Old 12-02-2013, 05:13 AM   #76
NeedForSpeed OP
PAK-MEISTER.COM
NeedForSpeed's Avatar
Oddometer: 1,348
PAK-MEISTER
Motorcycle Adventure Gear
CobraHeat LLC
A VETERAN OWNED AND OPERATED CO.
Nitron Shocks call (801) 663-7436
NeedForSpeed is offline   Reply With Quote
Old 12-04-2013, 05:05 AM   #77
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
Nitron Adventure Series
When a standard shock just isn’t up to the task…
Specifically designed and built for Dual Sport and Adventure bikes, the Adventure Series shocks offer exceptional year-round road and trail performance like no other.
Using billet aluminum components, Adventure shocks vastly improve the ride/handling of the bike at a significantly reduced weight compared to a standard shock.
Adventure shocks feature heavy-duty 16mm rods and a high-flow 46mm piston, both of which are custom tuned and developed for the demands of long-haul road commutes through to Paris-Dakar style endurance events.
New 46mm "Big Piston" design
Manufactured with a hard-anodised corrosion-resistant aluminium alloy CNC machined body using the highest quality internal components
Piggy-Back or remote 360 degree swiveling hose mounted gas pressure reservoir ± for fade-free consistent high-performance operation
Manual preload adjustment with c-spanner included, or...
Optional Hydraulic Remote Preload Adjuster System (HPA) for quick changes to rear ride-height to vary steering response between road and track (also ideal for shorter riders or for those bikes where the laden weight varies significantly; e.g. from solo to with pillion & luggage)
Adjustable length as standard to fine tune steering speed/response (also ideal for shorter riders who may want to reduce seat height [the typical lower seat height achievable is up to 30mm/1.25"] -please specify when ordering - see above)
Low friction rose jointed eyes where applicable (bike-dependent end fittings may differ from those shown here)
Separate compression and rebound damping adjustment for more advanced bike setup
By far the best value professional race level shock you can buy
3rd piston Shim-Stack for very low speed rebound damping control
Teflon lined low-friction rose jointed eyes where applicable (bike-dependent end fittings may differ from those shown here
Ultra low-friction piston rod seal design
Completely rebuildable/re-valvable with rapid maintenance and support service from Pak-Meister
PAK-MEISTER
CobraHeat LLC
Old 12-04-2013, 09:44 AM   #78
pjm204
Oddometer: 1,987
I've got about a thousand miles on my Adventure Series Race shock in the past couple weeks and it has been great. I'm going to use the ride height adjustment to raise the rear end a bit.
Current bikes:2006 DL650, 2008 WR250R
Past bikes: XT225, TTR125, '04 CRF50 '74 DT125,'70 TS250,'85 v45, '89 zx600c, '78 GS400x, '99 GS500E, '01 GS500E '05 Z750s, '77 GS400e, '82 GS1100ez, '97 GSX600, '07 VFR800, '03 KLR650, '03 FJR1300, '06 DL1000, '00 KLR650, '99 WR360, '08 DL650, '05 DR650, '08 EX650r, '96 CR500, '82 GS450T, '06 Ural
pjm204 is offline   Reply With Quote
Old 12-04-2013, 01:49 PM   #79
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
Start posting up some pictures guys!
PAK-MEISTER
CobraHeat LLC
Old 12-05-2013, 12:05 PM   #80
L.B.S.
Oddometer: 1,288
Mine is still sitting in the box anxiously awaiting it's replacement spring, and then I'll have to source a spring compressor and a funky pin-style preload collar tool.
It's now minus 6 at my place this morning with snow forecast for later, and having no garage, I'm a little unwilling to re/re the shock twice, if I don't have to...
L.B.S. is offline   Reply With Quote
Old 12-06-2013, 07:39 AM   #81
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
These orders shipped yesterday!
Nitron Track Series YAMAHA TDR250 (88-92)
Nitron Sport Series BMW R1150R (01-06) FRONT
Nitron Sport Series BMW R1150R (01-06) REAR
Nitron Track Series TRIUMPH Daytona T595/955i Single Arm Shocks (97-06)
Nitron Sport Series SUZUKI GSF/GSX 1250 Bandit Shocks (06-12)
PAK-MEISTER
CobraHeat LLC
Old 12-07-2013, 12:30 PM   #82
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
we'll check on the spring Monday morning...
Mike
PAK-MEISTER
CobraHeat LLC
Old 12-10-2013, 05:22 AM   #83
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
Nitron Adventure Series Shocks...
Specifically designed and built for Dual Sport and Adventure bikes, the Adventure Series shocks offer exceptional year-round road and trail performance lik...e no other.
PAK-MEISTER
CobraHeat LLC
Old 12-10-2013, 10:09 AM   #84
L.B.S.
Oddometer: 1,288
Mike
Have sent you a PM
Old 12-10-2013, 06:08 PM   #85
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
the replacement spring arrived and will be going out in the next day or two...
thanks-
PAK-MEISTER
CobraHeat LLC
Old 12-11-2013, 10:09 AM   #86
L.B.S.
Oddometer: 1,288
thanks-
No, thank you!
Old 12-19-2013, 02:41 AM   #87
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
These orders have shipped- thank you!
Nitron Sport Series Shock BMW R1150R (01-06) FRONT
Nitron Sport Series Shock BMW R1150R (01-06) REAR
PAK-MEISTER
CobraHeat LLC
Old 12-19-2013, 09:54 AM   #88
SPEIRMOOR
Oddometer: 212
Originally Posted by SPEIRMOOR View Post
DUCATI
Sport 1000 06-08
Sport 1000 06-08
Is this the singlesided swing arm Sportclassic? If so a few of us on the Ducati forum were wondering which version shock it is and have you any pictures of it installed on a bike?
Bump
SPEIRMOOR is offline   Reply With Quote
Old 12-19-2013, 02:21 PM   #89
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
Negative on the Ducati
PAK-MEISTER
CobraHeat LLC
Old 12-22-2013, 07:08 AM   #90
NeedForSpeed OP
PAK-MEISTER.COM
Oddometer: 1,348
Big news coming from Nitron- stay tuned...
PAK-MEISTER
CobraHeat LLC
Times are GMT -7.   It's 01:35 AM.
