 20 percent less force is needed to push it.
Old 07-06-2014, 03:20 PM   #244
jaumev OP
jaumev's Avatar
Oddometer: 1,487
Mine is 310 front but 220 rear... I would like more travel rear, can you give me the reference of your Ohlins?. Thanks.
Is it this clutch?: http://www.off-the-road.de/en/XT-660...ch-XT-660.html
I was tempted but from now my clutch works fine and was a bit worried about fiability. Are you happy with it?, do you recommend it?
Old 07-07-2014, 02:03 AM   #245
mathewst
Oddometer: 8
Hi,
this is the ohlins
http://www.off-the-road.de/en/XT-660...reservoir.html
about the clutch
I dont know. As I told I had some installation issues, guys from OTR are very slow responding these times (high season). It doesnt seems to be worthy investment. Have ridden just 50km with clutch. Will get to you later.
Whats your seat height and ground clearance? I got 97cm/35cm
Old 07-07-2014, 01:11 PM   #246
jaumev OP
jaumev's Avatar
Oddometer: 1,487
Hi,
this is the ohlins
about the clutch
The Tenere rear shock travel has 200 mm (OEM) so is this Ohlins designed for other bike? 40mm difference is a lot.
Please keep me updated about the clutch... it could be my next upgrade. Mine is ok to work with two fingers but after a long ride I miss the hidraulic clutch of my Sherco enduro bike.
You must be very tall. My seat is 91cm aprox and I reach tip toe (I'm 1,78)
The ground clearance with full tank is about 27 cm in the lowest point.
Old 07-08-2014, 05:06 AM   #247
mathewst
Oddometer: 8
Originally Posted by jaumev View Post
ask OTR. They are stating 300/240 for those in their built EVO bike.
I m just assuming mine is similar, I might be worng, its not really possible to measure it or is it?
About the clutch. Still got mounting issues, yesterday i was changing clutch lever geometry at the engine for more travel and removed original spring. Now it works ok (im not sure if cluytch wont be damaged without release spring though).
Changing my mind from not worth investment, it goes probly more than 30% easier than original clutch. Really comfy especially when im standing.
Old 07-08-2014, 01:56 PM   #248
jaumev OP
jaumev's Avatar
Oddometer: 1,487
Yes, I will ask, I'm curious.
My concern with more travel suspension is that i will not reach the floor!
How tall are you? Is your rear wheel 17" or 18"?
Old 07-08-2014, 03:39 PM   #249
mathewst
Oddometer: 8
I got 18 wheel from otr same as you. I 1.81 i can easily put one feet full on peg and on on ground. No way i can put both on ground but whats that for :)
I got lowered kahedo seat by 2.5cm bike got raised by mizu links by 3.5cm
Today i was riding with friend ktm 200exc he wasnt able to catch me in light terrain. Fields/mud. He called my build its like bulldog. Its hard to maneuvre it in the forest though :)
Old 07-08-2014, 08:25 PM   #250
Flat_Out
Oddometer: 13
Hi, this is a different exhaust!!! Could you tell witch is and why the change?
Best Regards,
Bruno, Caldas da Rainha, Portugal.
Flat_Out is offline   Reply With Quote
Old 07-08-2014, 08:30 PM   #251
Flat_Out
Oddometer: 13
XT660Z on the Baja Portalegre, Portugal.
[youtube]http://youtu.be/56jYuR-O20A[/youtube]
[youtube]http://youtu.be/IwViS1VRSoE[/youtube]
[youtube]http://youtu.be/6shbLJJeZmo[/youtube]
Old 07-09-2014, 02:12 AM   #252
JensEskildsen
Oddometer: 1,012
Cool vid
2003 xt600e 150.000km
1986 xt350 100.000km
JensEskildsen is offline   Reply With Quote
Old 07-09-2014, 03:11 PM   #253
jaumev OP
jaumev's Avatar
Oddometer: 1,487
Yes!!
Really cool videos, you run really fast. Good result?
Old 07-09-2014, 03:16 PM   #254
jaumev OP
jaumev's Avatar
Oddometer: 1,487
Best Regards,
Yes but just for some time meanwhile the Akrapovic is repaired.
A stone broke the carbon shield and it is been repaired for a titanium one.
This is an exhaust my dealer lent me. It come from a Yamaha YZ. I think is a Arrow. It is nice and work well but it is too noisy.
Old 07-13-2014, 02:08 AM   #255
jaumev OP
jaumev's Avatar
Oddometer: 1,487
Rebulid after the rally: http://traildreamer.com/en/reconstruida-tras-el-rally/
After the rally:
After the rebuild:
Times are GMT -7.   It's 03:41 PM.
