Old 09-10-2013, 02:40 PM   #16
hugemoth
hugemoth's Avatar
Oddometer: 3,032
In the US you want the sidecar on the right for a couple reasons, first because car drivers sit in the left seat, second because on crowned roads you want the sidecar to be on the downhill side.
Originally Posted by JerryH View Post
I just noticed all these scooters have the sidecar on the left, while Ural puts them on the right. I have seen sidecars on either side. What's the deal with that? does it make a difference?
Old 09-10-2013, 02:53 PM   #17
vt1099ace OP
vt1099ace's Avatar
Oddometer: 245
On vespa and stella that would be engine side..I wonder if it would block access?
vt1099ace is offline   Reply With Quote
Old 09-10-2013, 03:49 PM   #18
hugemoth
hugemoth's Avatar
Oddometer: 3,032
The California Sidecar didn't block access, don't know about other makes.
Old 09-10-2013, 03:57 PM   #19
vt1099ace OP
vt1099ace's Avatar
Oddometer: 245
Anyone do any distances with a hack or just local run-abouts? seems to me it would be a great place to put gear, especially if the seats removable and you keep the weight far less than a passenger.
Old 09-10-2013, 04:05 PM   #20
Eddieb
Eddieb's Avatar
Oddometer: 1,005
Judging by the posters location and the plates those scooters are all in the UK territory. Like here in NZ they drive on the left so all of the chairs are kerbside where they are.
Eddieb is offline   Reply With Quote
Old 09-10-2013, 04:49 PM   #21
gatling
gatling's Avatar
Oddometer: 2,413
www.CSCMotorcycles.com
'15 RX3 CSC Cyclone (An Awesome Motorcycle!)
gatling is offline   Reply With Quote
Old 09-10-2013, 05:05 PM   #22
gumshoe4
Oddometer: 855
"I just noticed all these scooters have the sidecar on the left, while Ural puts them on the right. I have seen sidecars on either side. What's the deal with that? does it make a difference?"
It's convention, Jerry. The Isle of Wight, where that scooter gathering occurred, is in the United Kingdom. In the US and most other locations where one drives on the right side of the road, the sidecar, by convention, goes on the right side of the tug. In the UK, where one drives on the left, the sidecar goes on the left side. Think of it as similar in nature to where the steering wheel is located in a car in the US and in Great Britain and that will answer your question...
gumshoe4 is offline   Reply With Quote
Old 09-22-2013, 11:56 PM   #23
vt1099ace OP
vt1099ace's Avatar
Oddometer: 245
Does Linkage in the front make a difference? Stella, vespa p's, honda helix all have trailing link front ends. Ural has leading link Fronts and are designed for hacks
Old 09-23-2013, 01:18 PM   #24
emmettken
emmettken's Avatar
Oddometer: 1,903
What make of sidecar is that in the video? Thanks!
emmettken is offline   Reply With Quote
Old 09-23-2013, 04:30 PM   #25
hugemoth
hugemoth's Avatar
Oddometer: 3,032
I don't think it matters whether it's trailing link, leading link, standard forks, it's just the amount of trail that makes a difference. The sidecars I've had on Vespas, VBB, Rally 200, and P200 all worked well.
Old 09-24-2013, 10:38 AM   #26
vt1099ace OP
vt1099ace's Avatar
Oddometer: 245
I talked to my stella dealer about a hack, his suggests at least the carb/exhaust upgrade from stock before adding a rig...
not unreasonable if I thinki about it.
Old 10-03-2013, 08:04 AM   #27
gogogordy
gogogordy's Avatar
Oddometer: 1,959
Yes, its been done
but I'd be more inclined to add a sidecar to an underbone scooter, vs. a monocoque Vespa or Stella.
A sidcar imposes some high stresses at its mounting points, and there isn't much more than stressed sheet metal to attach to on either of those.
Just because it's been done, doesn't mean its been durable.
You can get a sidecar for the Genuine Stella and various vintage Vespas. I can't imagine the Stella having enough power to handle one. but it has been done many times.
Isn't it past your bedtime?
gogogordy is offline   Reply With Quote
Old 10-03-2013, 12:29 PM   #28
vt1099ace OP
vt1099ace's Avatar
Oddometer: 245
I'd sure be interested to see an underbone with a hack, honda cubs never got over
110cc did they? Unless your talking helix, reflex, elites, etc... those I've seen with hacks... And a helix with the right style right looks pretty damned good imho
Old 10-03-2013, 12:53 PM   #29
gogogordy
gogogordy's Avatar
Oddometer: 1,959
Seen a couple Burgies with them, very attractive, robust and powered for the task.
I'm not a big Burgman fan, but you have to admit...thats a sexy set-up.
This one's pretty cool, but it's probably faster to walk:
And last, but not least:
gogogordy screwed with this post 10-03-2013 at 01:08 PM
Old 10-03-2013, 02:39 PM   #30
hugemoth
hugemoth's Avatar
Oddometer: 3,032
The way the sidecars attach to the Vespa is plenty sturdy, at least the ones I've used. They bolt on with 4 bolts right where the center hump meets the floorboard. The steel is double thick there. I've hauled some very heavy loads in mine for many thousands of miles and never had a problem.
Times are GMT -7.   It's 04:23 AM.
