Old 09-14-2013, 02:44 PM   #1
rotaryracer OP
rotaryracer's Avatar
Oddometer: 689
2013 R1200GS LC (GSW) parts by DS Bike Protection...now available at ADV Motorrad!
DS Bike Protection (based out of Igualada, Spain, near Barcelona) has been hard at work prototyping, testing, and producing new parts for the 2013+ R1200GS LC (a.k.a GSW). Building on the success of developing ADV gear for both the prior generation GS and other bikes, DSBP's parts are a great balance of form, function, and value.
ADV Motorrad is the exclusive North American importer for DS Bike Protection and we are excited to make these parts available to our fellow ADVrider inmates! We have good stock of most parts at our shop in New York, with more coming regularly from Spain. There's also new products in development that will be announced later in this thread after testing is complete.
First up...secret spy shots from the confines of the DSBP product testing lab....
Jason Smith
www.advmotorrad.com
Check out the ADV Motorrad vendor thread for great deals on adventure gear!
rotaryracer screwed with this post 10-28-2013 at 04:00 PM
rotaryracer is offline   Reply With Quote
Old 09-14-2013, 03:45 PM   #2
rotaryracer OP
Oddometer: 689
DSBP R1200 GSW Cylinder Head Guards - $134.99 -
DS Bike Protection cylinder head guards for the 2013 R1200GS LC ("Wethead"). These guards are laser cut and formed from 3MM aluminum, then anodized in either black or silver. All screws and bushings required for installation are included. Protect your valve covers if your GS goes down, and make sure you can ride out versus being towed out!
Jason Smith
www.advmotorrad.com
rotaryracer screwed with this post 11-26-2013 at 06:31 AM
Old 09-14-2013, 03:47 PM   #3
rotaryracer OP
Oddometer: 689
DSBP R1200 GSW Driveshaft Slider - $31.99 -
DS Bike Protection driveshaft slider made of durable, shock-absorbing nylon. This crash bung will help protect your expensive final drive housing in case of a fall. Easy installation in just a few minutes!
Jason Smith
www.advmotorrad.com
Old 09-16-2013, 10:39 AM   #4
rotaryracer OP
Oddometer: 689
DSBP R1200 GSW Sidestand Enlarger - $38.99 -
The stock footprint of the new liquid cooled R1200GS side stand is fairly small for a larger bike, making it a somewhat risky proposition to park on hot asphalt or loose sand, especially when you're loaded up with gear for a long ride. This aluminum side stand enlarger from DS Bike Protection will help prevent your "wasserboxer" from tipping over and incurring unnecessary and expensive damage. Tucks in nicely for no interference with riding boots, and installs quickly with included hardware.
Jason Smith
www.advmotorrad.com
Old 09-18-2013, 05:10 PM   #5
rotaryracer OP
Oddometer: 689
DSBP R1200 GSW Top Case Mounting Plate and Luggage Rack - $104.99 -
Made from 4mm aluminum, this top case mounting plate installs to the factory rack and doubles as a luggage rack when used without the top case. Most flat-bottom aluminum top cases (such as Holan Nomada Pro, Happy Trail, Bumot, Muffintops, etc.) will mount securely to the mounting plate using a bolt-through design into the threaded inserts in the plate. Numerous slots and holes provide multiple tie-down points. Available in anodized black or anodized silver.
Jason Smith
www.advmotorrad.com
Old 09-20-2013, 06:26 PM   #6
rotaryracer OP
Oddometer: 689
DSBP R1200 GSW Centerstand Skidplate - $49.99 -
The DSBP centerstand skidplate for the new 2013+ R1200GS LC extends protection from the sumpguard / engine skidplate. Made ​​of 4MM aluminum with four clamps that secure the guard to the stand, this will help fully protect the underside of your new GS. Available in anodized silver.
The first two pictures show the finished product in anodized silver; the last four pictures are of the prototype prior to anodizing.
Jason Smith
www.advmotorrad.com
Old 09-23-2013, 06:13 AM   #7
rotaryracer OP
Oddometer: 689
DSBP R1200 GSW Auxiliary Light Bar - $49.99 -
The DSBP auxiliary light bar for the new 2013+ R1200GS LC provides a solid, stable mounting surface for your auxiliary lights. Multiple mounting holes in M8 and M10 allow fitment of all popular aftermarket lights, with solid spacer mounts to help dampen road vibration. Available in anodized black.
Pictures of the prototype are shown in natural aluminum; the light bar and spacers on the final product are both anodized black. Hella Micro DE light guards (shown in the black and white picture) are available separately here.
Jason Smith
www.advmotorrad.com
Old 10-18-2013, 08:07 AM   #8
rotaryracer OP
Oddometer: 689
We've been happily farkling a bunch of GSWs with new parts from DS Bike, and appreciate all the positive feedback on the new products. We still have good stock of most LC items, and should have more arriving from Spain the week of 10/28.
We'll be announcing some new products here shortly (hint - if you take a look at the pictures of the LC at speed in the first post, you can see one of them ), but if you have any questions, please feel free to PM, email at sales AT advmotorrad DOT com, or call the shop at (585) 310-ADVM.
Jason Smith
www.advmotorrad.com
Old 10-27-2013, 01:51 PM   #9
rotaryracer OP
Oddometer: 689
DSBP R1200 GSW Headlight Protector (Polycarbonate) - $74.99 -
The DS Bike Protection polycarbonate headlight guard for the new 2013+ R1200GS is lightweight, yet protects the expensive headlight assembly from damage. It fits perfectly and mounts quickly using custom designed brackets. The lens guard is made from 4mm polycarbonate to provide strong protection from the worst road or trail debris.
Pictures of the guard mounted on the bike are of the prototype and the hardware used is not final; the pictures of the guard off the bike show the final Allen head screws used for attachment.
Jason Smith
www.advmotorrad.com
Old 10-28-2013, 03:24 PM   #10
rotaryracer OP
Oddometer: 689
DSBP R1200 GSW Headlight Protector (Steel) - $99.99 -
The DS Bike Protection steel headlight guard for the new 2013+ R1200GS is designed to protect that uber-expensive headlight lens. It mounts securely using custom designed brackets, yet is still easily removable for cleaning of the headlight lens. The lens guard features a laser cut design to minimize any degradation in light output.
Jason Smith
www.advmotorrad.com
Old 11-16-2013, 04:08 AM   #11
rotaryracer OP
Oddometer: 689
GSW parts are moving briskly, but we still have good stock in New York and more on the way from Spain.
Anyone want to take a guess at who manufactures those bitchin' crashbars on the red bike in the first post? More info to come, but for those that have been holding out for a set of stainless steel crashbars at an incredible price...your wait will soon be over....
Jason Smith
www.advmotorrad.com
Old 11-22-2013, 08:30 AM   #12
rotaryracer OP
Oddometer: 689
DSBP R1200GSW Stainless Steel Crashbars - $299.99 $269.99 -
These bars are designed to perfectly fit your bike while providing protection in case of a fall. These bars are made from 25mm O.D. stainless steel tubing with 2mm wall thickness and are available in either bead-blasted natural finish or black powdercoat. The lower mounting points are connected to a heavy duty mounting bracket that helps distribute any impact force across a larger surface area. All mounting hardware is included for an easy bolt-on installation.
Jason Smith
www.advmotorrad.com
rotaryracer screwed with this post 12-06-2013 at 09:21 AM
Old 11-23-2013, 03:08 PM   #13
rotaryracer OP
Oddometer: 689
A few pics off the bike to better show some of the crashbar details. These shots are of the raw prototype and not the finished product. The pics above with the bars mounted on the bike show the finished product in bead-blasted stainless. Feel free to click any of the pictures to be taken to the product page for more info.
We estimate we'll have a few of these in stock in stainless and powdercoated black in the next 3-4 weeks. Of course, I'm sure I could bring in more at a better price if someone wanted to twist my arm for a group buy.....
Jason Smith
www.advmotorrad.com
Old 11-26-2013, 05:27 AM   #14
rotaryracer OP
Oddometer: 689
A few more detail shots of the finished stainless steel bead-blasted crashbars off the bike...
Jason Smith
www.advmotorrad.com
Old 12-04-2013, 05:10 PM   #15
rotaryracer OP
Oddometer: 689
The first order of crashbars are en route from Spain and should arrive by Monday the 9th....
For those that have already pre-ordered a set (or are thinking about doing so), here's a quick video from DS Bike showing just how easily these mount up....
Jason Smith
www.advmotorrad.com
Times are GMT -7.   It's 05:31 AM.
