Old 09-14-2013, 11:07 AM   #1
JNS Engineering OP
JNS Engineering's Avatar
Oddometer: 184
DR650 Side Stand Foot Pad - JNS Engineering
Recently I've had a few requests for this product. Here's a picture of the prototypes. Just a few last details to iron out.
Powder coated production parts will be ready in about four weeks.
Available for pre-order here: http://www.jnsengineering.com/produc...tand-foot-pad/
JNS Engineering is offline   Reply With Quote
Old 09-16-2013, 02:21 PM   #2
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,074
Nice! How does that attach? Is sidestand threaded below?
Bill
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 09-17-2013, 07:10 PM   #3
JNS Engineering OP
Oddometer: 184
I originally tried jack nuts (like a nut rivet but installed with very simple hand tools) mounted to the underside of the OEM foot but I don't think they are strong enough for this application. In testing I boogered several with ease.
So it looks like installation will require the following steps....
1) remove side stand, not doing so will make step 2) - 5) very frustrating
2) match drill the OEM foot with a 1/4" then 5/16" drill bit
3) carefully position washer and nut on the top side of OEM foot, under the little gusset
4) position JNS pad and thread provided M6 flat-head from the bottom side
5) use flat blade screw driver to hold nut still*, torque appropriately
*close up photo showing this particular detail
Bill
Old 09-17-2013, 07:16 PM   #4
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Or make them out of steel so we can weld them?
Danjal is offline   Reply With Quote
Old 09-17-2013, 07:22 PM   #5
Rainier_runner
Epic Adventurer
Rainier_runner's Avatar
Oddometer: 301
Unfortunately no welder here however. I'm looking forward to the bolt on!
2014 KTM 1190 Adventure R
2006 Suzuki DR 650 ADV
Rainier_runner is offline   Reply With Quote
Old 09-18-2013, 06:05 AM   #6
JNS Engineering OP
Oddometer: 184
Not a bad idea! I can offer both steel and aluminum.
John
Old 09-18-2013, 06:49 AM   #7
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
John, if you have a welder,you could also add a return service or core program. You'd have to gauge some interest on that if it's viable for you.
Old 09-25-2013, 01:26 PM   #8
JNS Engineering OP
Oddometer: 184
Danjal,
I now offer a JNS steel weld-on foot pad!
John
Old 10-10-2013, 11:14 PM   #9
JNS Engineering OP
Oddometer: 184
Powder coated aluminum fender brace and FOOT PAD!
Old 10-11-2013, 09:53 AM   #10
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Since you have most of it done already.. another idea for you. Maybe incorporate it into the fender brace if it's a top mounted one?
Nice oil cooler guard btw.
Danjal screwed with this post 10-11-2013 at 10:32 AM
Old 10-24-2013, 11:11 AM   #11
JNS Engineering OP
Oddometer: 184
What kind of light is that?
Old 10-26-2013, 12:14 AM   #12
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
ADV monster. Sanjoh has a thread here in the vendors section.
Old 06-05-2014, 04:04 PM   #13
NWBoon
Oddometer: 88
I just placed an order for the DR650 fender brace and steel side stand foot pad. I'm in Seattle.
NWBoon is offline   Reply With Quote
Times are GMT -7.   It's 06:25 PM.
